(This might end up being more of an HTML question since I’m not an expert in web stuff, but here goes…)
I followed the REST API example for LEDs in the docs and I was able blink LEDs from an HTML form. Looking at the code, it seems that only a single value is passed through “args”: “on” or “off”. I’d now like to pass multiple arguments.
I modified the code to have 2 radio buttons (“left” and “right”), a text field (“steps”), and a submit button as follows:
<!DOCTYPE html>
<html>
<body>
<center>
<form action="https://api.particle.io/v1/devices/abc/turn?access_token=xyz" method="POST">
<fieldset>
<legend>Motor Calibration</legend>
<br>
<input type="radio" name="direction" value="left">Turn left
<br>
<input type="radio" name="direction" value="right">Turn right
<br>
Number of steps:<br>
<input type="text" name="steps">
<br>
<input type="submit" value="Do it!">
</fieldset>
</form>
</center>
</body>
</html>
On the Photon I put a serial print in turn() that simply prints out the String argument. I’m listening to it over serial on a host machine.
What I observe is that only the first argument, “left”/“right” or “steps”, is passed to turn(), but not both. For example: if I check “Turn left” and hit submit, turn() gets “left”. If I enter “123” in the text box and hit submit, turn() gets “123”. But if I do both and then hit submit, turn() gets only “left”.
Is there a way to pass both arguments at once, or do I have to concatenate them into a string on the HTML page? If I need to do the latter, can someone please point me to a tutorial/example ?
