Remote Control of Temperature and Humidity with Blynk
#2
i have followed the steps however after 5 or 6 seconds my photon then blinks green has the code you talk about (Also be sure to create the Blink.virtualWrite() function outside of the void loop and avoid to use the delay()) been added or do i need to add it
Thanks for your help…Ben
#3
If you are using the same code as above, I’d think your code gets stuck here
    //Serial.begin(9600);
    Blynk.begin(auth);
    if (!htu.begin()){
        Serial.println("Couldn't find sensor!");
        while(1);  // <--- stuck here IMHO
If you change this line to
  while(1) Particle.process();
your code will still block, but you won’t get blinking green and keep breathing cyan.
That’s already present in the code above and does work as is - provided your HTU21D is wired and working correctly :wink:
#4
thanks for the help, im still getting on my blynk app photon is not even online even though it is. is it only char auth code which needs changing.
cheers Ben
#5
Hello @benjiiiiuk,
Did you import the HTU21D and Bynk libraries in your app? Did you check the connections of the HTU21D?
Also make sure to use the token Blynk generates for your project. The string I have in the char auth[] line of the above code will not work!
Let me know if you still have issues.
#6
If my hint above cured the green blinking that other part of my post will still hold true
You need to get that sorted before you can expect Blynk to see your device. Only when you regularly call Blynk.run() (which you don’t if you’re still blocking) Blink will see your device.
#7
@ScruffR why the code should stuck in the if statement at the void setup? Why this does not happen in my case? I am using the code I posted in the tutorial with no issues. Silly question, @benjiiiiuk are you using the HTU21D-F sensor? I am curious to understand what is the cause of your problems.
#8
Not stuck in the if() statement but in the while(1) (code flow only breaks out of a while() when the condition evaluates to false which is the same as 0).
When will 1 ever become 0 to get out of the while()?
The answer to your question, why this doesn’t happen with your code is probably because !htu.begin() does not evaluate to true since your HTU does respond, but @benjiiiiuk’s most likely does not.
That was your code, so I thought you knew what it does :sunglasses:
#9
Thank you for the clarification :smile: , the question is if @benjiiiiuk is using the HTU21D-F properly connected and imported the HTU21D library in his app what do you think the reason would be to have !htu.begin() evaluated to true?
#10
That’s why I said this in my first post :wink:
If he hadn’t done that his code would not have built, but since he was even able to flash the code the lib was definetly present.
Exactly what I implicitly suggested by the above “condition” - I think the sensor is not wired or working correctly :wink:
#11
Yep, it must be some hardware issue. Sorry for asking so many questions, but I’m totally new to programming and I am trying to learn as much as I can. I appreciate your replys and feedback!
#12
Thanks for all your replies. I have just had a look and realised that I am infact using the bmp180 sensor so no wonder it won’t work “what a clown” I have oredered the correct sensor and will give it a go when it arrives.
#13
Or you just use the correct library and adjust the respective code.
See https://build.particle.io/libs/5393009b7b167fbbb60008ab/tab/bmp085test.ino
#14
Hello, I used the code above and everything works fine for a little bit. Then the boron still breaths cyan blue but no data is being sent. The error message is This device is currently unreachable by the Device Cloud. Displaying last recorded device vitals. Im confused about your conversation dealing with the
while(1);
and the delay() not being in the loop
Should i be adding something to this. Will this fix my issue?
here is my code
#include <Ubidots.h>
#include <blynk.h>
#include <HTU21D.h>
#ifndef TOKEN
#define TOKEN "My token"  // Put here your Ubidots TOKEN
#endif
Ubidots ubidots(TOKEN, UBI_TCP); // Comment this line to use another protocol.
HTU21D htu = HTU21D();
double tempVal, tempFVal, humidVal;
char auth[] = "My token";
    Serial.begin(115200);
  ubidots.setDebug(true);  // Uncomment this line for printing debug messages
    Blynk.begin(auth);
    if (!htu.begin()){
        while(1);
BLYNK_READ(V0){
    Blynk.virtualWrite(V0, round(tempVal*100)/100);
BLYNK_READ(V1){
    Blynk.virtualWrite(V1, round(tempFVal*100)/100);
 BLYNK_READ(V2){
    Blynk.virtualWrite(V2, humidVal);
    Blynk.run();
    //Serial.print("Temp: "); Serial.print(htu.readTemperature()); Serial.print(" C"); Serial.print("\t"); Serial.print(tempFVal); Serial.print(" F");
    //Serial.print("\t\tHUM: "); Serial.print(htu.readHumidity()); Serial.println(" %");
    //Serial.println("");
    //delay(10000);
    tempVal = htu.readTemperature();
    tempFVal = ((9.0/5.0)*tempVal + 32);
    humidVal = htu.readHumidity();
     Particle.publish("Temperature C", String(tempVal), PRIVATE);
     Particle.publish("Temperature F", String(tempFVal), PRIVATE);
     Particle.publish("Humidity", String(humidVal), PRIVATE);
  float value1 = tempVal;
  float value2 = tempFVal;
  float value3 = humidVal;
  ubidots.add("Temperature C", value1);  // Change for your variable name
  ubidots.add("Temperature F", value2);
  ubidots.add("Humidity", value3);
  bool bufferSent = false;
  bufferSent = ubidots.send();
  if(bufferSent){
    // Do something if values were sent properly
    Serial.println("Values sent by the device");
  delay(5000);
Thank you
#15
Also sometimes my humidity values is 998. Has anyone seen this before and know what I should go to fix it?
Thanks again
#16
First, you make multiple Particle.publish() calls very quickly. You should combine your multiple publishes into one single publish. If you don’t know, there is a limit on how fast you call publish (1/second or 4/within 4 seconds with a 4 second cool down period). You come close to violating the limit which may cause disconnects or bad publishes.
Second, get ride of String and instead us snprintf.
Third, you asked about this, don’t use delay() within your loop. You should use another method to space out your updates such as a millis timer or a timer library.
Fourth, the HTU library returns float values. Why do you declare doubles, then convert back to float before updating Blynk?
Here are some of those comments implemented on your own code… I did not compile so you will have to test:
#include <blynk.h>
#include <HTU21D.h>
#ifndef TOKEN
#endif
float tempVal, tempFVal, humidVal;
unsigned long lastUpdateMillis = 0;  //Used to hold the last time, in millis, that we updated.
unsigned long updateInterval = 5000;  //This is the interval, in millis, between updates.
char msg[200];
    Blynk.begin(auth);
    if (!htu.begin()){
        while(1) Particle.process();  //Stay here forever... never exit. Must reconnect sensor and reset device.
BLYNK_READ(V0){
BLYNK_READ(V1){
 BLYNK_READ(V2){
  Blynk.run();  //Moved outside of the millis timer to run as often as possible. See scruffR's comments.
  if (millis() - lastUpdateMillis > updateInterval) {
    //delay(10000);
    snprintf(msg, sizeof(msg) - 1, "TempC:%u,TempF:%u,Humidity:%u", tempVal, tempFval, humidVal);
    Particle.publish("EnvironmentData", msg, PRIVATE);
    ubidots.add("Temperature C", tempVal);  // Change for your variable name
    ubidots.add("Temperature F", tempFVal);
    ubidots.add("Humidity", humidVal);
    if(bufferSent){
    lastUpdateMillis = millis();
#17
This will definetly break the cloud connection.
You should change that to while(1) Particle.process();
Blynk.run() should be called as often as possible, so it should be outside of the if() block.
#18
Thank you so much for your help. As you can see Im new to this.
#19
Ninjatill thank you for posting the code. I had a question about it,
Can I play with the number (5000) in the code below to take measurements every hours?
Im assuming it wont be very accurate (example: sampling every 20 min), so there is a better way
I have used
if(Time.minute() % 20== 0 && Time.minute() != Time_old){ //sample every 20 min
During testing I used sample every minute. The issue was that ubidots was updating at weird times (not every min) and the values was wrong — 998 C and 1830F, humidity was steady
#20
Yes. Change to 3600000 for one hour. Or 1200000 for 20 minutes.
How accurate do you need it? No matter what the update internal, the millis timer method will be accurate to a few milliseconds. There may be some drift over time since I wasn’t resetting the timer until after the sensor readings. Move the timer reset closer to the top of the if statement to reduce the drift.
I don’t know how you update Time_old so it’s hard to say. I have seen others trip over using Time because they forget that when Time.minute() % 20== 0 becomes true, you will be updating as fast as possible for one whole minute (possibly 10s of thousands of iterations in a minute.) There needs to be some other safety mechanism to only run once when that condition becomes true. You can use this method, or numerous others, as long as you use it correctly.
#21
Hello,
I want to thank you guys again for all your help. I have modified the code and it all work well at first glance. The one issue is that it publishes to particle 4 - 5 time in a row even tho im asking it to publish one every 5 min. Ubidots seems to work good, one thing i noticed was that once in a blue it will give me min data verse 5 min data but once in an hour. Here is the code . I think somting is wrong with the time part of the code
#include <HTU21D.h>
#ifndef TOKEN
#define TOKEN "A1E-*****************"  // Put here your Ubidots TOKEN
#endif
int Time_old;
char msg[200];
  pinMode(D7, OUTPUT);
  digitalWrite(D7, LOW);
  if (!htu.begin()){
  if(Time.minute() % 5 == 0 && Time_old != Time.minute())
    digitalWrite(D7, HIGH);
  unsigned long timestamp_seconds = Time.now();
  Serial.println("Time Condition Satisfied!");
  Time_old = Time.minute();
  Serial.println("HTU Values Aquired!");
  snprintf(msg, sizeof(msg) - 1, "TempC:%f,TempF:%f,Humidity:%f", tempVal, tempFVal, humidVal);
  Serial.println("Particle Published!");
  ubidots.add("temperature", tempVal, NULL, timestamp_seconds);  // Change for your variable
  ubidots.add("Humidity", humidVal, NULL, timestamp_seconds);  // Change for your variable name
  //ubidots.add("Temperature C", tempVal);  // Change for your variable name
  //ubidots.add("Temperature F", tempFVal);
  //ubidots.add("Humidity", humidVal);
  bufferSent = ubidots.send();  // Will send data to a device label that matches the device Id
  if(bufferSent){
  delay(2000);
Maybe someone can spot the problem
Thanks again
