Is anyone using webhooks to feed data to sparkfun’s free phant service and willing to share an example ?
@AndyW i did a simple test and this works:
"eventName": "phantme_",
"url": "http://data.sparkfun.com/input/PASTE_PUBLIC_KEY_HERE",
"requestType": "GET",
"query": {
"private_key": "PASTE_PRIVATE_KEY_HERE",
"temp": "30.1",
"humidity": "86.10"
"noDefaults": true,
"mydevices": true
The issue is i’m wondering how are you going to update multiple values using the webhook…
There seems to be a phant library that might work better for multi variable logging though
I saw the phant library that makes direct http connections from the device to the service, I didn’t see any recent updates. However, I would prefer to use the particle ecosystem if I can.
One variable logging sounds fine but you will quickly hit into rate limiting with a regularly called webhook
If I’m attempting to do something of the order of between 1 and 8 metrics every 5 minutes, I do not see why anyone would rate cap me.
