Hi all
I’ve noticed that my product which publishes data using Particle.Publish requires a reset after establishing connection to a WiFi network via SoftAP, otherwise, no data is published. Has anyone else noticed this?
I can work around it by asking customers to reset manually after they have setup the device but ideally it might be done in firmware if this is a common issue?
