I have two photons both of which behave the same way. Connecting them via USB to my MacBook Pro and trying to set them up via USB or Wifi does not work.
With USB, the device simply does not show up in the list of connected USB devices.
No devices detected via USB.
With Wifi, I get the following:
? Would you like to scan for nearby Photons in Wi-Fi setup mode? Yes
? Found "Photon-FCUU". Would you like to perform setup on this one now? Yes
[Error: Unable to obtain claim code]
! PROTIP: We need an active internet connection to successfully complete setup.
! PROTIP: Are you currently connected to the internet? Please double-check and try again.
Now a third Photon works fine. Help!
A.J.
