When I connect with my computer, lights up for 2 seconds green , after lights up for 2 seconds cyan and then switches off for 2 minutes and the end is constantly red …
Which is the solution??
What is the code? What’s the hardware setup?
Just a little anecdotal video that may (exaggeratedly) illustrate the problem with above question
There are problems based on the color of led, finally the solution was to compile a new code …
