# Read temperature using a Timer
**URL:** https://community.particle.io/t/read-temperature-using-a-timer/17063
**Category:** General
**Created:** [November 1, 2015, 6:21pm UTC](https://community.particle.io/t/read-temperature-using-a-timer/17063 "2015-11-01T18:21:33Z")
**Posts on this page:** 1
**Showing post:** 17
### Author: ![BulldogLowell](https://sea2.discourse-cdn.com/flex026/user_avatar/community.particle.io/bulldoglowell/32/4305_2.png) [@BulldogLowell](https://community.particle.io/u/BulldogLowell)
#### Post date: [November 2, 2015, 12:04am UTC](https://community.particle.io/t/read-temperature-using-a-timer/17063/17 "2015-11-02T00:04:03Z")
have you considered a slightly simpler approach like this (uncompiled, untested):
```cpp
#include "DS18B20/Particle-OneWire.h"
#include "DS18B20/DS18B20.h"
// Globals
DS18B20 ds18b20 = DS18B20(D2); //Sets Pin D2 for Water Temp Sensor
int LED = D7; // pin for LED
int PIR = D3; //pin for PIR motion sensor
float pubTemp;
double celsius;
double fahrenheit;
const int Metric_Publish_Rate = 30000;
const int DS18B20_SAMPLE_INTERVAL = 2500;
unsigned long metricPublishTime = 0;
unsigned long tempSampleTime = 0;
volatile bool isrFlag = false;
int dsAttempts = 0;
Timer ledTimer(1000, blink_led);
// class Alarm {
// public:
// Alarm() {
// Particle.function("alarm", &Alarm::alarm, this);
// int status;
// int alarm(String command) {
// if(command == "reset"){
// status = 0;
// if(command == "panic"){
// status = 1;
// else {
// status = -1;
// return status;
void setup()
    Time.zone(-5);
    Particle.syncTime();
    Particle.variable("tempCelsius", &celsius, DOUBLE);
    Particle.variable("tempFahrenheit", &fahrenheit, DOUBLE);
    pinMode(LED, OUTPUT); // Use for a simple test of the led on or off by subscribing to a topical called led
    pinMode(PIR, INPUT_PULLUP); // Initialize pin as input with an internal pull-up resistor
    ledTimer.start();
    attachInterrupt(PIR, motion_detected, RISING);
    Serial.begin(9600);
void loop()
    if (millis() - tempSampleTime > DS18B20_SAMPLE_INTERVAL)
        getTemp();
        tempSampleTime = millis();
    if (millis() - metricPublishTime > Metric_Publish_Rate)
        Serial.println("Publishing now.");
        publishData();
        metricPublishTime = millis();
    if (isrFlag)
      Particle.publish("photon/motion/detected", "1");
      isrFlag = false;
void blink_led()
    digitalWrite(LED, !digitalRead(LED));
void motion_detected()
  isrFlag = true;
//void resetAlarm()
// Alarm alarm;
// alarm.status = 0;
//void raiseAlarm()
// Particle.publish("photon/motion/detected", "1");
// resetAlarm();
void publishData()
    if(!ds18b20.crcCheck()){
        return;
    Particle.publish("photon/temperature/celsius", String(celsius));
    Particle.publish("photon/temperature/fahrenheit", String(fahrenheit));
void getTemp()
    if(!ds18b20.search()){
        ds18b20.resetsearch();
        celsius = ds18b20.getTemperature();
        Serial.println(celsius);
        while (!ds18b20.crcCheck() && dsAttempts < 4){
            Serial.println("Caught bad value.");
            dsAttempts++;
            Serial.print("Attempts to Read: ");
            Serial.println(dsAttempts);
            if (dsAttempts == 3){
                delay(1000);
            continue;
        dsAttempts = 0;
        fahrenheit = ds18b20.convertToFahrenheit(celsius);
        Serial.println(fahrenheit);
_[View the full topic](https://community.particle.io/t/read-temperature-using-a-timer/17063)._
