Pow function returns always 0
#1
Hi,
I have the following code:
(I want to convert dB’s into watt)
double CalculateWatt(float db)
double res = 0;
res = pow(10,db);
return res;
this function always return 0 !
this doesn’t seem normal to me.
I already included math.h
what else can I do?
#2
changed it into:
double res = 0;
res = pow(10,(db/10))/1000;
return res;
now it is working…
had propably an overflow…
#3
What values were you passing as db?
With this code I can’t reproduce your issue trying 0.1, 1.2, 12.3 and even 123.456.
1234.56 returns inf but not 0.
#include <math.h>
  double res = 0.0;
  res = pow(10, db);
  return res;
    Particle.function("set", set);
int set(const char* cmd) {
    double x = atof(cmd);
    Serial.printlnf("%f", CalculateWatt(x));
    return x;
