Particle Firmware Updates Thread
#63
Firmware 0.8.0-rc.9 Pre-release for Core/Photon/P1/Electron
released on July 30th, 2018
:pencil: Please read all notes in the Notes Festival :tada: below
Note: This is a release candidate for 0.8.0 default so please do test on your systems.
Note: This is a pre-release and is not intended for production yet. We’ve tested this pre-release to the best of our ability and we want to know what you think now! Please understand that some care and attention is necessary when testing this pre-release, and be sure to upgrade to the final release when it’s available. It will not be available by default. To use you must select the version dropdown from the devices drawer. Downgrading back to the current release info is at the bottom of this post.
Note: OTA or YModem transfer on Electron (sequence required)
  1. First Update to 0.5.5 (if the current version is less than that)
  2. Then update to 0.6.4 (if the current version is less than that)
  3. Then update to 0.7.0 (if the current version is less than that)
  4. Then update to 0.8.0-rc.9
Note: DFU over USB on Electron/Photon/P1 (sequence not required)
  • You may update to 0.8.0-rc.9 directly first, flash the system firmware (attached above) in order 1,2(,3) to the device using particle flash --usb <system-part.bin>. See the next note about the bootloader if you are offline!
Note: P1/Photon Bootloader
The Cloud will automatically update the bootloader on P1/Photon devices if your device is online. If your device does not connect to the cloud and it is offline, you should flash the bootloader to the device using particle flash --serial <bootloader.bin>. This should be done after upgrading system firmware. The Electron bootloader is applied automatically from it’s own system parts.
Note: Downgrading [Electron/Photon/P1] OTA or YModem transfer:
If you need to downgrade, you must downgrade to 0.7.0 and then 0.6.3(Photon/P1), 0.6.4(Electron) to ensure that the bootloader downgrades automatically. When downgrading to older versions, downgrade to 0.7.0 first, then 0.6.3(Photon/P1), 0.6.4(Electron), then to an older version such as 0.5.5.
0.8.0-rc.9
BUGFIXES
  • [Electron/LTE] Fast OTA Fixes #1558
System Binaries (all devices)
https://github.com/particle-iot/firmware/releases/tag/v0.8.0-rc.9
Programming and Debugging
You can view specific programming and debugging notes for this version of firmware here.
Particle Tools Changelog
#64
Firmware 0.8.0-rc.10 Pre-release for Core/Photon/P1/Electron
released on August 17th, 2018
  4. Then update to 0.8.0-rc.10
  • You may update to 0.8.0-rc.10 directly first, flash the system firmware (attached above) in order 1,2(,3) to the device using particle flash --usb <system-part.bin>. See the next note about the bootloader if you are offline!
0.8.0-rc.10
BUGFIXES
  • [Electron/LTE] eDRX & Power Saving mode disabled by default #1567
https://github.com/particle-iot/firmware/releases/tag/v0.8.0-rc.10
#65
Firmware 0.8.0-rc.11 Pre-release for Core/Photon/P1/Electron
released on September 29th, 2018
  • You may update to 0.8.0-rc.11 directly first, flash the system firmware (attached above) in order 1,2(,3) to the device using particle flash --usb <system-part.bin>. See the next note about the bootloader if you are offline!
0.8.0-rc.11
ENHANCEMENTS
  • [Electron/Photon/P1] Do not check and lock bootloader sector write protection on every boot [ch17416] #1578
BUGFIXES
  • [Electron/LTE] adds 1 retry for UDP/TCP socket send in case of error [ch18789] #1576
  • [Electron/Photon/P1] Fixes recursive semaphore lock timeout [ch21928] #1577
https://github.com/particle-iot/firmware/releases/tag/v0.8.0-rc.11
Putting back in box (update: took back out of box...)
#66
Firmware 0.8.0-rc.12 Pre-release for Core/Photon/P1/Electron
released on December 20th, 2018 :santa: :mrs_claus:
  4. Then update to 0.8.0-rc.12
  • You may update to 0.8.0-rc.12 directly first, flash the system firmware (attached above) in order 1,2(,3) to the device using particle flash --usb <system-part.bin>. See the next note about the bootloader if you are offline!
0.8.0-rc.12
ENHANCEMENTS
  • [Electron/Photon/P1] Cache persistent feature flags (#1640)
  • [Photon/P1] Memory usage optimizations (#1635)
BUGFIXES
  • [Electron/Photon/P1] Fixes SOS in 0.8.0-rc.11 and also ensures button and OOM events are handled synchronously. Previously in multi-threaded applications the button handling may have been delayed to run within the application thread. Now it is always handled immediately and should be noted that it is called from an ISR, so it is not advised to dynamically allocate memory in button event handlers. (#1600) (#1650)
  • [Electron/Photon/P1] Do not disable interrupts on every system loop iteration (#1622)
  • [Electron/Photon/P1] Wait for Wiring Thread to start (#1528)
  • [Electron/LTE] Power Manager Watchdog Timer Fix (#1581)
  • [Electron/LTE] AT+CNUM command causing registration failure on LTE devices (#1627)
  • [Electron] PMIC::getInputCurrentLimit() cannot report values higher than 900mA (#1581)
  • [Electron] Do not set the sticky skip hello after handshake (#1624)
  • [Photon/P1] Invalidate sockets when turning WiFi off (#1639)
https://github.com/particle-iot/firmware/releases/tag/v0.8.0-rc.12
#67
Firmware 0.8.0-rc.14 Pre-release for Core/Photon/P1/Electron
released on January 4th, 2019
  4. Then update to 0.8.0-rc.14
  • You may update to 0.8.0-rc.14 directly first, flash the system firmware (attached above) in order 1,2(,3) to the device using particle flash --usb <system-part.bin>. See the next note about the bootloader if you are offline!
0.8.0-rc.14
BUGFIXES
  • [Electron/LTE] Fixes unique stale socket issue with LTE devices (#1666)
https://github.com/particle-iot/firmware/releases/tag/v0.8.0-rc.14
#68
Firmware 1.0.0 release is out on the Web IDE for Core/Photon/P1/Electron
released on production servers January 10th, 2019
:pencil2: Please read all notes below :bowtie:
Note: This is a Release and may be used for production. Any known issues are likely slated for 1.0.1-rc.1 (check Github issues). It is available by default for all devices. To use, select the 1.0.0 version dropdown from the devices drawer.
Downgrading back to a previous release info is at the bottom of this post.
Note: If you have previously last used one of the prerelease versions of 0.8.0-rc.x on a Core/Photon/P1 device, please re-flash it with 1.0.0.
  4. Then update to 1.0.0
  • You may update to 1.0.0 directly first, flash the system firmware (attached above) in order 1,2(,3) to the device using particle flash --usb <system-part.bin>. See the next note about the bootloader if you are offline!
1.0.0
BREAKING CHANGES
  • Beginning with 1.0.0 release, Particle.publish() and Particle.subscribe() methods will require event scope to be specified explicitly. This means using PRIVATE or PUBLIC for Particle.publish() and MY_DEVICES or ALL_DEVICES for Particle.subscribe(). Please update your apps to include the event scope to avoid compilation errors in firmware >0.7.0. Deprecation warnings for this change began with 0.7.0-rc.3. #1365
  • [Core/Photon/P1] WiFi.RSSI() must be cast to int8_t when used inline with Serial.print() to produce correct results. E.g. Serial.printlnf("%d", (int8_t) WiFi.RSSI() ); Electron is not affected. #1423
FEATURES
  • Diagnostics service #1390
  • Network and Cloud diagnostics #1424
  • Diagnostics for unacked messages and rate limited events #1391
  • System uptime diagnoatics #1393
  • Network Signal Quality/Strength rework and diagnostics #1423
  • RAM usage diagnostic sources data #1411
  • Battery charge diagnostics #1395
  • Battery State diagnostics #1398
  • [Electron] Reworked power management #1412
  • Low-latency interrupt handlers #1394
  • [Electron] adds UPSV handling to cellular_hal #1480
  • [Photon/P1] TCPClient: non-blocking, blocking, blocking with timeout writes support #1485
  • Network and cloud diagnostics #1424
  • Out of heap system event and heap fragmentation detection #1452
  • USB request handlers #1444
ENHANCEMENTS
  • [Photon/P1] Moves Wi-Fi tester into application module #1378
  • [Photon/P1] Wi-FI firmware compression #1421
  • Only remake $(TARGET_BASE).elf el al. if necessary #1223
  • Use ‘using std::**’ instead of define * std::* #1258
  • Added docs on local build setup #1374
  • Firmware update and access to internal flash via USB requests #1456
  • Generalize FuelGauge to also use alternative I2C interfaces. #1443
  • [Photon/P1] WiFi.dnsServerIP()/WiFi.dhcpServerIP() support #1386
  • [Photon/P1] Increase maximum supported number of simultaneously active TCP connections #1350
  • Disable WKP pin waking device up from SLEEP_MODE_DEEP #1409
  • System.sleep(): support for multiple wake up pins #1405
  • System.sleep() wake up reason #1410
  • Serialize access to the CRC peripheral (STM32F2xx) #1465
  • [Photon/P1] Enables support for SHA384/SHA512 certificates for WPA Enterprise #1501
  • [Photon/P1] A number of networking-related fixes v2 #1500
  • [Electron/Photon/P1] Increase Device OS API argument lengths. More data in Functions, Variables, Publish, Subscribe… oh my! #1537
  • [Electron] Adds support for SARA-R410 to the Cellular HAL #1532
BUGFIXES
  • [Electron] Error handling in the data usage API #1435
  • Cloud random seed not working #1312
  • Fixed shadowing of write(const unint_8_t*, sizte_t) in USBKeyboard #1372
  • Fix usage of an incorrect prerequisite name in program-* targets #1463
  • [Virtual] Fixes virtual device running with UDP protocol #1462
  • [Core] Fixes I2C slave mode #1309
  • [Electron] moves some newlib functions into part1 #1471
  • [Electron] DCD fixes #1454
  • [Electron] connect_cancel() fix #1464
  • [Electron] Fix caching of the description CRCs in the backup RAM #1413
  • [Electron] Guard cellular_command() with a global lock #1415
  • [Electron] Fix heap bounds build for system part1 #1478
  • [Photon/P1/Electron] Recursive logging freezes the application thread while the LogHandler is trying to acquire a lock on the resource #1517
  • [Photon/Electron] WKP pin needs to be disabled as a wakeup source on boot to allow its normal operation #1496
  • [Photon/P1] A number of networking-related fixes #1492
  • [Electron] Fixes missing URCs for received data during TX or RX socket operations. This caused the modem not to be able to receive further data properly until it re-connected to the Cloud which it would do automatically but usually after a short or longer period of time. #1530
  • [Electron] Particle.keepAlive() API was broken since v0.6.2-rc.2 firmware on Electron where the System would override an early set User ping interval. This required a workaround of updating the keepAlive after the System made a connection to the Cloud. See issue #1482 for workaround. #1536
  • [Electron] Bug fixes for SARA-R410 LTE E Series #1547
  • [Electron] Disables 30 second ping for Kore SIMs on SARA_R410 (default 23 minute ping re-applied)
INTERNAL
  • Minor refactoring of the USB protocol implementation #1473
  • [Electron] Flash size optimizations #1469
  • Documents low level USB request completion notifications #1475
  • IS_CLAIMED request fixes #1472
  • fixes the unit test build #1474
  • Fixes some 0.8.0-rc.2 tests #1476
  • [Electron] fixes sticker-rig issue with POWER_ON command #1544
  • [Electron] Fixes monolithic build #1543
System Binaries (all devices) & Device Upgrader (Photon & Electron)
https://github.com/particle-iot/firmware/releases/tag/v1.0.0
Po-util: The Ultimate Local Particle Experience for Linux and macOS
#69
Hi friends!
We just updated release/stable and master branches of the device-os repo to be current with release/v1.0.0.
Because we had to force push these changes, you’ll likely have merge conflicts if you git pull the latest changes for those branches. Because of this you will need to hard reset your local copy of each branch to match the remote.
:warning: Before doing this, make sure you save any changes you have been making in your local copy of release/stable or master (hopefully you are not doing that though and using a feature/branch based on these :wink: )
Hard Reset release/stable
git checkout release/stable && git fetch origin && git reset --hard origin/release/stable
Hard Reset master
git checkout master && git fetch origin && git reset --hard origin/master
You should now be sync’d up again with the most recent release/stable and master
Rename the repo to device-os
We also renamed the repo from firmware to device-os and you may update your local clone as follows:
git remote set-url origin git@github.com:particle-iot/device-os.git
Read more about 1.0.0 on our blog
Announcing Device OS 1.0 and Release Guidelines for Product Creators
