Powering Electron with and without LiPo
#16
I would be hesitant using that battery with a 2G Electron. 900mA definitely is insufficient for a 2G Electron, so you’ll be looking at the max. pulse current here. This number however can mean different things depending on the manufacturer of the battery; while some may supply it for a minute or more, with others it may only be for short pulses.
I would either:
(1) Use this battery with a 3G Electron
(2) Get a D-cell LiSOCl2 instead (mine have a continuous current of 2A)
(3) Reach out to Tekcell to make sure their battery would actually sufficiently support your setup
What other components do you have in your setup? Does anything else drain a lot of power?
#17
Yeah i have atleast one magnetic reed switch and possibly a 5v boosted 4-20mA current loop board (that can be switched off when not used) or some other sensor input.
The company also have this battery:
https://actec.dk/media/documents/F9089A4F5DA5.pdf
Which has a max continuous current of 1800mA. It is however not in stock atm… but with high current discharge capability and the TPS booster sucking the battery dry, this could be a very efficient possibility, right?
What if I put the other battery in parallel with another one, would this also double the continuous current max or is it only the capacity that doubles?
Thanks!
#18
A D-cell is definitely a good pick; usually the issue with them though are space constraints. I have only used the TPS Booster with a single LiSOCl2 D-cell so far, but it has been working great with one of my devices for the last 2 months now.
You can indeed put two C-cells in parallel and it will share the current between them, meaning they can support higher loads from your system.
A major warning I have to give here though is that you should never put these batteries in parallel with something that has a different chemistry, voltage rating and/or state of charge. LiSOCl2 are non-rechargeable,so you want to avoid them charging each other. The only safe way to do this is to put two identical brand-new cells together, and throw them out once you remove them.
#19
Warning is noted!
Do you think a single D-cell as referenced in my previus post can last a year with a magnetic reed switch and a 5v boosted 4-20mA current loop board? - Because that’s the goal I want to achieve.
The 4-20mA board is powered every hour for a quick log and the GSM module is only used once a day for sending up the logs of the day.
I could get a statisticly long battery life from testing with the 2000mAh LiPo that came with it (using the reed switch and current loop board) but a D-cell battery like the one i referenced with that capacity and low self-discharge gotta give a whole lot more running time, right?
#20
Capacity is going to depend on temperature and current drawn (which for you is pretty low). Assuming you’re using the battery at room temperature, you’re probably going to get about 7 times the lifespan out of this compared to your 2Ah LiPo.
How long it will exactly last is hard to say - the GSM module may be an important factor on it, depending on how good your signal is. You didn’t explicitly specify it, but if you’re keeping your Electron in Deep Sleep when it’s not sending a log, and your booster has something like an Enable pin, then you could potentially get a couple of years out of one D-cell
#21
Yes absolutly, the electron will be in deep sleep when not used and the booster is enabled/disabled aswell.
I will try out both solar panel and the D-cell, and see what runtime I can get.
Thanks!
#22
@RWB knows way more about this as he did a lot of work with solar panels, but be careful that you’re not going to accidentally recharge your LiSOCl2 with the solar panel in your setup. @RWB uses a solar panel to recharge his LiPo I believe, so there’s definitely a risk of recharging.
How do you plan to power your device? (i.e. what pins). Personally I use the JST connector, which would automatically recharge them if another power source is added (e.g. USB)
#23
I was planning on using JST connection alone when using the Li-SOCl2 battery for locations with no sunlight and using the JST (LiPo) + VIN (6W solar panel) for locations where sunlight is present.
I could potentially also use a powerbank (5v 2A) via USB together with the LiPo connected to JST in some cases.
I don’t think I can use USB and/or VIN together with Li-SOCl2 battery Connected to JST, as it uses these to recharge the LiPo battery like you said. Am I right in this?
#24
Yes, supplying power over USB/VIN would attempt to recharge whatever is connected to the JST socket if I’m not mistaken, because it was originally designed for a rechargeable LiPo.
#25
@Mic, You really should accurately measure your sleeping current. Anything else is just a wild guess.
Your firmware can handle limiting the time the Electron stays awake if for some reason it cant connect.
Your Sleeping Current will be the major factor to the battery life.
If you don’t have a way to accurately measure low currents, you can share your firmware code and possibly mail a sample of the reed switch and 4-20 board to someone that can.
I don’t own any 2G Electrons, otherwise I’d be happy to test a copy of your hardware & firmware setup for you.
Measuring the Sleep Current removes the guesswork for your Power Budget, for battery only and Solar/Battery systems…IMHO :grin:
#26
In order to get to the 110 uA to 130 uA deep sleep current you have to use Li+/JST. If you use VIN, the regulator needs to be turned on and you won’t get to that low of a sleep current.
However, if you attach a Li-SOCI2 (or other non-rechargeable) battery to Li+/JST make sure you turn off the charger. It can be done in software.
#27
This is correct.
It’s not documented, and I only found out after some testing.
Any idea what that Charger OFF command is? Just so we can refer others to this code as the question comes up now and then.
#28
So if I use the LiPo on JST and solar panel on VIN, i won’t get a good sleep current (100uA to 130uA)? - or is it only if I use the VIN alone?
And like @RWB said, how would one turn off the charger in software?
BTW, i just read that the spiral-type Li-SOCl2 battery has a higher self-discharge rate than a bobbin-type Li-SOCl2 battery. Is it substantial? I mean if it is around the same self-discharge rate as a LiPo’s 3% a month, it doesn’t really help my case :confused: Do you know if it is still much lower than the LiPo self-discharge rate, @Vitesze? Otherwise i will have to use the bobbin-type Li-SOCl2 battery with a supercapacitor in parallel, but i’m not really sure what Farad and other specs i should be looking for and it is pretty expensive compared to having just a LiPo or spiral-type Li-SOCl2.
Thanks!
#29
You can still charge the Electron by VIN with a LiPo battery connected and get low current in deep sleep. The problem is only if you use only VIN.
Here’s the code to disable charging:
void setCharging(bool enable) {
	PMIC pmic;
	// DisableCharging turns off charging.
	if (enable) {
		pmic.enableCharging();
	else {
		pmic.disableCharging();
	// Disabling the PMIC watchdog is necessary, otherwise it will kick in and turns
	// charging at random times, even when sleeping.
	// This disables both the watchdog and the charge safety timer in
	// Charge Termination/Timer Control Register REG05
	// pmic.disableWatchdog() disables the watchdog, but doesn't disable the
	// charge safety timer, so the red LED will start blinking slowly after
	// 1 hour if you don't do both.
	byte DATA = pmic.readChargeTermRegister();
	if (enable) {
		DATA |= 0b00111000;
	else {
		// 0b11001110 = disable watchdog
		// 0b11000110 = disable watchdog and charge safety timer
		DATA &= 0b11000110;
	// This would be easier if pmic.writeRegister wasn't private (or disable
	// charge safety timer had an exposed method
	Wire3.beginTransmission(PMIC_ADDRESS);
	Wire3.write(CHARGE_TIMER_CONTROL_REGISTER);
	Wire3.write(DATA);
	Wire3.endTransmission(true);
There are some more options here:
#30
It is a much lower self-discharge rate and why these batteries are good for this type of application if you can not solar recharge.
I don’t think using a Capicator + smaller Li-SOC battery that is not specd to handle the continuous discharge current of the Electron would support the Electrons load. The capacitor is good for a short burst of power but it will not help if the battery cannot support the higher load during a connection process that lasts 1-60 seconds or even longer during an extended connection process.
Use the larger batteries that @Vitesze have proven to work with the boost circuit and you will be good.
#31
No, the difference is very minor. LiSOCl2-cells have a self-discharge rate of about 1-2% per YEAR. The low self-discharge is the reason they are popular in applications that need battery-powered for a very long duration.
With a single spiral-type LiSOCl2 and efficient code you could power an Electron for a few years.
#32
Hi, Just for additional info, a small part of the 2G transmission cycle is what requires the 1800mA peak current. The transmit intervals are well documented and have a defined maximum duty cycle (it’s what makes that ticking sound you hear when a 2g phone is used near some audio equipment). You shouldn’t need a ‘supercapacitor’ - a good quality low-leakage electrolytic is likely to have lower ESR (ie. better peak current response). It should be quite simple to calculate the size based on duration of current pulse and acceptable voltage sag that the battery can top-up between tx pulses.
HTH
#33
For design parameters, Section 2.2 of the document “SARA-G3-U2_SysIntegrManual_(UBX-13000995).pdf” has sample designs for both LiPo and non-rechargeable battery options. The ‘tank’ capacitor needs to keep Vcc drop <400mV for a 1/8 duty cycle, with the battery able to provide average current during 2G GPRS (I think) operations.
The gist for capacitor size appears to be a 330uF tantalum with ESR <35mOhms, placed as close as possible to the modem module (or, in this case, the Electron board’s Li+). I’d increase the size to accommodate any concurrent activity in the uP and other devices on the Electron board (say 470uF tantalum). Going too large could be counter-productive, as the capacitor has to recover through its ESR, as well as discharge. Also tantalum caps don’t tend to come in large capacities, but have very low ESR making them preferable for this function. Also more electrically stable over their lifetime, if my memory serves.
The manual is downloadable from ublox web-site.
HTH.
[Edited: Vin to Li+]
#34
Good information!
Would this be a good solution?:
The TPS would take care of the voltage drop after long usage and the capacitor would take the quick peak current pulses and also help with the battery voltage drop, right? Or could I completely discard the TPS?
#35
In my opinion, for a 3.7V LiSOCl2, with its rapid voltage drop when exhausted (per the battery datasheet), I’d skip the booster circuit. I’d surmise the additional run-time gained is going to be quite small. From the battery datasheet, the peak current is measured over 100mS with a 2 minute recovery. The modem is going to consume peak current for about 2.3mS every 4.6mS in worst case 2G GPRS modes (at max power and worst antenna matching). So, the average current is roughly half the peak. If the battery can maintain 1A continuous, that should be enough.
I took a squiz at the Electron doc/schematic. The ublox modem is normally powered via the PMIC output (3V8 line), and has a 200uF cap. close to its Vcc.
In this case, you will need to directly connect to the Li+/Gnd, or JST battery socket, as the PMIC expects a minimum of 3.9V on VIN. The PMIC won’t be doing much, but it won’t charge the battery as there is no VIN (as long as you don’t connect both battery and USB at the same time!). You can, as Rick K mentioned above, disable the PMIC charging functions to be completely safe.
So, this is (almost) a direct connection from battery to the modem and its existing 200uF ‘tank’ capacitor. I’d say that you would be fine with just that battery and a 330uF tantalum in parallel, the latter as close to the Electron’s Li+ and Gnd as possible.
Note that the PMIC can disconnect the battery when it drops below 3.0V (adjustable) - but this is also the minimum operating voltage of the modem, anyway.
