Just to add to this topic, I had the exact same issue as everyone here. iPhone app, CLI serial, and CLI wifi all failed with “invalid claim code.” Finally I tried the “particle serial wifi” method explained here, and my Photon connected, rebooted, flashed, rebooted, and then just connected and apparently claimed itself for me using my CLI credentials.
This is definitely an issue with a number of photons and is creating a lot of headaches for people, especially those who don’t have time to jump through setup hoops.
Just received 10 photons and keen to get the first one connected - now seeing the same problem as others. When I tried the IOS app, it fails at the last step (Verify device ownership) and a retry does not work as the Photon’s network does not appear in the list of networks on my phone. I have to reboot the device, but the same issues appears (fails to verify).
I then tried the CLI and get this message:
Photon team - I know a serious amount of effort has gone into the Photon and I am willing this to work. I can see that by using low level commands, some of these cores do start to connect, but this is far from ideal. Can we have a response as to what is being done to identify how big an issue this is and what we can do collectively to resolve this?
From the App
The app requires login, so this was the case with the app attempt. My machine is connected to the internet (same machine I am emailing from).
From CLI
When I ran 'particle setup' it confirmed I was already logged in. I have also tried logging into my second account and I get the same response. The photon is flashing blue. I am seeing an error:
Setup is easy! Let's get started...
It appears as though you are already logged in as xxxx@xx.xx
? Would you like to log in with a different account? No
! PROTIP: Hold the MODE/SETUP button on your device until it blinks blue!
! PROTIP: Please make sure you are connected to the internet.
I have detected a Photon connected via USB.
? Would you like to continue with this one? Yes
! The Photon supports secure Wi-Fi setup. We'll try that first.
! PROTIP: Wireless setup of Photons works like a wizard!
! PROTIP: We will automagically change the Wi-Fi network to which your computer is connected.
! PROTIP: You may lose your connection to the internet for a moment.
Potentially unhandled rejection [2] Unable to find mac address in response (WARNING: non-Error used)
? Found "Photon-TQJL". Would you like to perform setup on this one now? Yes
! PROTIP: You will need to know the password for your Wi-Fi network (if any) to proceed.
! PROTIP: You can press ctrl + C to quit setup at any time.
! Woops. Something went wrong connecting to Photon-TQJL. Please manually re-connect to your Wi-Fi network.
Although I know my machine is connected to wifi, I disconnected and reconnected. I get the same result, but I no longer get the error message (unhandled rejection [2])
Response when I try to save the core id (id obfuscated):
Thanks! Wait while I save those credentials…
Done! Your device should now restart.
iMac002:natter kevinhankinson$ particle device add 19002xxxxxxxx343337373xxx
Claiming device 19002xxxxxx343337373xxx
Failed to claim device, server said { ok: false, errors: [ ‘device does not exist’ ] }
iMac002:Spark kevinhankinson$ dfu-util -d 2b04:d006 -a 1 -s 2082 -D cloud_public.der
dfu-util 0.8
dfu-util: Invalid DFU suffix signature
dfu-util: A valid DFU suffix will be required in a future dfu-util release!!!
Deducing device DFU version from functional descriptor length
Opening DFU capable USB device...
ID 2b04:d006
Claiming USB DFU Interface...
Setting Alternate Setting #1 ...
Determining device status: state = dfuIDLE, status = 0
dfuIDLE, continuing
DFU mode device DFU version 011a
Device returned transfer size 4096
DfuSe interface name: "DCT Flash "
Downloading to address = 0x00000822, size = 402
Download [=========================] 100% 402 bytes
Download done.
File downloaded successfully
On reboot - now flashing cyan (no red). I have attempted to run 'particle device add' and it failed.
This can also happen if your behind a firewall. Can you open up a terminal/command line and issue the following command: telnet device.spark.io 5683 or telnet device.particle.io 5683. If you get lots of gibberish text back then your firewall isn’t the problem
