I have a Photon running in SEMI_AUTOMATIC mode with SYSTEM_THREAD(ENABLED).
My program uses 4 Particle variables and 3 Particle functions that are in setup() as a nice short listing of these 7 items.
However in the Particle Console it only shows the first item of this list!
When I run the program in AUTOMATIC mode (but with SYSTEM_THREAD(ENABLED)), the console shows crrectly all 7 items.
I’ve found out that it is obviously important where in setup() you put these function- and variable-definitions: when you start setup() with first the functions and variables and then all other setup stuff, it all goes well.
Is this normal behaviour of the Photon, and if so: is this documented somewhere?
