I’m using a photon w/ relay shield with 5 capacitive moisture sensors.
I’m trying to publish the sensor values, which can later be taken to IFTTT for push notifications.
However, I am only receiving 4 sensor values, on the web ide events page. The 5th sensor (sensorvalue4) is not getting uploaded.
Am I trying to push too much data at once? Please help.
Thanks in advance,
Tom
#define THRESHOLD 2200
#define SENSOR_PIN0 A0
#define SENSOR_PIN1 A1
#define SENSOR_PIN2 A2
#define SENSOR_PIN3 A3
#define SENSOR_PIN4 A4
#define TEXTING_INTERVAL 1800000 //30 minutes (1000ms * 60s * 30mins)
int sensorvalue0 = 0;
int sensorvalue1 = 0;
int sensorvalue2 = 0;
int sensorvalue3 = 0;
int sensorvalue4 = 0;
unsigned long lastTextTime = 0;
unsigned long previousMillis = 0;
pinMode(SENSOR_PIN0, INPUT);
pinMode(SENSOR_PIN1, INPUT);
pinMode(SENSOR_PIN2, INPUT);
pinMode(SENSOR_PIN3, INPUT);
pinMode(SENSOR_PIN4, INPUT);
Particle.variable("sensor0", sensorvalue0);
Particle.variable("sensor1", sensorvalue1);
Particle.variable("sensor2", sensorvalue2);
Particle.variable("sensor3", sensorvalue3);
Particle.variable("sensor4", sensorvalue4);
unsigned long currentMillis = millis();
if((currentMillis - previousMillis) >= 5000) {
previousMillis = currentMillis; // Remember the time
sensorvalue0 = analogRead(SENSOR_PIN0);
sensorvalue1 = analogRead(SENSOR_PIN1);
sensorvalue2 = analogRead(SENSOR_PIN2);
sensorvalue3 = analogRead(SENSOR_PIN3);
sensorvalue4 = analogRead(SENSOR_PIN4);
if (sensorvalue0 > THRESHOLD) {
Particle.publish("0 Water Me Now!", String( sensorvalue0));
else {
Particle.publish("0Adequate soil moisture", String( sensorvalue0));
if (sensorvalue1 > THRESHOLD) {
Particle.publish("1Water Me Now!", String( sensorvalue1));
else {
Particle.publish("1Adequate soil moisture", String( sensorvalue1));
if (sensorvalue2 > THRESHOLD) {
Particle.publish("2Water Me Now!", String( sensorvalue2));
else {
Particle.publish("2Adequate soil moisture", String( sensorvalue2));
if (sensorvalue3 > THRESHOLD) {
Particle.publish("3Water Me Now!", String( sensorvalue3));
else {
Particle.publish("3Adequate soil moisture", String( sensorvalue3));
if (sensorvalue4 > THRESHOLD) {
Particle.publish("4Water Me Now!", String( sensorvalue4));
else {
Particle.publish("4Adequate soil moisture", String( sensorvalue4));
