Hello everybody i don´t understand why i can´t connect to my core… i have tried to connect i and it looks like it goes through the sequence correct. but after the LED have been breathing for a few sec it stops and just turns solid… i have tried to make a little video… can anybody help me fix it.
Video of my core
Thomas
ScruffR
December 18, 2016, 3:38pm
2
We’d need to see the code running on your Core too.
There is no code running on it… i just unboxed it and followed the instruction… i have written some code but haven’t been able to upload it yet…
it checks out in the IDE but i´m not able to upload…
const int VAL_PROBE = 0; //Analog pin 0
const int MOISTURE_LEVEL = 250; //Vaerdien hvorefter LED taender
void LedState(int state) {
digitalWrite(7, state);
int moisture = analogRead(VAL_PROBE);
Serial.println(moisture);
if(moisture >= MOISTURE_LEVEL) {
LedState(HIGH);
} else {
LedState(LOW);
delay(100);
ScruffR
December 18, 2016, 5:33pm
4
This is a white Core and you just unboxed it? You seem to be a patient man
In that case you might need to do some major updating first.
You’ll need to setup CLI and DFU drivers and perform
particle flash --usb cc3000
particle flash --usb deep_update_2014_06
particle flash --factory tinker
particle flash --usb tinker
Not patient just very very busy…
i will try that… thank you
