Hi all!
Is it possible to execute two operations at the same time?
I would like to blink the leds and produce a notification sound to show the user that the application went into an error.
Hi all!
You could try out Software Timers
But what kind of sound transducer are you thinking of?
With a mere buzzer, you’d only set a pin HIGH and it will buzz till you set it LOW again.
Other more sophisticated options like a MP3 board will provide nicer sound with similarly little effort.
