I was looking at github and seen a few repos and noticed a convention that was a little confusing to me.
I noticed that most projects had a firmware folder. (“that made sense”) but where I got confused was the difference between what looks to be the main app meant to be compiled and an following example folder which looks to be competing with the main app.cpp file.
This is what I seen as convention.
firmware ¬
examples ¬
SomeExample.ino
SomeMainApp.cpp
SomeHeader.h
Whats confusing is why would I need an example if I have the SomeMainApp.cpp?
From what I can tell Both the SomeMainApp.ccp and the SomeExample.ino both #include SomeHeader.h but very greatly from each other in most cases.
The example looks to be more focused arround the spark/photon with a setup/loop method where I dont see that at all in the SomeMainApp.ccp. At the same time the example only looks to be using the header file.
I guess most the repos you looked at were library repos, where the main thing is the library and not the examples that just show how to use the library.
Header files are there to tell the compiler that there will be some implementation for the mentioned functions and stuff.
So when it compiles your code, which uses some of the external functions, the compiler will be happy, because he got told of their existance.
It will also compile the .CPP files he finds in the library folders.
When the compiler is done, the linker brings all the seperate parts togther (links them) and if all external references that the compiler willingly accepted can be matched to an implementation, the linker will be happy to. If not - not
That’s a very basic description how C programs are written and built - if you want more detail, there are loads of other resources on the web.
