January 16th 2018:
Web Setup for Photon now works on Safari and Edge browsers.
February 7th 2018: Firmware release 0.7.0-rc.7
March 23rd 2018:
Who likes surprise features right before the weekend? We do!
You can now download your Web IDE app sources as a ZIP file!
March 23rd 2018:
Rate limits on webhooks and integrations are no more!
March 26th 2018: Firmware v0.7.0
A new Default Release Firmware v0.7.0 is available now on https://build.particle.io for Core/Photon/P1/Electron.
Be sure to read the full collection of notes Particle Firmware Updates Thread.
April 10th 2018: Firmware v0.8.0-rc.3
A new pre-release firmware v0.8.0-rc.3 is available now on https://build.particle.io for Core/Photon/P1/Electron.
The changelog is short, so here it is!
Be sure to read the full collection of notes in the changelog.
We want 0.8.0 to be rock solid and as bug-free
as possible so please let us know if you find any issues.
April 12th 2018:
You can now change your email (i.e., username) at https://login.particle.io/account-info.
May 4th 2018: Firmware v0.8.0-rc.4
A new pre-release firmware v0.8.0-rc.4 is available now on https://build.particle.io for Core/Photon/P1/Electron.
Particle.keepAlive()
API was broken since v0.6.2-rc.2 firmware on Electron where the System would override an early set User ping interval. This required a workaround of updating the keepAlive after the System made a connection to the Cloud. See issue #1482 for workaround. #1536
May 29th 2018:
Changes to the behavior of Device OS updates for cellular devices are described in this post:
June 26th 2018: Firmware v0.8.0-rc.8
A new pre-release firmware v0.8.0-rc.8 is available now on https://build.particle.io for Core/Photon/P1/Electron.
Note: This is primarily a MFG. release for SARA-R410 LTE modules. The changes do touch code used on other Electron based platforms, but no other features or fixes are relevant for U260, U270, U201, or G350 modems. This code has been tested on-device for all mentioned modem types with passing results. Please let us know if you find any issues. That said, this is a release candidate for 0.8.0 default so please do test on your systems.
July 30th 2018: Firmware v0.8.0-rc.9
A new pre-release firmware v0.8.0-rc.9 is available now on https://build.particle.io for Core/Photon/P1/Electron.
Note: This is a release candidate for 0.8.0 default so please do test on your systems.
August 17th 2018: Firmware v0.8.0-rc.10
A new pre-release firmware v0.8.0-rc.10 is available now on https://build.particle.io for Core/Photon/P1/Electron.
September 19th 2018: Two-Step Authentication and new Real-Time Event Logs.
Check out the blog post for details!
Happy building
September 29th 2018: Firmware v0.8.0-rc.11
A new pre-release firmware v0.8.0-rc.11 is available now on https://build.particle.io for Core/Photon/P1/Electron.
December 20th 2018: Firmware v0.8.0-rc.12
A new pre-release firmware v0.8.0-rc.12 is available now on https://build.particle.io for Core/Photon/P1/Electron.
PMIC::getInputCurrentLimit()
cannot report values higher than 900mA (#1581) Be sure to read the full collection of notes in the changelog.
January 4th 2019: Firmware v0.8.0-rc.14
A new pre-release firmware v0.8.0-rc.14 is available now on https://build.particle.io for Core/Photon/P1/Electron.
The ability to create Particle Products using the Generation 3 Hardware — specifically Products based on the Argon or Boron is now available in the Console and via the Particle API. These options will appear in the Device Type dropdown when creating a new product.
This will enable the creation of single-radio applications leveraging Wi-Fi or Cellular connectivity that use the latest and greatest Particle hardware. Stay tuned for support for Mesh-based deployments using the Product architecture!
January 10th 2019: Device OS v1.0.0
A new Default Release Device OS v1.0.0 is available now on https://build.particle.io for (Core/Photon/P1/Electron).
Check out our blog post all about it here: Announcing Device OS 1.0 and Release Guidelines for Product Creators
Finally, be sure to read the full collection of release notes Particle Device OS Updates Thread.
February 4th 2019: Device OS v1.0.1-rc.1
A new Release Candidate Device OS v1.0.1-rc.1 is available now on https://build.particle.io for (Core/Photon/P1/Electron).
This 1.0.1-rc.1 Release Candidate will be defaulted to 1.0.1 on Feb. 18th, 2019 unless there are regressions found that require further patches.
️ Testing on your applications is encouraged and appreciated, thank you!
February 19th 2019: Device OS v1.0.1
A new Default Release Device OS v1.0.1 is available now on https://build.particle.io for Core/Photon/P1/Electron.
