@rickkas7 - removed SINGLE_THREADED_BLOCK - testing so far so good and not showing previous issues. I will expand test code to now publish to cloud to make sure it no longer deadlocks
Test APP (below):
- removed SINGLE_THREADED_BLOCK and added in 2 Particle.publish() calls.
- SYSTEM_THREAD(ENABLED)
XENON with Ethernet wing:
Still failing once publish functions are called - so I suspect the SPI issues as @rickkas7 describes above are in play once the SPI ethernet is used. It seems the SINGLE _THREADED_BLOCK just made he issue appear sooner.
ARGON:
Takes longer to fail but locks up within 3 iterations
The console does not receive the publish data from either device at all.
Remove SYSTEM_THREAD(ENABLED) - all devices work and do not lockup, Published messages received in console.
APP:
// SYSTEM_THREAD(ENABLED);
const int dbOffset = 50;
const int sizeOfAttributeName = 4;
const int largestAttributeValue = 20;
const int numOfAttributes = 75;
struct
{ // common struct for attributes stored in EEPROM
int attributeNum;
char attributeValue[largestAttributeValue + 1];
time_t lastChanged;
} attributes;
char buf[128];
void eepromCreateDataTable() //set NVram to defaults
Serial.printf("\nStarting EEPROM test");
for (int recno = 0; recno < numOfAttributes; recno++)
attributes.attributeNum = recno;
attributes.lastChanged = Time.now();
snprintf(attributes.attributeValue, largestAttributeValue, "%05d", recno);
EEPROM.put((recno * sizeof(attributes)) + dbOffset, attributes);
Serial.printf("\nRecord %d added", recno);
void selectAll()
Serial.print("\n#\tName\t\tUpdated\t\tValue");
EEPROM.get((recno * sizeof(attributes)) + dbOffset, attributes);
Serial.printf("\n%d\t%d\t\t%lu\t%s", recno, attributes.attributeNum, attributes.lastChanged, attributes.attributeValue);
Serial.begin(); // open serial over USB
while (!Serial.isConnected()) // wait for Host to open serial port
Particle.process();
Particle.publish("sysMsg", "EEPROM Test Started", PRIVATE);
static int iterationCount = 0;
eepromCreateDataTable();
selectAll();
Serial.printlnf("\n\n----------------------------\nIteration:%d\n----------------------------",
++iterationCount);
sprintf(buf,
"Iteration:%d",
++iterationCount);
Particle.publish("sysMsg", buf, PRIVATE);
delay(5000);
What version of Device OS do you have on the device and what version are you targeting for your app?
1.4.4 - 1.4.4 - using workbench, latest CLI
