Hello there! I use a1.8 "TFT 128x160 SPI display along with 4 PT100 temperature converters (SPI breakout boards with a MAX31865 chip). I managed to use the 4 breakout boards on the same SPI bus (with different Chipselectpins of course). The photon runs stable for at least 10 h and printing temperature to the serial port every second.
For the display i use the Adafruit_ST7735 and Adafruit_mfGFX libraries.
When I add the display code to also display temperature on the screen then it runs a few minutes and then suddenly the display freezes and the photon is stuck (no more readings to serial output).
I have another device without extra sensors (so just the display) and that works stable. So I guess it has something to do with the two types of devices on the same SPI bus. But I’m not sure where to debug or what tests to do find the cause.
Anyone an idea or hint how to proceed?
