Thanks for your help avtolstoy. I ran the command:
particle keys server --protocol udp --host '$id.udp-mesh.particle.io'
particle-cli v1.35.2
! A newer version (1.36.0) of particle-cli is available.
! Upgrade now by running: npm install -g particle-cli
Okay! New keys in place, your device will not restart.
After that I tried setup via mobile again. It still results in an Error: "Your deive could not connect to the device cloud. Please try again.
Additionally, if not in setup mode (blinking blue) or dfu mode (blinking yellow), my device is blinking cyan (fast) and occasionally orange, which would indicate a decryption error according to https://docs.particle.io/tutorials/device-os/led/argon/
I also tried the following, but device is still blinking cyan and orange:
particle keys doctor <id> -v
New Key Created!
Saved!
dfu-util 0.8
ID 2b04:d00c
Claiming USB DFU Interface...
Setting Alternate Setting #1 ...
dfuIDLE, continuing
DfuSe interface name: "DCD Flash "
Downloading to address = 0x00000c22, size = 121
Download [=========================] 100% 121 bytes
Download done.
File downloaded successfully
Transitioning to dfuMANIFEST state
Invalid DFU suffix signature
Saved!
attempting to add a new public key for device <id>
submitting public key succeeded!
Okay! New keys in place, your device should restart.
1 orange blink: Decryption error.
2 orange blinks: Could not reach the internet.
3 orange blinks: Connected to the internet, but could not reach the Particle Device Cloud. This sometimes is seen as yellow or red and indicates bad server keys.
I count 3 orange blinks in my case, which would still indicate bad server keys. Any idea how to fix this?
Yes, I changed it with my actual device ID which I obtained with particle identify. Wasn’t sure if it was sensitive data so I let it out here.
I updated to 1.36.3 since my post from last week. Tried the commands again without success.
