July 30th 2020: Device OS v2.0.0-rc.1
A new Release Candidate Device OS v2.0.0-rc.1 is available now on https://build.particle.io for Photon/P1/Electron/Argon/Boron/B SoM/B5 SoM.
Highlights
BREAKING CHANGES
- DeviceOS no longer supports Xenon platform and Mesh connectivity in general
- Minimum ARM GCC version has been updated to 9.2.1
SPISettings
class is available even without Arduino compatibility layer
- Some HAL APIs have changed names, be sure to check the deprecation warnings when compiling the applications. Eventually, calling some HAL functions by old names will not be supported
FEATURES
- OTA improvements (compression, combined updates)
- [Gen 3] Cellular modem warm bootup, improving connection times when the modem is already registered on the network
- New sleep mode and wake up options and sleep improvements in general
- [Gen 3] Power-loss resistant bootloader updates
- Device-initiated describe messages. Timing issues should no longer affect variable/function registration
As well as 54 enhancements and bugfixes in total and some other features!
Be sure to read the full collection of release notes Particle Device OS Updates Thread.
September 22nd 2020: Device OS v2.0.0-rc.2
A new Release Candidate Device OS v2.0.0-rc.2 is available now on https://build.particle.io for Photon/P1/Electron/Argon/Boron/B SoM/B5 SoM.
Highlights
DEPRECATIONS
CellularSignal::rssi
and CellularSignal::qual
when used now generate deprecation warnings. These APIs will be removed in the next major release line (3.x). Make sure to check the documentation for the new API
FEATURES
- Sleep 2.0 feature parity between Gen 2 and Gen 3 (wake-up by analog value, USART, cellular)
ftruncate()
/ truncate()
ENHANCEMENTS
- Better power loss resiliency of OTA updates
- Cellular stability improvements
- Recovery mechanics for cases where Electron/E Series modem becomes unresponsive
… and lots more!
October 15th 2020: Device OS v1.5.4-rc.2
A new Release Candidate Device OS v1.5.4-rc.2 is available now on https://build.particle.io for Photon/P1/Electron/Argon/Boron/Xenon/B SoM/B5 SoM/Tracker.
Highlights
This release contains a few cellular connectivity bugfixes backported from 2.x release line.
October 21st 2020: Device OS v2.0.0-rc.3
A new Release Candidate Device OS v2.0.0-rc.3 is available now on https://build.particle.io for Photon/P1/Electron/Argon/Boron/B SoM/B5 SoM/Tracker.
Highlights
- A lot of cellular bugfixes/improvements
- [Gen 3] SPI MOSI pin drive strength is now set to high by default to support higher frequencies better
- When going into sleep without specifying network interface as a wake-up source, cloud connection will be properly terminated (allowing session resume on wake-up). When network interface is specified as a wake-up source, we’ll be sending a ping to the cloud on wake-up to make sure that the connection is still alive.
- In certain cases LED wasn’t going back to blinking green (network connecting) from cyan when the network connection was lost during some initial cloud connection process. This is now fixed.
- On platforms with PMIC, warm boots will no longer cause occasional modem brownouts due to current limit dropping to 100mA
- LTE Borons / B SoMs should now be establishing cellular connection much quicker from warm boot (we’ve introduced a workaround for peculiar SARA R410 modem behavior)
- Some standard C library functions are now exported from the system and are no longer needed to be compiled into the application saving some flash space
Dec 3rd 2020: Device OS v2.0.0 (LTS)
Particle’s first release in our new Long Term Support (LTS) branch for Device OS is now publicly available in the Web IDE, Particle Workbench, Particle CLI, and our Device OS releases page in GitHub. Long Term Support (LTS) releases for Device OS are independent branches of Device OS that are feature-frozen in time, aimed at providing increased stability and reliability for mission critical applications.
To learn more about our new LTS release line, read our latest blog post.
2.0.0
Highlights
Highlights from 2.0.0 Release Candidates:
BUGFIXES
- [Gen 2] Fix an issue in Sleep 2.0 API with STOP and ULP sleep modes potentially blocking user application on wake-up #2238
- [Electron] Fix a regression in
+C*REG
URC parsing #2239
Dec 16th 2020: Device OS v2.0.1 (LTS)
Device OS 2.0.1 is the latest release on LTS 2.x branch. To learn more about our new LTS release line, read our blog post.
2.0.1
Highlights
- This release enables a change in product firmware update process from earlier versions of Device OS: Electrons / E Series and Gen 3 devices will receive a bootloader update as a first step without triggering Safe Mode, to ensure that the rest of the update process can benefit from safety enhancements present in the LTS version of the bootloader (#2151 and #2176)
- OTA updates of Gen 3 devices to this release from Device OS < 1.1.0 no longer require an intermediate update step through Device OS 1.1.0 #2254
SystemSleepNetworkFlag::INACTIVE_STANDBY
can now be specified when entering HIBERNATE
sleep mode to keep the network coprocessor in its current state #2248
- Fast pin API calls should get some performance improvement compared to Device OS 2.0.0 #2251
Dec 24th 2020: Device OS v3.0.0-beta.1
Device OS 3.0.0-beta.1 is the first pre-release on non-LTS feature development branch (3.x). To learn more about our new LTS release line, read our blog post.
3.0.0-beta.1
Highlights
- OTA protocol version 3 (OTAv3) on Gen 3 platforms
- WiFi scanning support on Tracker
- Charging management through higher level power management API
Network.isOn()
and Network.isOff()
APIs
- BLE legacy pairing support and other BLE enhancements
- New Tracker-specific wake-up options
- More accurate cellular signal strength/quality percentage calculations
January 22nd 2021: Device OS v3.0.0-rc.1
Device OS 3.0.0-rc.1 is the first release candidate on non-LTS feature development branch (3.x). To learn more about our new LTS release line, read our blog post.
3.0.0-rc.1
Highlights
- [Electron] Modem power-on speed-up
- [Boron / B SoM] Third-party SIM card initialization bugfixes
- [Gen 3] UART RX DMA bugfix
- [Gen 3] BLE, OTAv3, network stack bugfixes
March 16th 2021: Device OS v3.0.0-rc.2
Device OS 3.0.0-rc.2 is the second release candidate on non-LTS feature development branch (3.x). To learn more about our new LTS release line, read our blog post.
3.0.0-rc.2
Highlights
- [Cellular] Battery presence detection when charging is disabled
- Increased maximum payload sizes for cloud primitives (publishes, variables, functions)
- Improved cold and warm boot behavior on B5 SoMs and Trackers
- System power management subsystem improvements
… and other bugfixes and improvements!
April 8th 2021: Device OS v3.0.0
Device OS 3.0.0 is the latest release on non-LTS (3.x) branch. To learn more about our new LTS release line, read our blog post.
3.0.0
Breaking changes
- [Cellular] Remove
rssi
and qual
from Cellular.RSSI()
#2212
- [Gen 3] BLE API consistency enhancements #2222
Highlights
- Network.isOn() and Network.isOff() APIs
April 15th 2021: Device OS v2.1.0-rc.1 (LTS)
This is the first Release Candidate for the upcoming Device OS release 2.1.0 (LTS) with critical bugfixes and backports from 3.x release line.
2.1.0-rc.1
Highlights
- This Release Candidate contains a set of critical bugfixes and backports from 3.x release line
- Backported features:
Network.isOn()
and Network.isOff()
APIs to query the network interface power state #2205
- [Electron] Proactively attempt to recover from a number of failed cellular registration states #2301
- Plenty of bugfixes and enhancements!
April 29th 2021: Device OS v2.1.0 (LTS)
This is the first minor Device OS Release in the LTS line with critical bugfixes and backports from 3.x release line.
2.1.0
Highlights
- This Release contains a set of critical bugfixes and backports from 3.x release line
Network.isOn()
and Network.isOff()
June 22nd 2021: Device OS v3.1.0-rc.1
3.1.0-rc.1
Highlights
[Gen 3] (Argon, Boron, B SoM, B5 SoM, Tracker) maximum application size has been increased from 128KB to 256KB #2322. A few important aspects of this change:
- If using standalone Particle CLI installation, make sure it’s updated to >= 2.12.0 version, which includes support for 256KB applications.
- A compiler will trigger an error when a function does not return a value, but was declared with a non-void return type #2323
- GCC 10 support #2288
- [Gen 3] BLE LE Secure Connections support #2262
- [Gen 3] BLE LE Long Range/Coded PHY support #2287 #2298 #2321
- [Boron / B SoM / Electron] SARA R410 05.12 modem firmware support #2317 #2319 #2318
- APIs to query maximum payload size for cloud primitives #2315
- Improvements to Argon boot-up times #2327
- Improvements to sleep behavior with
Cellular
specified as a wake-up source #2295 #2321
June 24th 2021: Device OS v2.2.0-rc.1 (LTS)
This is the first Release Candidate for the upcoming Device OS release 2.2.0 (LTS) with critical bugfixes and backports from 3.x release line.
2.2.0-rc.1
Highlights
July 13th 2021: Device OS v3.1.0
Note: This is a Release and may be used for production.
3.1.0
Highlights
Cellular
August 27th 2021: Device OS v2.2.0-rc.2 (LTS)
This is the second Release Candidate for the upcoming Device OS release 2.2.0 (LTS) with critical bugfixes and backports from 3.x release line.
2.2.0-rc.2
Highlights
- DTLS session is not cleared on socket errors (e.g. caused by cellular network deregistration), reducing network data required to re-established cloud connection #2335 #2337
- [Argon / Tracker] Avoid power leakage through ESP32
ESPBOOT
pin #2342
- Fixes parsing of JSON strings with more than 127 tokens #2348
- Reset scheduled module updates performed by the bootloader in case a second OTA update happens before they are applied (e.g. if
System.disableReset()
is used to postpone a pending device reset) #2346
September 15th 2021: Device OS v2.2.0 (LTS)
This is the second minor Device OS Release in the LTS line with critical bugfixes and backports from 3.x release line.
2.2.0
Highlights
ESPBOOT
pin #2342
September 24th 2021: Device OS v2.0.2 (LTS)
2.0.2
Highlights
- [Electron] Optional feature to use HSE/LSI as RTC clock source instead of LSE (external 32KHz XTAL) #2354
October 6th 2021: Device OS v2.3.0-rc.1 (LTS)
This is the first Release Candidate for the upcoming Device OS release 2.3.0 (LTS) with critical bugfixes and backports from 3.x release line.
2.3.0-rc.1
Highlights
- [Boron / B SoM ] Support for SARA R510 #2359 #2365
November 12th 2021: Device OS v3.2.0-rc.1
3.2.0-rc.1
Highlights
acquireSerialXBuffer()
API support for configuring custom buffer sizes for hardware UARTs (e.g. Serial1
) #2375
- [Boron / B SoM] Support for SARA R510 #2359 #2365
- [Gen 3] BLE: extended advertisement support with Coded PHY #2331
ESPBOOT
pin #2342
