# Programmer Shield debugging with Eclipse on 0.6.4 firmware
**URL:** <https://community.particle.io/t/programmer-shield-debugging-with-eclipse-on-0-6-4-firmware/41050>\
**Created:** [April 13, 2018, 7:45pm UTC](https://community.particle.io/t/programmer-shield-debugging-with-eclipse-on-0-6-4-firmware/41050 "2018-04-13T19:45:03Z")\
**Showing post:** 5
**Author:** ![itsmedavid](https://avatars.discourse-cdn.com/v4/letter/i/fbc32d/32.png) [@itsmedavid](https://community.particle.io/u/itsmedavid)\
**Post date:** [April 13, 2018, 10:45pm UTC](https://community.particle.io/t/programmer-shield-debugging-with-eclipse-on-0-6-4-firmware/41050/5 "2018-04-13T22:45:33Z")
The same error in the [link](https://community.particle.io/t/building-debug-builds-error-doc-topic-debugging-with-eclipse/31697) that I linked.
Building target: /home/user/Documents/Example/app/target/app.elf
Invoking: ARM GCC C++ Linker
mkdir -p /home/user/Documents/Example/app/target/
arm-none-eabi-g++ -DSTM32_DEVICE -DSTM32F2XX -DPLATFORM_THREADING=1 -DPLATFORM_ID=10 -DPLATFORM_NAME=electron -DUSBD_VID_SPARK=0x2B04 -DUSBD_PID_DFU=0xD00A -DUSBD_PID_CDC=0xC00A -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb -DINCLUDE_PLATFORM=1 -DPRODUCT_ID=10 -DPRODUCT_FIRMWARE_VERSION=65535 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DUSE_SWD_JTAG -DSYSTEM_VERSION_STRING=0.6.4 -DDEBUG_BUILD -Werror -I../user/inc -I../wiring/inc -I../hal/inc -I../hal/shared -I/rtos/FreeRTOSv8.2.2/FreeRTOS/Source/include -I/rtos/FreeRTOSv8.2.2/FreeRTOS/Source/portable/GCC/ARM_CM3 -I../hal/src/electron -I../hal/src/stm32f2xx -I../hal/src/stm32 -I../system/inc -I../services/inc -I../communication/src -I../platform/shared/inc -I../platform/MCU/STM32F2xx/STM32_USB_Host_Driver/inc -I../platform/MCU/STM32F2xx/STM32_USB_OTG_Driver/inc -I../platform/MCU/STM32F2xx/STM32_StdPeriph_Driver/inc -I../platform/MCU/STM32F2xx/STM32_USB_Device_Driver/inc -I../platform/MCU/STM32F2xx/SPARK_Firmware_Driver/inc -I../platform/MCU/shared/STM32/inc -I../platform/MCU/STM32F2xx/CMSIS/Include -I../platform/MCU/STM32F2xx/CMSIS/Device/ST/Include -I../dynalib/inc -I. -MD -MP -MF /home/user/Documents/Example/app/target/app.elf.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DMODULE_VERSION=0 -DMODULE_FUNCTION=3 -DMODULE_DEPENDENCY=0,0,0 -D_WINSOCK_H -D_GNU_SOURCE /home/user/Documents/Example/app/target/obj/./src/module_info.o /home/user/Documents/Example/app/target/obj/startup/startup_stm32f2xx.o --output /home/user/Documents/Example/app/target/app.elf -nostartfiles -Xlinker --gc-sections -L../build/arm/linker/stm32f2xx --specs=nano.specs --specs=../newlib_nano/src/custom-nano.specs -T../hal/src/electron/app_no_bootloader.ld -Wl,--defsym, __STACKSIZE__ =1400 -L../hal/src/electron -u _printf_float -Wl,-Map,/home/user/Documents/Example/app/target/app.map -u uxTopUsedPriority -L../build/target/user/platform-10/app/ -L../build/target/wiring/platform-10/ -L../build/target/system/platform-10/ -L../build/target/services/platform-10/ -L../build/target/communication/platform-10-prod-10/ -L../build/target/hal/platform-10/ -L../build/target/platform/platform-10/ -L../build/target/wiring_globals/platform-10/ -L../build/target/newlib_nano/platform-10 -L../build/arm/linker -Wl,--whole-archive -lnewlib_nano -luser -lwiring -lhal -lsystem -lservices -lcommunication -lplatform -lwiring_globals -Wl,--no-whole-archive
../build/target/system/platform-10//libsystem.a(system_network.o): In function `ManagedNetworkInterface::notify_can_shutdown()':
/home/user/Documents/Example/firmware/v0.6.4/system/src/system_network_internal.h:550: multiple definition of `HAL_NET_notify_can_shutdown'
../build/module.mk:222: recipe for target '/home/user/Documents/Example/app/target/app.elf' failed
../build/target/hal/platform-10//libhal.a(cellular_hal.o):/home/user/Documents/Example/firmware/v0.6.4/hal/src/electron/cellular_hal.cpp:41: first defined here
make[1]: Leaving directory '/home/user/Documents/Example/firmware/v0.6.4/main'
../build/target/system/platform-10//libsystem.a(system_network.o): In function `ManagedNetworkInterface::network_interface()':
Makefile:16: recipe for target 'target/Example.bin' failed
/home/user/Documents/Example/firmware/v0.6.4/system/../wiring/inc/spark_wiring_led.h:145: multiple definition of `HAL_NET_notify_connected'
../build/target/hal/platform-10//libhal.a(cellular_hal.o):/home/user/Documents/Example/firmware/v0.6.4/hal/src/electron/cellular_hal.cpp:20: first defined here
/home/user/Documents/Example/firmware/v0.6.4/system/../wiring/inc/spark_wiring_led.h:145: multiple definition of `HAL_NET_notify_dhcp'
/home/user/Documents/Example/firmware/v0.6.4/system/../wiring/inc/spark_wiring_led.h:145: multiple definition of `HAL_NET_notify_disconnected'
collect2: error: ld returned 1 exit status
make[1]: *** [/home/user/Documents/Example/app/target/app.elf] Error 1
make: *** [target/Example.bin] Error 2
Thanks for your help @rickkas7 .
_[View the full topic](https://community.particle.io/t/programmer-shield-debugging-with-eclipse-on-0-6-4-firmware/41050)._
