Photon Blinks White Problem
I’m brand new to using the Photon. I got it installed properly and everything worked fine with Tinker. The next time I applied power to it, the LED blinked white. I understand that the flashing white LED means the Photon is not connected to the Wi-Fi. How do I reconnect it and how can I keep it connected?
Thanks.
Jim
Hi @jrybak,
I’m not sure if you flashed an app to it using manual mode, but if you did, you can get back online by going into safe mode:
https://docs.particle.io/guide/getting-started/modes/photon/#safe-mode
If not please let us know and we’ll try to help troubleshoot the issue. :slight_smile:
David
