Help!
While __SPISettings creates a way to pass an SPI channel structure to a class I cannot find how to pass a Wire (I2C) channel to a class. I am using two I2C channels and need to pass the channel number/structure to the class. Something like __SPISettings would be great.
What do you mean with I2C channel?
If you refer to the slave ID then you will pass that in the Wire.beginTransmission()
call.
If you refert to the I2C interface object (Wire
vs. Wire1
) you need to do that via a “placeholder” variable (for that case that’d be the same for SPI
vs. SPI1
Thanks for your reply. I want to pass Wire or Wire1 to a class or sub-class as a parameter when initialized. Ideal would be with something like __SPISettings.
I’m pretty certain SPISettings
doesn’t do that either.
SPISettings()
are to be used with a SPI.beginTransaction()
or SPI1.beginTransaction()
call respectively. There is no way to pass in which SPI interface object you intend to “tie” it to.
Can you provide a link where this “feature” would be suggested to exist?
However, as I said, you can make the interface selection dynamic.
e.g. like this
void someWireCall(TwoWire& wire) {
wire.beginTransmission(id);
wire.write(0xFF);
wire.endTransmission();
someWireCall(Wire);
someWireCall(Wire1);
Thanks again for your reply.
Yes it works great. The __SPI Setting is a struct which holds the variable data to configure an SPI channel. You define the struct then you can pass the pointer to the struct when you instigate a class giving that instance the correct configuration for that SPI channel. For example, create the struct:
__SPISettings spi_sd(30* MHZ, MSBFIRST, SPI_MODE0); // create the SPISetting for the SD card, 35Mhz MAX
then pass it:
SdCardPrintHandler SdPrintToCard(sd, SD_cs_pin, spi_sd); // enable printf to SD log.
If you have another way to accomplish what I need I am all ears. I have several I2C classes which are inherited by layers of classes adding methods. I want to reuse the class changing the I2C channel when instantiated.
Exactly what I'm saying. Via SPISettings
you are not passing anything containing a reference to SPI
or SPI1
but only some information about how you want to set the interface.
In your call above the sd
parameter is the reference to which SPI interface you want these settings applied to.
So again, as you would pass SPI
or SPI1
into the function via sp
(not spi_sd
) you'd pass Wire
or Wire1
into the function the way I already outlined above (by use of a reference parameter of type TwoWire&
- also works for classes / alternatively you could use a pointer
TwoWire* wire
and then in your classes use wire->write()
Which other settings pertaining to Wire
or Wire1
would you want to pass?
Via a WireTransmission
object you can pass some settings like the slave ID, timeout and stop flag. You cannot change the bus speed or enable/disable clock stretching between clients that way tho'.
Got it, you are right. I misunderstood this. I see what you are saying and I am going back to implement this in my code. Thanks.
More confusion. I cannot see how I pass the TwoWire &wire to a class. What am I missing?
If you show what you tried and how we may be able to see the issue
Thanks again for your help with this.
I have multiple instances of the oxygen cell class which have alternate inherited classes based in the driver method. The issue I have is when the oxygen class inherits an I2C class. I need to pass either Wire or Wire1 and the I2C address to the I2C (INA) class. I do not understand how to get the Wire or Wire1 to the INA class.
For example, in the task I create the objects:
O2CELL Cell1 (size, 2100, 0x40, Wire);
O2CELL Cell2 (size, 2100, 0x41, Wire1);
In the I2C driver class I have:
class INA{
public:
INA(int addr, TwoWire& wire);
private:
TwoWire *wire;
int _addr;
INA::INA(int addr, TwoWire& wire)
_addr = addr;
Then methods like this:
void INA::begin(void)
if (!wire->isEnabled()) { wire->begin(); }
In the oxygen cell class:
#include "INA.h"
class O2CELL : public INA{
public:
O2CELL(int size, int seed, int addr, TwoWire& wire);
O2CELL::O2CELL(int size, int seed, int addr, TwoWire& wire)
_size = size;
_seed = seed:
When you are using a reference (TwoWire& wire
) you would use it as wire.begin()
References are not pointers but just another "name" for the original entity.
This syntax wire->begin()
would require _wire
to be a pointer (i.e. TwoWire *_wire
) any you'd need to assign the pointer as this._wire = &wire
(have the member variable _wire
point to the address of the parameter reference wire
). To keep things clear it's good practice to use distinct names for parameters and member variables.
However, when you are using a reference variable in a class you'd need to initialize it via the construction initialization list.
class INA {
public:
INA(TwoWire& wire, uint8_t addr) : _wire(wire), _addr(addr) { };
private:
TwoWire& _wire;
uint8_t _addr;
Derived classes can call the base constructor like this
class O2CELL : public INA {
public:
O2CELL(TwoWire& wire, uint8_t addr, int size, int seed)
: INA(wire, addr), _size(size), _seed(seed) { };
