Is there a difference between Core and Photon color sequences?
I have at powerup -> solid white, flashing green, flashing cyan, rapid flashing cyan, single red flash, rapid flashing cyan, single red flash then flashing cyan…
i finally got my balancing bot balancing and then the wheels flogged out so i had to print new ones… and now they are ready the photon doesn’t want to play
edit: so i since discovered its bad keys… i followed the steps here, it said success but still has the same sequence
Photon not flashing correctly, or always flashing with tinker
