Hi All!!
I have had some problems when I am trying to send Data to Parse.
I already send and update data but only when I use numbers in a char[]
Something like this works perfectly.
char n1[40] = "20";
char n2[40] = "100";
sprintf(resultStr, "{\"n1\": %s, \"n2\": %s}", n1, n2);
But if i change, for example:
char n1[40] = "A";
I get a blank space on Parse, i don’t know why with letters it is not working.
I need the photonID and other parameters that use letters.
I tried using String and converting to char.
String id = "30032001047343432313031";
id.c_str()
And using sprintf again, but it’s the same i just get blank spaces.
And just with one parameter that contains a letter, although the other has numbers i get nothing.
Somebody with the same problem?
Let me know
Thanks in advance…
