I tried to hook up external power to an RGB LED strip that I had running off a Spark Core to make it brighter and I think I fried my board. Now the onboard LED won’t turn on and it just gets warm.
Any ideas on a resolution other than buying a new one? It was a pretty dumb thing to do in retrospect…
Could you tell us the exact set-up, and the things you’ve done? If you’re lucky, you’ve ‘only’ killed the voltage regulator and perhaps some pins, and there might be a way to salvage some.
Unfortunately, this is comparable to trying to un-crash a car. You might be able to fix some of the issues, but you’re likely to have some permanent damage.
Anyhow, let us know, perhaps it can still be (partially) saved.
