I have a problem with TCPclient, when i try to get some response from any server using an http method or tcp metho client.avaible() function show me 0 bytes to read.
I am using a simple method, where i send some data to server via client.println (data of server change by post) but it never sends me an http response like “201 http 1.1” …
float Ubidots::getValue(char* id) {
int i = 0;
while (!_client.connected() && i < 6) {
i++;
_client.connect("things.ubidots.com", 80);
if (_client.connected()) { // Connect to the server
#ifdef DEBUG_UBIDOTS
Serial.println("Client connected");
#endif
_client.flush();
_client.print("GET /api/v1.6/variables/");
_client.print(id);
_client.print("/values?token=");
_client.print(_token);
_client.println(" HTTP/1.1\nHost: things.ubidots.com\nConnection: close");
delay(1000);
Serial.println(_client.available());
while (_client.available()>0) {
char c = _client.read();
Serial.write(c);
#endif
and in the app I put this one:
#include "Ubidots.h"
#define TOKEN "CCN8F000lRYGulPTkbaiR9Myx8qN2o" // Put here your Ubidots TOKEN
#define DATA_SOURCE_TAG "3d0038000a51343334363138" // Put here your data source name
Ubidots ubidots(TOKEN);
Serial.begin(115200);
ubidots.getValue("571fc3e77625427c84f581b9");
delay(5000);
@Metavix, first I have to ask why you are not using the ubidot’s library getValueWithDatasource() function. Second, you will notice in the library how the char string allData is filled using sprintf(). This is used so that a single _client.print() can be used instead of several. The reason is that each _client.print() sends a single TCP packet. So in your case, many are sent which is most likely causing the problem.
Your HTTP request does not look well-formed to me. You need another trailing newline after final actual of a GET request. You don’t seem to have an Accept: header either which is sometimes required.
Yes, I doesn’t use a post there, but is the same with the post line, if i use:
ubidots.add();
ubidots.sendAll();
I post the value to ubidots i see that happend, but particle photon, or electron don’t get the package of respo nse.
I use a TELNET, to confirm if my message is good, or if it is a problem from ubidots, but in telnet all is ok. @bko it is ok i test it by a telnet
My problem is very strange because the last week the get method was ok, but this week all go down.
I know that because i create this library
Hi!, @Metavix, i’m experiencing the same issue, but using the ubidots library on a photon device … the library is extremely easy to use, so i’m worrying about myself … any clue to solve this problem? thanks
Explaining the actual problem you see rather than saying “the same issue” (which it won’t necessarily be, using an additional library) would be good.
Also have you tried to start with a running example and move on from that one?
After which addition did it start to play up?
How does your code look now?
That was quick
I’ve been testing a bit more, and have found, that the problem seems to be the “lack” of description what DataSourceName and DataSourceTag actually are and what you need to use with getValueWithDatasource()
I found when I use the tag rather than the name I can retrieve the variable (BTW: today is my first contact with Ubidots - specifically to answer your question)
So I tried this code
#include "Ubidots/Ubidots.h"
#define TOKEN "<<YourTokenHere>>"
#define DATA_SOURCE_NAME "Monitor"
#define DATA_SOURCE_TAG "Particle"
#define VAR_NAME "valor2"
ubidots.setDatasourceName(DATA_SOURCE_NAME);
ubidots.setDatasourceTag(DATA_SOURCE_TAG);
delay(1000);
ubidots.add(VAR_NAME, analogRead(A0)); // this would create a new data source with tag
ubidots.sendAll(); // if that combination didn't already exist
float value;
value = ubidots.getValueWithDatasource(DATA_SOURCE_TAG, VAR_NAME);
Serial.println(value);
delay(5000);
And it works. I can set the value and read it too.
Without setDatasourceName() your default data source will be called Particle and get an arbitrary tag (when adding variables).
Setting the the name and tag for your data source will save you some headache to guess the default values you’ll end up with.
Sorry @fbt because the old version of libraries has that problem, in the examples said that you needed to put the variable name, but it was false, you need to put there is the variable tag! then if your variable tag is null you could not to get the variable value, but you can add a tag via front end of Ubidots!
Hi @Metavix … thanks for the reply … could you please post a valid example for getting the value of variable “valor2” in the following scenario?. thanks
#define TOKEN "Your_Token_Here" // Put here your Ubidots TOKEN
#define DATA_SOURCE_TAG "Your_Data_Source_Tag" // Put here your data source name
float value;
value = ubidots.getValueWithDatasource("Particle", "Particle2");
delay(5000);
