A new Release Candidate Device OS v1.2.0-rc.1 is available now on https://build.particle.io for Core/Photon/P1/Electron/Argon/Boron/Xenon/A SoM/B SoM/X SoM.
1.2.0-rc.1
Note: If your Gen 3 device does not have a Cloud connection, it is recommended to update system firmware, and then the bootloader via CLI with particle flash --serial bootloader.bin (bootloaders found in Github release)
This release contains v302 bootloaders (bumped this release due to Gen 3 changes in #1777 ). We have also separated BOOTLOADER_DEPENDENCY for Gen 2 and Gen 3. For now, we will leave Gen 2 as is depending on v201 bootloader (so there is nothing to do for Gen 2 (Photon/P1 only) unless you want the latest bootloader, although it is not mandatory), but we have bumped Gen 3 to v302 because also in this release we have removed the embedded bootloaders from Gen 3 system firmware. To force the Cloud update for Gen 2 (Photon/P1 only) we will bump the bootloader dependency version to v302 in v1.2.0 default.
A new Release Candidate Device OS v1.2.1-rc.1 is available now on https://build.particle.io for Core/Photon/P1/Electron/Argon/Boron/Xenon/A SoM/B SoM/X SoM.
1.2.1-rc.1
Note: This is primarily a Manufacturing release for Gen 3 devices with no significant feature/enhancement/bugfixes. Your testing is appreciated though. If you find any issues, please report them, and fallback to 1.2.0-rc.1 or 1.1.0.
This release contains v310 bootloaders (bumped this release due to Gen 3 changes in #1768 ). We have also separated BOOTLOADER_DEPENDENCY for Gen 2 and Gen 3. For now, we will leave Gen 2 as is depending on v201 bootloader (so there is nothing to do for Gen 2 (Photon/P1 only) unless you want the latest bootloader, although it is not mandatory), but we have bumped Gen 3 to v302 because also in this release we have removed the embedded bootloaders from Gen 3 system firmware. To force the Cloud update for Gen 2 (Photon/P1 only) we will bump the bootloader dependency version to v302 in v1.2.0 default.
A new Release Candidate Device OS v1.2.1-rc.2 is available now on https://build.particle.io for Core/Photon/P1/Electron/Argon/Boron/Xenon/A SoM/B SoM/X SoM.
1.2.1-rc.2
Note: This is primarily a Manufacturing release for Gen 3 devices with some minor bugfixes. Your testing is appreciated. If you find any issues, please report them, and fallback to 1.2.0-rc.1 or 1.1.0.
This release contains v311 bootloaders (bumped this release due to Gen 3 changes in #1799 ). We have also separated BOOTLOADER_DEPENDENCY for Gen 2 and Gen 3. For now, we will leave Gen 2 as is depending on v201 bootloader (so there is nothing to do for Gen 2 (Photon/P1 only) unless you want the latest bootloader, although it is not mandatory), but we have bumped Gen 3 to v311 because we have removed the embedded bootloaders from Gen 3 system firmware in 1.2.0-rc.1. To force the Cloud update for Gen 2 (Photon/P1 only) we will bump the bootloader dependency version to v302 in v1.2.0 default.
BUG FIXES
[gen 3] Fixes radio initialization sequence for SoftDevice S140v6.1.1 #1794
[gen 2] Fix ABI compatibility issue in cellular HAL regarding CellularDevice and cellular_device_info()#1792
[gen 3] [bootloader] fixes SOS 10 when upgrading bootloader first from older system firmware. External flash sleep refactoring #1799
A new Release Candidate Device OS v1.2.1-rc.3 is available now on https://build.particle.io for Core/Photon/P1/Electron/Argon/Boron/Xenon/A SoM/B SoM/X SoM.
1.2.1-rc.3
A new Release Candidate Device OS v1.1.1-rc.1 is available now on https://build.particle.io for Core/Photon/P1/Electron/Argon/Boron/Xenon/A SoM/B SoM/X SoM.
1.1.1-rc.1
Note: This is primarily a Manufacturing release for Gen 2 & Gen 3 devices with some minor LTE bugfixes. Your testing is appreciated. If you find any issues, please report them, and fallback to 1.1.0.
BUGFIXES
[Electron/LTE] disables all eDRX AcT types [ch32051] #1762
A new Release Candidate Device OS v1.3.0-rc.1 is available now on https://build.particle.io for Core/Photon/P1/Electron/Argon/Boron/Xenon/A SoM/B SoM/X SoM.
The particle-api-js Javascript SDK now has improved event stream error handling.
If you have a server or browser application that subscribes to Particle events and there is a network error the subscription used to fail silently (no additional Particle events were received but no error was communicated to the customer application). Now it handles more types of errors. You have to upgrade the version of particle-api-js they use to take advantage of this.
More details on how to use the improved event streams in the Javascript SDK docs.
A new Release Candidate Device OS v1.3.1-rc.1 is available now on https://build.particle.io for Core/Photon/P1/Electron/Argon/Boron/Xenon/A SoM/B SoM/X SoM.
A new Release Candidate Device OS v1.4.0-rc.1 is available now on https://build.particle.io for Core/Photon/P1/Electron/Argon/Boron/Xenon/A SoM/B SoM/X SoM.
1.4.0-rc.1
FEATURES
[Gen 3] Introduces BLE.begin() and BLE.end() wiring APIs #1890
[Gen 3] Exposes POSIX select() and poll() from socket HAL dynalib #1895
ENHANCEMENTS
[Gen 3] Alternately broadcast user and Particle-specific BLE advertising data when the device is in the Listening mode #1882
Updates all third party dependencies (OpenThread, MbedTLS, FreeRTOS, etc.) #1864
BUGFIXES
[Gen 3] Fixes heap and application static RAM overlap introduced in 1.3.0-rc.1 #1898
Fixes tinker build errors when building with LOG_SERIAL=y#1898
Fixes dynalib alignment issue when compiling relatively large applications potentially due to an unconfirmed bug in GCC by moving the dynalib into a separate section (.dynalib) #1894
A new Release Candidate Device OS v1.4.1-rc.1 is available now on https://build.particle.io for Core/Photon/P1/Electron/Argon/Boron/Xenon/A SoM/B SoM/X SoM.
1.4.1-rc.1
FEATURES
[Gen 2] Adds support for serial number, NCP type and mobile secret in STM32F2 OTP area #1927#1931
ENHANCEMENTS
[Electron, Boron] Increase the PMIC input current limit from 900mA to 1500mA and limit charging current to 896mA to allow 2G/3G devices to function when powered by sufficient power supply through VIN without the battery #1921
DTLS handshake timeout increased to 24 seconds to allow 3 retransmission attempts #1914
BUGFIXES
[Electron] Fixes RSSI failing due to Power Saving mode active #1917#1892
[Gen 3] Fixes memory leak when scanning for BLE devices #1929#1926
[Gen 3] Fixes reporting of discovered BLE peer characteristic descriptors #1916
[Gen 3] Fixes BleCharacteristic::setValue() with default BLeTxRxType argument (BleTxRxType::AUTO) for characteristics with WRITE property #1915#1913#1924
A new Default Release Device OS v1.4.1 is available now on https://build.particle.io for Core/Photon/P1/Electron/Argon/Boron/Xenon/A SoM/B SoM/X SoM.
1.4.1
FEATURES
ENHANCEMENTS
Implements a command to reset all network interfaces of a device remotely #1943
[Electron] Disables usage of AT+UDNSRN on 2G/3G Electrons in favor of a standalone socket-based DNS client #1940
BUGFIXES
[Photon / P1] Limits maximum TLS version to TLS1.1 for WPA Enterprise authentication as TLS1.2 seems to be broken in WICED 3.7.0-7 #1945
[Boron] Fixes attachInterrupt(D7, ...) not working due to a constraint introduced previously for cellular devices (Electron) #1939#1944
Send safe mode event when the session is resumed #1935
[LTE, u-blox] adds a mitigation to keep DNS Client responsive ch38990 #1938
A new Default Release Device OS v1.4.2 is available now on https://build.particle.io for Core/Photon/P1/Electron/Argon/Boron/Xenon/A SoM/B SoM/X SoM.
This release resolves a critical issue affecting Gen 3 bootloaders in DeviceOS releases 1.2.1 - 1.4.1, which may leave the device in a boot/crash-loop with a faint flickering white LED state.
So far, the issue has been confirmed on a number of Borons only, but other Gen 3 platforms may be presenting it as well.
1.4.2
BUGFIXES
[Gen 3] Fixes a boot/crash-loop due to a POWER_CLOCK_IRQn firing in between the jump into the system firmware from the bootloader #1948
A new Default Release Device OS v1.4.3 is available now on https://build.particle.io for Core/Photon/P1/Electron/Argon/Boron/Xenon/A SoM/B SoM/X SoM.
This release resolves a thread-safety issue on Gen 2 devices (Photon, P1, Electron), affecting non-reentrant C standard library functions requiring temporary non-stack storage. It is recommended to update any Gen 2 devices to this release.
1.4.3
BUGFIXES
[Photon/P1/Electron] Fixes thread-safety issues with non-reentrant C standard library functions requiring temporary thread-local storage #1970
A new Default Release Device OS v1.4.4 is available now on https://build.particle.io for Core/Photon/P1/Electron/Argon/Boron/Xenon/A SoM/B SoM/X SoM.
This release resolves a bug in handling of incorrectly initialized WiFi credentials list, resulting in crashes on a number of Photons and P1s manufactured with DeviceOS 1.2.1 - 1.4.2. It is recommended to update Photons and P1s with factory 1.2.1 - 1.4.2 DeviceOS to this release.
1.4.4
BUGFIXES
[Photon/P1] Fixes handling of invalid WiFi access point config entries in DCT #1976
