Hey community!
can we force the Photon 2 to use only 5GHz Wi-Fi?
I have an installation with the same SSID/passwd on 2.4GHz and 5GHz and I suspect the 2.4GHz is weak around the device, but the 5GHz looks better.
I would like to force this device to connect via 5GHz.
Is this possible?
Thank you,
