Particle publish and blocking
#14
USB Serial ignores the baudrate.
The actual transfer rate is always the USB speed as you are not actually sending a serial bit stream but USB data reports at USB speed and get unpacked by the virtual CDC driver on your computer.
In code you can even write Serial.begin() or Serial.begin(9600) and you will still receive the data fine even if you expect 115200 baud.
For the actual UART interfaces Serial1 and siblings the baudrate does matter tho’
#15
Thanks. I tried it with and without baud and still only receive [app] INFO log messages. This is a Boron. Could that matter?
#16
There’s a new version of the PublishQueueAsyncRK library. Version 0.0.3 now supports WITH_ACK!
This is really cool because the events are not dequeued until the ACK is received. If you lose connectivity, there’s a period of time where Particle.connected() returns true still but you’re not able to send and receive data. Now with WITH_ACK support, those events will stay in the queue until you’re back online.
And, as before, since the queue is in retained memory, you can even reset the device or put it in sleep mode and the events will go out later.
Thanks for the code to make WITH_ACK work from a worker thread @joel!
#17
Can this be used with Photon and 3rd Gen devices?
#18
@rickkas7, is there an easy way to modify this async to be a very light weight version where it only basiclly runs on its own thread.
I only have about 600 - 1000 bytes to squeeze into my code and this would be awesome to have. Since our device has a UI delays related to this it really throw off the user experience.
#19
The library is pretty light-weight. If you’re really that tight on code-space you could likely remove the support for multiple queued publishes packed into a retained buffer so that it only handles a single publish event/data at a time.
#20
right now our code is at 130,700 bytes… so not much room.
Is there a limit to the stacksize you can make a thread? IE can it be 400? vs 2048 as shown below?
// This is the stack size for the thread.
const size_t ASYNCTCPCLIENT_STACK_SIZE = 2048;
I’m looking to create the smallest possilbe thread to just run particle.Publish. to stop blocking condions on the LTE with spotty connections. This causes long delays in our UI
#21
The stack size can probably be made smaller than 2048. You could try making it smaller until it fails to publish, then back add in some safety margin.
However this doesn’t affect the 130,700 limit. That’s the code size limit in flash. Make sure you’ve done everything here to minimize your usage:
https://docs.particle.io/support/particle-devices-faq/code-size-tips/
The thread stack is allocated at runtime out of the heap and affects the results of System.freeMemory().
#22
Ok thanks! Do you know if particle.publish is thread safe?
#23
@rickkas7 @BDub I was able to remove some features in my product to include your 0.0.3 ver AsyncPublish library. I am still finding that on a lossy connection that the device gets blocked for upto 10 sec. This is a case where the connection dropped out after this or just prior. Do you have any thoughts why the device is still getting blocked in this case of a dropped connection?
@BDub Could this be related to the fixes included in 1.0.1 and made the recovery much faster?
This is where it blocked:
 102.958 AT send     109 "\x17\xfe\xfd\x00\x01\x00\x00\x00\x00\x00\x1c\x00`\x00\x01\x00\x00\x00\x00\x00\x1c\xaf?\xd8\xf1\x80\xc3\xba\xdc\xfdL_\xd5\x8a\xae\xae\x04C\xa4O\x17\xcf\xd3\x86V~\xd2b\xd6\xa7I,\x015\xc4\xd55\xb4*I\xcc\xc6\x1b\x06\x10\xd4\xd9\xfeY\x7f\xcc\xc3\xeb\xa7N\xf0\xff\xf1~b\xca\xdb\xa0\xe2\x0fZ\x0f\x1fy\xa4\x19d\t?\x14 c\x84,\x9a\x81\x9d\xa7\x1e\xc6\xc7\xf8\x97\xab"
0000103285 [app.pubq] INFO: queueing eventName=s data=02100001010000001000.1553024929.4305.-6.1420:100.81111111111111.413.1.0 ttl=60 flags1=1 flags2=8 size=84
   112.967 AT send      36 "AT+USOST=0,\"18.213.151.3\",5684,109\r\n"
Below are the logs:
[ Modem::getSignalStrength ] = = = = = = = = = =
    97.538 AT send       8 "AT+CSQ\r\n"
    97.544 AT read  +   15 "\r\n+CSQ: 20,99\r\n"
    97.545 AT read OK    6 "\r\nOK\r\n"
0000097996 [app.pubq] INFO: queueing eventName=s data=02101001010000001000.1553024923.4305.-6.1420:100.81111111111111.413.1.0 ttl=60 flags1=1 flags2=8 size=84
0000097997 [app.pubq] INFO: publishing s 02101001010000001000.1553024923.4305.-6.1420:100.81111111111111.413.1.0 ttl=60 flags=9
0000097998 [comm.coap] TRACE: sending message id=16
0000097998 [system] TRACE: send 109
socketSendTo(0,18.213.151.3,5684,,109)
    97.995 AT send      11 "AT+CEREG?\r\n"
    98.003 AT read  +   34 "\r\n+CEREG: 2,1,\"4608\",\"4E62510\",8\r\n"
    98.005 AT read OK    6 "\r\nOK\r\n"
    98.005 AT send      36 "AT+USOST=0,\"18.213.151.3\",5684,109\r\n"
    98.012 AT read  >    3 "\r\n@"
    98.012 AT send     109 "\x17\xfe\xfd\x00\x01\x00\x00\x00\x00\x00\x1b\x00`\x00\x01\x00\x00\x00\x00\x00\x1b\x89\x8a\x06\xf2\xb4#\x8b\x01=\xaf\xadjE>P\xcb\x1coo\xf0\xea\xab\xbe:\xeb\xbe\xecC\x86\xfeCLT\\\x0f;\x93\xe7\xcd\xb4\xa3\x1e\x1f\xf7]\x05\r\xb0\xb4\xa4a\xbd\xf9\xea0\xb3>\xd5\\\a\xbfg4\xf4\x92\x8ae\xa7\xafp\x98\xb2}\x8fC>#\xfeu%y\xca\x15\x94C'\xc3\xa3"
    98.032 AT read  +   17 "\r\n+USOST: 0,109\r\n"
    98.033 AT read OK    6 "\r\nOK\r\n"
    98.033 AT send      14 "AT+USORF=0,0\r\n"
    98.039 AT read UNK   1 "\r"
    98.040 AT read UNK   5 "\r\n\r\r\n"
    98.041 AT read UNK  11 "+USORF: 0,0"
    98.042 AT read OK    6 "\r\nOK\r\n"
0000098874 [app.pubq] INFO: queueing eventName=s data=02100001010000001000.1553024924.4305.-6.1420:100.81111111111111.413.1.0 ttl=60 flags1=1 flags2=8 size=84
   100.051 AT send       8 "AT+CSQ\r\n"
   100.057 AT read  +   15 "\r\n+CSQ: 20,99\r\n"
   100.058 AT read OK    6 "\r\nOK\r\n"
   102.560 AT send       8 "AT+CSQ\r\n"
   102.566 AT read  +   15 "\r\n+CSQ: 20,99\r\n"
   102.567 AT read OK    6 "\r\nOK\r\n"
0000102632 [app.pubq] INFO: queueing eventName=s data=02101001010000001000.1553024928.4305.-6.1420:100.81111111111111.413.1.0 ttl=60 flags1=1 flags2=8 size=84
0000102941 [system] TRACE: send 109
   102.937 AT send      11 "AT+CEREG?\r\n"
   102.946 AT read  +   34 "\r\n+CEREG: 2,1,\"4608\",\"4E62510\",8\r\n"
   102.949 AT read OK    6 "\r\nOK\r\n"
   102.949 AT send      36 "AT+USOST=0,\"18.213.151.3\",5684,109\r\n"
   102.958 AT read  >    3 "\r\n@"
mbedtls/library/ssl_tls.c:2971: mbedtls_ssl_flush_output() returned -1 (-0x0001)
mbedtls/library/ssl_tls.c:7165: mbedtls_ssl_write_record() returned -1 (-0x0001)
   122.970 AT send       8 "AT+CSQ\r\n"
0000123074 [comm.protocol] ERROR: Event loop error 3
0000123074 [system] WARN: Communication loop error, closing cloud socket
0000123074 [system] INFO: Cloud: disconnecting
0000123075 [system] INFO: Cloud: disconnected
0000123075 [app.pubq] INFO: published failed, will retry in 30000 ms
0000123175 [system] INFO: Cloud: connecting
0000123175 [system] TRACE: sparkSocket Now =0
0000123175 [system] TRACE: Close Attempt
socketClose(0)
   123.973 AT send      11 "AT+CEREG?\r\n"
socketFree(0)
0000124978 [system] TRACE: socket_close()=success
0000124980 [system] INFO: Read Server Address = type:1,domain:$id.udp.particle.io
#24
Are you calling Cellular.RSSI() from your code? If you are, it will block for up to several minutes if the cloud connection is lost.
#25
I do call that every 2.5 seconds. I also check for particle connected and cellular ready before I check the RSSI.
From the log it was called just before the sending of data but retuend ok it blocked at this line
RSSI read just before, but returned
#26
The following sequence (from your trace) corresponds to what we have seen when LTE modem locks up due to cellular connection dropping from low signal strength during a transmit.
The USOST are transmit commands that each have a 10-second timeout and block your RSSI check (the CSQ command). Further, when your RSSI check finally gets a turn the modem is locked up and will hit its own 10-second time.
1.0.1 recovers more quickly by detecting the modem lockup and going through targeted recovery steps. But the underlying failure is coming out of the LTE modem and will result in some delay.
You can move your RSSI checks to a background thread so as to not block your main application thread if the cellular modem is currently busy or non-responsive.
#27
I’ll try creating a new thread for checking RSSI as that also blocked too as you and @rickkas7 said. This case was for about 7 seconds.
#28
@rickkas7 do you think I would be able to check the RSSI in the AsyncPublish thread instead of creating another thread?
#29
I’ve been contemplating that. I think so. If RSSI is stuck, you wouldn’t be able to publish anyway because they’re both waiting on the same resource.
#30
@rickkas7 Could it be checked at the below? Or would there be a better spot to check it at?
void PublishQueueAsync::threadFunction() {
	// Call the stateHandler forever
	while(true) {
		stateHandler(*this);
            ****Check RSSI HERE?
		os_thread_yield();
void PublishQueueAsync::checkQueueState() {
	// Is there data waiting to go out?
	volatile RetainedBufHeader *hdr = reinterpret_cast<RetainedBufHeader *>(retainedBuffer);
	bool haveEvent = false;
	SINGLE_THREADED_BLOCK() {
		haveEvent = (hdr->numEvents > 0);
	if (haveEvent && Particle.connected() && millis() - lastPublish >= 1010) {
		// We have an event and can probably publish
		isSending = true;
		EventData *data = reinterpret_cas
#31
Yes, that’s a reasonable place to put it. You probably want to surround it with a millis check so you don’t do it on every loop. I may add this as an optional feature, since it would be useful.
#32
@rickkas7 after using your library i’ve noticed that when I change screens when updating the TFT screen that now there are times certain things now do not render. If I encase the rendering in SINGLE_THREADED_BLOCK() { } they dont get messed with.
Is this a byproduct of using multithreads? Where on thread can iterrupt the other one at anytime?
Can one be deprioritized?
Also does it hurt if i slow down the thread by using?
os_thread_delay_until(&lastThreadTime, 100);
Can this be called: thread = new Thread("PublishQueueAsync", threadFunctionStatic, this, 1, 2048);
vs: thread = new Thread("PublishQueueAsync", threadFunctionStatic, this, OS_THREAD_PRIORITY_DEFAULT, 2048);
or are the only 2 priorities as per below:
const os_thread_prio_t OS_THREAD_PRIORITY_DEFAULT = 2;
const os_thread_prio_t OS_THREAD_PRIORITY_NETWORK = OS_THREAD_PRIORITY_DEFAULT;
const os_thread_prio_t OS_THREAD_PRIORITY_CRITICAL = 9;
#33
This is what I was thinking to get the RSSI from the thread.
void getRSSI() {
	#if PLATFORM_ID == PLATFORM_ELECTRON_PRODUCTION
	static uint32_t prevRSSIMillisB = 0;
	if (Particle.connected() && Cellular.ready()) {
		if (millis() > 5000 && celluarTurnedOn && millis() - prevRSSIMillisB >= 2500) {
			CellularSignal sig = Cellular.RSSI();
			wirelessRSSI = sig.rssi;
			prevRSSIMillisB = millis();
	#endif
	while(true) {
		getRSSI();
		os_thread_delay_until(&lastThreadTime, 100); // Delay so we're called every 100 milliseconds (10 times per second)
		//os_thread_yield();
