2/8/2017: Docs: webhooks and search
There is a new webhook reference section in the docs that documents all the properties of webhooks and the template syntax.
The search box at docs.particle.io was revamped to remove all the duplicate results for multiple devices and provide more accurate results.
This is also available on prerelease-docs.particle.io which is currently serving docs for 0.6.1-rc.2 firmware.
