I’m sending messages from a photon device to a Azure IoT Hub. I monitor the outgoing messages from the particle portal and they seem to be just fine. Below is a recent sample:
"name": "*****",
"data": "{\"eventSentUtcTime\": \"2017-11-03 10:42:00\", \"machine\": \"x10\", \"eventType\": \"coffeeMaintenance\", \"data\": {\"category\": \"MillingPlantCoffee\", \"count\": \"24868\"}",
"ttl": 60,
"published_at": "2017-11-03T09:42:39.233Z",
"coreid": "*****",
"userid": "*****",
"version": 37,
"public": false,
"productID": 1427
But when I check incoming messages from the Azure IoT Hub, they’re empty except the schema. I’m using the Device explorer from Azure’s github for monitoring.
03.11.2017 10:42:09> Device: [*****], Data:[{"data":{"count":"","category":""},"eventType":"","machine":"","eventSentUtcTime":""}]
I double checked the incoming messages inside a sql database, which also displays an empty json message except the given schema.
data,eventType,machine,eventSentUtcTime,EventProcessedUtcTime,PartitionId,EventEnqueuedUtcTime,IoTHub
Record,,,,2017-11-03T10:01:26.8295948Z,1,2017-11-03T10:01:25.7270000Z,Record
The access policy I’m using has all permissions checked. I don’t know where to problem lies.
