Continuing the discussion from Toolchain Installer / Helper for Linux and OSX (I can't edit the post for some reason...)
Particle Offline Utility:
A handy script for installing and using the Particle Toolchain on Ubuntu-based distros and OSX.
This script downloads and installs: dfu-util, nodejs, gcc-arm-embedded, particle-cli, and the Particle Firmware source code.
# Quick Install / Update
curl po-util.com/download | bash
Copy and paste this into your terminal.
See 2.0 instructions in a post below.
Info
po-util Copyright (GPL) 2016 Nathan Robinson
This program comes with ABSOLUTELY NO WARRANTY.
Read more at http://bit.ly/po-util
Usage: po DEVICE_TYPE COMMAND DEVICE_NAME
po DFU_COMMAND
po install [full_install_path]
Commands:
install Download all of the tools needed for development.
Requires sudo. You can optionally install to an
alternate location by specifying [full_install_path].
Ex.:
po install ~/particle
By default, Firmware is installed in ~/github.
build Compile code in "firmware" subdirectory
flash Compile code and flash to device using dfu-util
clean Refresh all code
init Initialize a new po-util project
patch Apply system firmware patch to change baud rate
update Download latest firmware source code from Particle
upgrade Upgrade system firmware on device
ota Upload code Over The Air using particle-cli
serial Monitor a device's serial output (Close with CRTL-A +D)
DFU Commands:
dfu Quickly flash pre-compiled code
dfu-open Put device into DFU mode
dfu-close Get device out of DFU mode
Tips
The three most useful commands are build
, flash
and clean
. Build compiles code in a "firmware"
subdirectory and saves it as a .bin
file in a "bin"
subdirectory. Flash does the same, but uploads the compiled .bin
to your device using dfu-util. Clean refreshes the Particle firmware source code.
A po-util project must be arranged like so:
po-util_project/
â”” firmware/
â”” main.cpp
â”” lib.cpp
â”” lib.h
Since po-util compiles .cpp
and not .ino
files, #include "application.h"
must be present in your main.cpp
file.
A blank main.cpp
would look like:
One of the features of po-util is that it changes the baud rate to trigger dfu mode on Particle devices from 14400
to 19200
. The reason for this is because Linux can not easily use 14400 as a baud rate. To enable this feature, connect your device and put it into DFU mode, and type:
po DEVICE_TYPE patch
# Replace DEVICE_TYPE with either "photon" or "electron"
Your computer will then recompile both parts of the Particle system firmware and flash each part to your device using dfu-util.
Why I created this script
I created this script because Particle does not currently have a script for easily installing the Particle Toolchain and depedencies on Linux and OSX. I created this script in order to help out other Particle users and to improve my bash scripting skills. It would be my dream come true if Particle added this script to its resources or gave it a shout out in its documentation. If that happened, I would feel very proud of myself for making a meaningful contribution.
Read more at po-util.com
