Hi all!
I have a projet with RMF95 and XENON and FeatherWing. I am trying to use the librairy of RadioHead.h (https://www.airspayce.com/mikem/arduino/RadioHead/index.html)
I have been struggling with that pretty much the whole day and cannot make it work.
It fail right on the init process because it look like I cannot change the working mode…
Since Xenon use nRF52840 , I assumed that I need plaform NRF52.
#define RH_PLATFORM RH_PLATFORM_NRF52
using that, I have been able to compile my code
I defined the module it with the CS and IRQ in my main:
RH_RF95 rf95(RFM95_CS, RFM95_INT);
The function RH_RF95::init() return false because the OP_MODE is 8 instead of 80 (which is set just before).
NOTE: If I use “RH_RF95 rf95” only, OP_MODE response 0 so it’s look like I have some communication.
I seen on the main page of RadioHead particular attention for photon (title “Building for Particle Photon”) but since Xenon use NRF52840, I assumed it’s not needed).
PLEASE HELP
Francis
