Has anyone been able to share wifi with a Particle device over ethernet - specifically Xenon + Ethernet shield?
Setup
- Raspberry Pi 3 connected to internet over wifi
- Particle Xenon + Ethernet shield connected to Pi over ethernet
Issue
I am trying with the following script, but it only keeps flashing one of the following
- Cyan - where it is trying to connect but never does
- Orange (red/yellow) - where it hits an error in the connection
It seems like it should be possible, right?
Code
#!/bin/bash
# Share Wifi with Eth device
# This script is created to work with Raspbian Stretch
# but it can be used with most of the distributions
# by making few changes.
# Make sure you have already installed `dnsmasq`
# Please modify the variables according to your need
# Don't forget to change the name of network interface
# Check them with `ifconfig`
ip_address="192.168.2.1"
netmask="255.255.255.0"
dhcp_range_start="192.168.2.2"
dhcp_range_end="192.168.2.100"
dhcp_time="12h"
eth="eth0"
wlan="wlan0"
sudo systemctl start network-online.target &> /dev/null
sudo iptables -F
sudo iptables -t nat -F
sudo iptables -t nat -A POSTROUTING -o $wlan -j MASQUERADE
sudo iptables -A FORWARD -i $wlan -o $eth -m state --state RELATED,ESTABLISHED -j ACCEPT
sudo iptables -A FORWARD -i $eth -o $wlan -j ACCEPT
sudo sh -c "echo 1 > /proc/sys/net/ipv4/ip_forward"
sudo ifconfig $eth $ip_address netmask $netmask
# Remove default route created by dhcpcd
sudo ip route del 0/0 dev $eth &> /dev/null
sudo systemctl stop dnsmasq
sudo rm -rf /etc/dnsmasq.d/* &> /dev/null
echo -e "interface=$eth\n\
bind-interfaces\n\
server=8.8.8.8\n\
domain-needed\n\
bogus-priv\n\
dhcp-range=$dhcp_range_start,$dhcp_range_end,$dhcp_time" > /tmp/custom-dnsmasq.conf
sudo cp /tmp/custom-dnsmasq.conf /etc/dnsmasq.d/custom-dnsmasq.conf
sudo systemctl start dnsmasq
