Rate limited? Why
Not sure if I’ve chosen the right category for this issue, but my Electron has been rate limited. I can’t figure out why. It is publishing events at the rate of only once every 5 minutes. It has been running flawlessly, completely hands-off, for several months now. But this AM he remote device to which the Electron is sending events stopped receiving them. Not only have I not ‘touched’ anything, I haven’t even looked at my code in many months.
I have attached a couple of screenshots
. Can anyone suggest what is going on?
You’d need to provide your code to be sure. However, the most likely situation is that you’re attempting to publish on every loop, or at least more than once per second.
