This is something I have experienced multiple times before - photons light control is no longer working (The LED is a static cyan or not on at all) and the user application is not executing nor is there any cloud connection with the device.
Debug information from JTAG:
#0 xQueueGenericReceive (xQueue=0x856f78f8, pvBuffer=pvBuffer@entry=0x0, xTicksToWait=xTicksToWait@entry=1, xJustPeeking=xJustPeeking@entry=0) at WICED/RTOS/FreeRTOS/ver7.5.2/Source/queue.c:1165
#1 0x0803138e in sys_sem_new (sem=sem@entry=0x20005bdc <memp_memory_NETCONN_base+828>, count=count@entry=0 '\000') at WICED/network/LwIP/WWD/FreeRTOS/sys_arch.c:239
#2 0x080267e2 in netconn_alloc (t=<optimized out>, callback=callback@entry=0x0) at WICED/network/LwIP/ver1.4.0.rc1/src/api/api_msg.c:598
#3 0x08025eac in netconn_new_with_proto_and_callback (t=t@entry=NETCONN_TCP, proto=proto@entry=0 '\000', callback=callback@entry=0x0) at WICED/network/LwIP/ver1.4.0.rc1/src/api/api_lib.c:73
#4 0x0802d822 in wiced_tcp_create_socket (socket=0x0, interface=<optimized out>) at WICED/network/LwIP/WICED/tcpip.c:295
#5 0x080401ac in socket_create (family=<optimized out>, type=<optimized out>, protocol=<optimized out>, port=<optimized out>, nif=0) at src/photon/socket_hal.cpp:960
#6 0x0804597c in Spark_Connect () at src/system_cloud_internal.cpp:856
#7 0x08044f14 in establish_cloud_connection () at src/system_task.cpp:215
#8 0x08045174 in manage_cloud_connection (force_events=<optimized out>) at src/system_task.cpp:302
#9 0x080451ae in Spark_Idle_Events (force_events=<optimized out>) at src/system_task.cpp:335
#10 0x08044000 in ActiveObjectBase::run (this=0x200096b8 <SystemThread>) at src/active_object.cpp:49
#11 0x08044020 in ActiveObjectBase::run_active_object (object=<optimized out>) at src/active_object.cpp:92
#12 0x08043968 in std::invoke_thread (ptr=0x2000c498) at src/system_threading.cpp:85
#13 0x00000000 in ?? ()
(gdb) fin
Run till exit from #0 xQueueGenericReceive (xQueue=0x856f78f8, pvBuffer=pvBuffer@entry=0x0, xTicksToWait=xTicksToWait@entry=1, xJustPeeking=xJustPeeking@entry=0) at WICED/RTOS/FreeRTOS/ver7.5.2/Source/queue.c:1165
Any ideas on what could possibly cause this?
