I have my core connected via I2C to my MPU6050 accelerometer and gyroscope sensor.I am sampling at 20Hz per second.1 sample contains 12 bytes of data (ax,ay,az and gx,gy,gz).
I need to send the data to cloud.Will the cloud be able to accept if i send the samples in real time?
Or should i store data in a string for 30s or so and send it?
How to send my data to the cloud? I think its using Spark.variable or Spark.publish,but how can I view the data in the cloud and check if the data is sent to the cloud?
Good question! The fastest way to send data from your core would be to open a direct TCP or UDP connection to your core, and stream data directly into your program. The next best is probably a Spark.publish, but the limit is currently 1 publish a second, at a length of about 63 characters. If you did a Spark.variable, you could get it at about the same speed, but you could encode up to about 600 characters.
If you’re using Spark.publish, you can open a stream to the API anywhere in the world that will let you see your events:
