hi i have asking for some help some days ago and i have working with some already done code,
you can see the original code here
AGAIN NOT MY CODE I ONLY EDITED, DONT WANT CREDITS
NOTE: you can control from several Computers.
So, in my photon the code i used was on the link on the top but its only for 1 servo, but i need 3 servos, so i edited and see the result:
// PARTICLE DONT NEED #INCLUUDE <servo.h>
Servo serv;
Servo serv1;
Servo serv2;
int pos = 0;
int pos1 = 0;
int pos2=0;
serv.attach(D2);
Spark.function("setpos", setPos);
Spark.variable("getpos", &pos, INT);
serv1.attach(D0);
Spark.function("setpos1", setPos1);
Spark.variable("getpos1", &pos1, INT);
serv2.attach(D3);
Spark.function("setpos2", setPos2);
Spark.variable("getpos2", &pos2, INT);
int setPos(String pstn) {
pos = pstn.toInt();
serv.write(pos);
return pos;
int setPos1(String pstn1) {
pos1 = pstn1.toInt();
serv1.write(pos1);
return pos1;
int setPos2(String pstn2) {
pos2 = pstn2.toInt();
serv2.write(pos2);
return pos2;
and the HTML will look like this:
<html>
<head>
<style>
body {
margin: 1em auto;
max-width: 45em;
padding: 0.8em;
background: white;
</style>
</head>
<body>
<h1>Braço Esquerdo</h1>
<input type="range" min="0" max="180" value="0" onchange="showValue(this.value)"/>
<span id="range">0</span>
<script type="text/javascript">
function showValue(newValue) {
document.getElementById("range").innerHTML=newValue;
var request = new XMLHttpRequest();
var dev_id = 'YOUR ID';
var access = 'YOUR TOKEN';
var data = 'params='+newValue+'&access_token='+access;
var url = 'https://api.particle.io/v1/devices/'+dev_id+'/setpos/';
request.open('POST', url, true);
request.setRequestHeader('Content-Type', 'application/x-www-form-urlencoded; charset=UTF-8');
request.send(data);
</script>
<h1>Braço Direito</h1>
<input type="range" min="0" max="180" value="0" onchange="showValue1(this.value)"/>
<span id="range1">0</span>
function showValue1(newValue2) {
document.getElementById("range1").innerHTML=newValue2;
var request1 = new XMLHttpRequest();
var dev_id1 = 'YOUR ID';
var access1 = 'YOUR TOKEN';
var data1 = 'params='+newValue2+'&access_token='+access1;
var url1 = 'https://api.particle.io/v1/devices/'+dev_id1+'/setpos1/';
request1.open('POST', url1, true);
request1.setRequestHeader('Content-Type', 'application/x-www-form-urlencoded; charset=UTF-8');
request1.send(data1);
</script>
<h1>Tronco</h1>
<input type="range" min="0" max="180" value="0" onchange="showValue2(this.value)"/>
<span id="range2">0</span>
function showValue2(newValue3) {
document.getElementById("range2").innerHTML=newValue3;
var request2 = new XMLHttpRequest();
var dev_id2 = 'YOUR ID';
var access2 = 'YOUR TOKEN';
var data2 = 'params='+newValue3+'&access_token='+access2;
var url2 = 'https://api.particle.io/v1/devices/'+dev_id2+'/setpos2/';
request2.open('POST', url2, true);
request2.setRequestHeader('Content-Type', 'application/x-www-form-urlencoded; charset=UTF-8');
request2.send(data2);
</script>
</body>
</html>
this have taken me 4 hours to do it and now i have shared to you, make a good use of it. and thanks the developer on HERE
