If only there was a way in which you could take an image of your screen and share that…
Since there evidently is not, and we have no idea what commands you’ve used, nor are we able to see the full output, there’s little we can say I’m afraid.
I think the device may not have been in the correct mode (since you say it was still doing it’s thing, which it should not, depending on the mode you’re in), but that’s hard to tell.
