Particle Firmware Updates Thread
#23
##:particle: :particle: Firmware 0.5.1-rc.1 Pre-release is out on the Build IDE for Core/Photon/P1/Electron :particle: :particle:
Note: This is a pre-release and is not intended for production yet. It will not be available by default. To use you must select the version dropdown from the devices drawer. Downgrading back to the current release info is at the bottom of this post.
v0.5.1-rc.1 Changelog
FEATURES
  • Wi-Fi Country Code can be set to configure the available channels and power transmission. #942
ENHANCEMENTS
  • ARM GCC 5.3.1 compiler support
BUGFIXES
  • [Photon/P1] Fix a timing-critical bug in WICED that causes system freeze. #877
  • Tone not available on A7 after stop-mode sleep. #938
  • Regression in EEPROM emulation size. #983
  • [Electron] Wrong bitmask is provided for 4208 setting in power management #987
#System Binaries (all devices) & Device Upgrader (Photon & Electron)
Updating System Firmware (and optionally adding Tinker)
To update your device, compile and flash your application in the Build IDE, selecting version 0.5.1-rc.1 (prerelease) in the devices drawer. Update instructions for Core, Photon, P1 and Electron below.
The OTA method using Particle CLI
For devices already online and connected to the cloud, the system firmware can be updated OTA using these commands:
If your device is online, you can attempt to OTA (Over The Air) update these system parts as well with the particle-cli:
Note: You must download system binaries to a local directory on your machine for this to work.
Core:
particle flash YOUR_DEVICE_NAME tinker-0.5.1-rc.1-core.bin
Photon:
particle flash YOUR_DEVICE_NAME system-part1-0.5.1-rc.1-photon.bin
particle flash YOUR_DEVICE_NAME system-part2-0.5.1-rc.1-photon.bin
particle flash YOUR_DEVICE_NAME tinker (optional)
P1:
particle flash YOUR_DEVICE_NAME system-part1-0.5.1-rc.1-p1.bin
particle flash YOUR_DEVICE_NAME system-part2-0.5.1-rc.1-p1.bin
Electron:
particle flash YOUR_DEVICE_NAME system-part1-0.5.1-rc.1-electron.bin
particle flash YOUR_DEVICE_NAME system-part2-0.5.1-rc.1-electron.bin
The local method over USB using Particle CLI
This requires CLI version 1.12.0 or newer. You can check with particle --version.
If you have the Particle CLI installed already, make sure it is updated with the following command. Make sure the device is in DFU mode and run:
sudo npm update -g particle-cli (note: you can try without sudo first if you wish)
Core:
particle flash --usb tinker-0.5.1-rc.1-core.bin
Photon:
particle flash --usb system-part1-0.5.1-rc.1-photon.bin
particle flash --usb system-part2-0.5.1-rc.1-photon.bin
particle flash --usb tinker (optional)
P1:
particle flash --usb system-part1-0.5.1-rc.1-p1.bin
particle flash --usb system-part2-0.5.1-rc.1-p1.bin
Electron:
particle flash --usb system-part1-0.5.1-rc.1-electron.bin
particle flash --usb system-part2-0.5.1-rc.1-electron.bin
The local DFU-UTIL method
can be applied to offline devices locally over USB using dfu-util
  • Put the device in DFU mode (flashing yellow LED)
  • open a terminal window, change to the directory where you downloaded the files above, and run these commands:
Core:
dfu-util -d 1d50:607f -a 0 -s 0x8005000:leave -D tinker-0.5.1-rc.1-core.bin
Photon:
dfu-util -d 2b04:d006 -a 0 -s 0x8020000 -D system-part1-0.5.1-rc.1-photon.bin
dfu-util -d 2b04:d006 -a 0 -s 0x8060000:leave -D system-part2-0.5.1-rc.1-photon.bin
P1:
dfu-util -d 2b04:d008 -a 0 -s 0x8020000 -D system-part1-0.5.1-rc.1-p1.bin
dfu-util -d 2b04:d008 -a 0 -s 0x8060000:leave -D system-part2-0.5.1-rc.1-p1.bin
Electron:
dfu-util -d 2b04:d00a -a 0 -s 0x8020000 -D system-part1-0.5.1-rc.1-electron.bin
dfu-util -d 2b04:d00a -a 0 -s 0x8040000 -D system-part2-0.5.1-rc.1-electron.bin
Downgrading from 0.5.1-rc.1 to current default firmware
Current defaults
Core: v0.5.0
Photon: v0.5.0
P1: v0.5.0
Electron: v0.5.0
The easiest way to downgrade from a 0.5.1-rc.1 prerelease system firmware, is to use the CLI and run these commands in order. First put the Tinker back on the device, then downgrade the System firmware. This requires CLI version 1.12.0 or newer. You can check with particle --version.
If you have the Particle CLI installed already, you can update it with the following combined command. Make sure the device is in DFU mode and run:
  1. Make sure Tinker is installed, instead of a 0.5.1-rc.1 app that you may currently have running on your device. Have the device in DFU mode and run:
  1. Make sure the device is in DFU mode and run:
particle update
This works for downgrading without specifying --target X.Y.Z because the 0.5.1-rc.1 pre-release firmware is not the default, and therefor particle update effectively downgrades your firmware.
Debugging for Electron
Instructions on using the Tinker USB Debugging app are here
This is useful for simply capturing the Electron’s connection process.
Instructions on using the Electron Troubleshooting app are here
This is useful for interacting with the Electron’s connection process.
#24
##:particle: :particle: Firmware 0.5.1 Release is out on the Build IDE for Core/Photon/P1/Electron - and the Particle CLI has been updated from 1.12.0 to 1.14.0 :particle: :particle:
Note: This is a Release and may be used for production. Any known issues are minor and mostly likely slated for 0.6.x release (check Github issues). It is available by default for all devices. To use, select the 0.5.1 version dropdown from the devices drawer. Please observe the warning below about downgrading.
Note: Some users previously had last used 0.5.1-rc.1 or 0.5.1-rc.2 on various platforms. Since these are no longer available, please re-flash your devices with 0.5.1. This is technically the same as 0.5.1-rc.2. As usual, you will have to locally upgrade the Electron system firmware to 0.5.1 first.
:warning: Caution: After upgrading to 0.5.1, DO NOT downgrade system firmware via OTA remotely
This will cause Wi-Fi credentials to be erased on the Photon and P1. This does not affect the Core or Electron. Feel free to downgrade locally with the understanding that you will have to re-enter Wi-Fi credentials. Also note that 0.5.1 fixes several important bugs, so there should be no reason you’d normally want to downgrade. :warning:
v0.5.1 Changelog
FEATURES
  • [Electron] Added support in HAL for a SMS received callback handler.
ENHANCEMENTS
BUGFIXES
To update your device, compile and flash your application in the Build IDE, selecting version 0.5.1 in the devices drawer. Update instructions for Core, Photon, P1 and Electron below. Electron system firmware must be updated locally (see below) to minimize data usage, after which user applications can be flashed OTA from the Build IDE.
Particle CLI (easy method)
The easiest way to upgrade to 0.5.1 system firmware, is to use the CLI and run these commands. First upgrade the System firmware, then optionally put Tinker on the device. This requires CLI version 1.14.0 or newer. You can check with particle --version.
If you have the Particle CLI installed already, you can update it with the following command. Make sure the device is in DFU mode (flashing yellow LED) and run:
// Note: you can try without sudo first if you wish
particle update
  1. Optionally add Tinker as the user firmware instead of an app that you may currently have running on your device. Have the device in DFU mode and run:
Note: You must download system binaries to a local directory on your machine for this to work. Binaries are attached to the bottom of this release.
Core:
particle flash YOUR_DEVICE_NAME tinker-0.5.1-core.bin
Photon:
particle flash YOUR_DEVICE_NAME system-part1-0.5.1-photon.bin
particle flash YOUR_DEVICE_NAME system-part2-0.5.1-photon.bin
P1:
particle flash YOUR_DEVICE_NAME system-part1-0.5.1-p1.bin
particle flash YOUR_DEVICE_NAME system-part2-0.5.1-p1.bin
Electron:
particle flash YOUR_DEVICE_NAME system-part1-0.5.1-electron.bin
particle flash YOUR_DEVICE_NAME system-part2-0.5.1-electron.bin
Core:
particle flash --usb tinker-0.5.1-core.bin
Photon:
particle flash --usb system-part1-0.5.1-photon.bin
particle flash --usb system-part2-0.5.1-photon.bin
P1:
particle flash --usb system-part1-0.5.1-p1.bin
particle flash --usb system-part2-0.5.1-p1.bin
Electron:
particle flash --usb system-part1-0.5.1-electron.bin
particle flash --usb system-part2-0.5.1-electron.bin
Core:
dfu-util -d 1d50:607f -a 0 -s 0x8005000:leave -D tinker-0.5.1-core.bin
Photon:
dfu-util -d 2b04:d006 -a 0 -s 0x8020000 -D system-part1-0.5.1-photon.bin
dfu-util -d 2b04:d006 -a 0 -s 0x8060000:leave -D system-part2-0.5.1-photon.bin
P1:
dfu-util -d 2b04:d008 -a 0 -s 0x8020000 -D system-part1-0.5.1-p1.bin
dfu-util -d 2b04:d008 -a 0 -s 0x8060000:leave -D system-part2-0.5.1-p1.bin
Electron:
dfu-util -d 2b04:d00a -a 0 -s 0x8020000 -D system-part1-0.5.1-electron.bin
dfu-util -d 2b04:d00a -a 0 -s 0x8040000 -D system-part2-0.5.1-electron.bin
Where is the real documentation?
Electron always in safe mode
#25
Firmware 0.5.2-rc.1 Pre-release is out on the Build IDE for Core/Photon/P1/Electron :particle: :particle:
Note: This is a pre-release and is not intended for production yet. We’ve tested this pre-release to the best of our ability and we want to know what you think now! Please understand that some care and attention is necessary when testing this pre-release, and be sure to upgrade to the final release when it’s available. It will not be available by default. To use you must select the version dropdown from the devices drawer. Downgrading back to the current release info is at the bottom of this post.
v0.5.2-rc.1 Changelog
ENHANCEMENTS
  • [Photon/P1] Restores the default WICED country to Japan #1014
:white_check_mark: Upgrading to this version will now allow you to downgrade remotely OTA to v0.5.0 or earlier without erasing Wi-Fi credentials. There are still some cases where a downgrade will erase credentials, but only if you have explicitly set the country code to something other than the default or JP2. For example, if you set the country code to GB0 or US4, if you downgrade to v0.5.0 your Wi-Fi credentials will be erased. Leaving the country code at default or set to JP2 will not erase credentials when downgrading to v0.5.0. Do not downgrade to v0.5.1 first, and then v0.5.0… this will erase credentials in all cases.
BUGFIXES
  • .syncTime() and .unsubscribe() called on the system thread. Prevents issues when multiple threads try to send messages through the cloud connection or manage the network state shared memory. #1041
To update your device, compile and flash your application in the Build IDE, selecting version 0.5.2-rc.1 (prerelease) in the devices drawer. Update instructions for Core, Photon, P1 and Electron below.
Core:
particle flash YOUR_DEVICE_NAME tinker-0.5.2-rc.1-core.bin
Photon:
particle flash YOUR_DEVICE_NAME system-part1-0.5.2-rc.1-photon.bin
particle flash YOUR_DEVICE_NAME system-part2-0.5.2-rc.1-photon.bin
P1:
particle flash YOUR_DEVICE_NAME system-part1-0.5.2-rc.1-p1.bin
particle flash YOUR_DEVICE_NAME system-part2-0.5.2-rc.1-p1.bin
Electron:
particle flash YOUR_DEVICE_NAME system-part1-0.5.2-rc.1-electron.bin
particle flash YOUR_DEVICE_NAME system-part2-0.5.2-rc.1-electron.bin
Core:
particle flash --usb tinker-0.5.2-rc.1-core.bin
Photon:
particle flash --usb system-part1-0.5.2-rc.1-photon.bin
particle flash --usb system-part2-0.5.2-rc.1-photon.bin
P1:
particle flash --usb system-part1-0.5.2-rc.1-p1.bin
particle flash --usb system-part2-0.5.2-rc.1-p1.bin
Electron:
particle flash --usb system-part1-0.5.2-rc.1-electron.bin
particle flash --usb system-part2-0.5.2-rc.1-electron.bin
Core:
dfu-util -d 1d50:607f -a 0 -s 0x8005000:leave -D tinker-0.5.2-rc.1-core.bin
Photon:
dfu-util -d 2b04:d006 -a 0 -s 0x8020000 -D system-part1-0.5.2-rc.1-photon.bin
dfu-util -d 2b04:d006 -a 0 -s 0x8060000:leave -D system-part2-0.5.2-rc.1-photon.bin
P1:
dfu-util -d 2b04:d008 -a 0 -s 0x8020000 -D system-part1-0.5.2-rc.1-p1.bin
dfu-util -d 2b04:d008 -a 0 -s 0x8060000:leave -D system-part2-0.5.2-rc.1-p1.bin
Electron:
dfu-util -d 2b04:d00a -a 0 -s 0x8020000 -D system-part1-0.5.2-rc.1-electron.bin
dfu-util -d 2b04:d00a -a 0 -s 0x8040000 -D system-part2-0.5.2-rc.1-electron.bin
Downgrading from 0.5.2-rc.1 to current default firmware
Current defaults
Core: v0.5.1
Photon: v0.5.1
P1: v0.5.1
Electron: v0.5.1
The easiest way to downgrade from a 0.5.2-rc.1 prerelease system firmware, is to use the CLI and run these commands in order. First put the Tinker back on the device, then downgrade the System firmware. This requires CLI version 1.14.2. You can check with particle --version.
  1. Make sure Tinker is installed, instead of a 0.5.2-rc.1 app that you may currently have running on your device. Have the device in DFU mode and run:
particle update
This works for downgrading without specifying --target X.Y.Z because the 0.5.2-rc.1 pre-release firmware is not the default, and therefor particle update effectively downgrades your firmware.
#26
Note: This is a Release and may be used for production. Any known issues are likely slated for 0.5.3-rc.1 and 0.6.0-rc.1 releases (check Github issues). It is available by default for all devices. To use, select the 0.5.2 version dropdown from the devices drawer. Please read the note below about downgrading.
Note: Some users previously had last used 0.5.2-rc.1 on Core/Photon/P1 devices. Since this target is no longer available for those devices, please re-flash them with 0.5.2. Pre-release 0.5.2-rc.1 is still available for the Electron since it may be more difficult or costly to upgrade these remote devices. Please do upgrade when you can to 0.5.2, however this is technically the same firmware as 0.5.2-rc.1. As usual, you will have to locally upgrade the Electron system firmware to 0.5.2 first. Electron system version identification has been improved. You should only need to refresh/reload the Build IDE to see the new version.
v0 5 2
v0.5.2 Changelog
ENHANCEMENTS
BUGFIXES
located below
The easiest way to upgrade to 0.5.2 system firmware, is to use the CLI and run these commands. First upgrade the System firmware, then optionally put Tinker on the device. This requires CLI version 1.15.0 or newer. You can check with particle --version.
particle update
Core:
particle flash YOUR_DEVICE_NAME tinker-0.5.2-core.bin
Photon:
particle flash YOUR_DEVICE_NAME system-part1-0.5.2-photon.bin
particle flash YOUR_DEVICE_NAME system-part2-0.5.2-photon.bin
P1:
particle flash YOUR_DEVICE_NAME system-part1-0.5.2-p1.bin
particle flash YOUR_DEVICE_NAME system-part2-0.5.2-p1.bin
Electron:
particle flash YOUR_DEVICE_NAME system-part1-0.5.2-electron.bin
particle flash YOUR_DEVICE_NAME system-part2-0.5.2-electron.bin
Core:
particle flash --usb tinker-0.5.2-core.bin
Photon:
particle flash --usb system-part1-0.5.2-photon.bin
particle flash --usb system-part2-0.5.2-photon.bin
P1:
particle flash --usb system-part1-0.5.2-p1.bin
particle flash --usb system-part2-0.5.2-p1.bin
Electron:
particle flash --usb system-part1-0.5.2-electron.bin
particle flash --usb system-part2-0.5.2-electron.bin
Core:
dfu-util -d 1d50:607f -a 0 -s 0x8005000:leave -D tinker-0.5.2-core.bin
Photon:
dfu-util -d 2b04:d006 -a 0 -s 0x8020000 -D system-part1-0.5.2-photon.bin
dfu-util -d 2b04:d006 -a 0 -s 0x8060000:leave -D system-part2-0.5.2-photon.bin
P1:
dfu-util -d 2b04:d008 -a 0 -s 0x8020000 -D system-part1-0.5.2-p1.bin
dfu-util -d 2b04:d008 -a 0 -s 0x8060000:leave -D system-part2-0.5.2-p1.bin
Electron:
dfu-util -d 2b04:d00a -a 0 -s 0x8020000 -D system-part1-0.5.2-electron.bin
dfu-util -d 2b04:d00a -a 0 -s 0x8040000 -D system-part2-0.5.2-electron.bin
#27
Hey all! Just wanted to give you an update and say that 0.5.1 build target is still available for all devices even though it should not be downgraded from with Wi-Fi devices Photon and P1 (credentials will be lost, upgrade to 0.5.2 first before downgrading to 0.5.0 or earlier).
Also 0.5.2-rc.1 pre-release is still available for the Electron since it may be more difficult or costly to upgrade these remote devices. Please do upgrade when you can to 0.5.2, however this is technically the same firmware as 0.5.2-rc.1.
#28
Firmware 0.5.3-rc.1 Pre-release is out on the Build IDE for Core/Photon/P1/Electron :particle:
053rc1
v0.5.3-rc.1
BUGFIXES
  • SoftAP mode persisting when setup complete if Wi-Fi was off. #971
  • Free memory allocated for previous system interrupt handler #951 fixes #927
  • availableForWrite() was reporting bytes available instead of bytes available for write #1020 and #1017
  • millis()/micros() are now atomic to ensure monotonic values. Fixes #916, #925 and #1042
  • Fixes to I2C Slave mode implementation with clock stretching enabled #931
  • General I2C Improvements and MCP23017 tests #1047
  • Rebuilt Wiced_Network_LwIP_FreeRTOS.a WWD_for_SDIO_FreeRTOS.a on OSX #1057 fixes Local build stalling on object dump #1049
  • digitalRead() interfered with analogRead() #1006 fixes #993
  • Validates that module dependencies would still be satisfied after the module from the “ota_module” location is flashed (via OTA or YMODEM flashing) #1063
To update your device, compile and flash your application in the Build IDE, selecting version 0.5.3-rc.1 (prerelease) in the devices drawer. Update instructions for Core, Photon, P1 and Electron below.
Core:
particle flash YOUR_DEVICE_NAME tinker-0.5.3-rc.1-core.bin
Photon:
particle flash YOUR_DEVICE_NAME system-part1-0.5.3-rc.1-photon.bin
particle flash YOUR_DEVICE_NAME system-part2-0.5.3-rc.1-photon.bin
P1:
particle flash YOUR_DEVICE_NAME system-part1-0.5.3-rc.1-p1.bin
particle flash YOUR_DEVICE_NAME system-part2-0.5.3-rc.1-p1.bin
Electron:
particle flash YOUR_DEVICE_NAME system-part1-0.5.3-rc.1-electron.bin
particle flash YOUR_DEVICE_NAME system-part2-0.5.3-rc.1-electron.bin
Core:
particle flash --usb tinker-0.5.3-rc.1-core.bin
Photon:
particle flash --usb system-part1-0.5.3-rc.1-photon.bin
particle flash --usb system-part2-0.5.3-rc.1-photon.bin
P1:
particle flash --usb system-part1-0.5.3-rc.1-p1.bin
particle flash --usb system-part2-0.5.3-rc.1-p1.bin
Electron:
particle flash --usb system-part1-0.5.3-rc.1-electron.bin
particle flash --usb system-part2-0.5.3-rc.1-electron.bin
Core:
dfu-util -d 1d50:607f -a 0 -s 0x8005000:leave -D tinker-0.5.3-rc.1-core.bin
Photon:
dfu-util -d 2b04:d006 -a 0 -s 0x8020000 -D system-part1-0.5.3-rc.1-photon.bin
dfu-util -d 2b04:d006 -a 0 -s 0x8060000:leave -D system-part2-0.5.3-rc.1-photon.bin
P1:
dfu-util -d 2b04:d008 -a 0 -s 0x8020000 -D system-part1-0.5.3-rc.1-p1.bin
dfu-util -d 2b04:d008 -a 0 -s 0x8060000:leave -D system-part2-0.5.3-rc.1-p1.bin
Electron:
dfu-util -d 2b04:d00a -a 0 -s 0x8020000 -D system-part1-0.5.3-rc.1-electron.bin
dfu-util -d 2b04:d00a -a 0 -s 0x8040000 -D system-part2-0.5.3-rc.1-electron.bin
Downgrading from 0.5.3-rc.1 to current default firmware
Current defaults
Core: v0.5.2
Photon: v0.5.2
P1: v0.5.2
Electron: v0.5.2
The easiest way to downgrade from a 0.5.3-rc.1 prerelease system firmware, is to use the CLI and run these commands in order. First put the Tinker back on the device, then downgrade the System firmware. This requires CLI version 1.14.2. You can check with particle --version.
  1. Make sure Tinker is installed, instead of a 0.5.3-rc.1 app that you may currently have running on your device. Have the device in DFU mode and run:
particle update
This works for downgrading without specifying --target X.Y.Z because the 0.5.3-rc.1 pre-release firmware is not the default, and therefor particle update effectively downgrades your firmware.
#29
More info on the digitalRead() interfering with analogRead() fix from changelog:
Updated notes in analogRead(), will be live in docs shortly.
https://docs.particle.io/reference/firmware/photon/#analogread-adc-
Before 0.5.3 Note: do not set the pinMode() with analogRead(). The pinMode() is automatically set to AN_INPUT the first time analogRead() is called for a particular analog pin. If you explicitly set a pin to INPUT or OUTPUT after that first use of analogRead(), it will not attempt to switch it back to AN_INPUT the next time you call analogRead() for the same analog pin. This will create incorrect analog readings.
Since 0.5.3 Note: you do not need to set the pinMode() with analogRead(). The pinMode() is automatically set to AN_INPUT any time analogRead() is called for a particular analog pin, if that pin is set to a pinMode other than AN_INPUT. If you explicitly set a pin to INPUT, INPUT_PULLUP, INPUT_PULLDOWN or OUTPUT before using analogRead(), it will switch it back to AN_INPUT before taking the reading. If you use digitalRead() afterwards, it will automatically switch the pinMode back to whatever you originally explicitly set it to.
#30
A post was merged into an existing topic: Particle Firmware Updates: Comments
#31
Firmware 0.5.3-rc.2 Pre-release is out on the Build IDE for Core/Photon/P1/Electron
v0.5.3-rc.2
FEATURE
  • DTR/RTS support (open/closed detection: Serial.isConnected()). #1073
ENHANCEMENTS
  • [Electron] System firmware is now aware of system-part3 to allow OTA/YModem upgrade from >=0.5.3-rc.2 to >=0.6.0-rc.1
BUGFIXES
  • added HAL_IsISR() which is used to skip calling the background loop from delay(). fixes #673
  • Fixes an issue of USB Serial erroneously switching to closed state. #1073
  • RTC wakeup time now calculated right before entering SLEEP_MODE_DEEP. Fixes #1043
  • STOP mode should retain user interrupt handler. Fixes #1029
To update your device, compile and flash your application in the Build IDE, selecting version 0.5.3-rc.2 (prerelease) in the devices drawer. Update instructions for Core, Photon, P1 and Electron below.
Core:
particle flash YOUR_DEVICE_NAME tinker-0.5.3-rc.2-core.bin
Photon:
particle flash YOUR_DEVICE_NAME system-part1-0.5.3-rc.2-photon.bin
particle flash YOUR_DEVICE_NAME system-part2-0.5.3-rc.2-photon.bin
P1:
particle flash YOUR_DEVICE_NAME system-part1-0.5.3-rc.2-p1.bin
particle flash YOUR_DEVICE_NAME system-part2-0.5.3-rc.2-p1.bin
Electron:
particle flash YOUR_DEVICE_NAME system-part1-0.5.3-rc.2-electron.bin
particle flash YOUR_DEVICE_NAME system-part2-0.5.3-rc.2-electron.bin
Core:
particle flash --usb tinker-0.5.3-rc.2-core.bin
Photon:
particle flash --usb system-part1-0.5.3-rc.2-photon.bin
particle flash --usb system-part2-0.5.3-rc.2-photon.bin
P1:
particle flash --usb system-part1-0.5.3-rc.2-p1.bin
particle flash --usb system-part2-0.5.3-rc.2-p1.bin
Electron:
particle flash --usb system-part1-0.5.3-rc.2-electron.bin
particle flash --usb system-part2-0.5.3-rc.2-electron.bin
Core:
dfu-util -d 1d50:607f -a 0 -s 0x8005000:leave -D tinker-0.5.3-rc.2-core.bin
Photon:
dfu-util -d 2b04:d006 -a 0 -s 0x8020000 -D system-part1-0.5.3-rc.2-photon.bin
dfu-util -d 2b04:d006 -a 0 -s 0x8060000:leave -D system-part2-0.5.3-rc.2-photon.bin
P1:
dfu-util -d 2b04:d008 -a 0 -s 0x8020000 -D system-part1-0.5.3-rc.2-p1.bin
dfu-util -d 2b04:d008 -a 0 -s 0x8060000:leave -D system-part2-0.5.3-rc.2-p1.bin
Electron:
dfu-util -d 2b04:d00a -a 0 -s 0x8020000 -D system-part1-0.5.3-rc.2-electron.bin
dfu-util -d 2b04:d00a -a 0 -s 0x8040000 -D system-part2-0.5.3-rc.2-electron.bin
Downgrading from 0.5.3-rc.2 to current default firmware
Current defaults
Core: v0.5.2
Photon: v0.5.2
P1: v0.5.2
Electron: v0.5.2
The easiest way to downgrade from a 0.5.3-rc.2 prerelease system firmware, is to use the CLI and run these commands in order. First put the Tinker back on the device, then downgrade the System firmware. This requires CLI version 1.14.2. You can check with particle --version.
  1. Make sure Tinker is installed, instead of a 0.5.3-rc.2 app that you may currently have running on your device. Have the device in DFU mode and run:
particle update
This works for downgrading without specifying --target X.Y.Z because the 0.5.3-rc.2 pre-release firmware is not the default, and therefor particle update effectively downgrades your firmware.
[RESOLVED]Web IDE - not verifying/compiling!
How can we select different serial configuration other than default, such as "8E1", is it supported?
#32
Firmware 0.6.0-rc.1 Pre-release is out on the Build IDE for Core/Photon/P1/Electron
This is a big one!
  • The majority of Docs updates for 0.6.0 are going to roll out and be live between now and tomorrow sometime.
  • Please make sure to update your CLI to v1.16.0 for proper handling of 3 system parts for Electron.
  • You must update your Electron to v0.5.3-rc.2 first before attempting to use OTA or YModem transfer to update to v0.6.0-rc.1. If you use DFU over USB, you can update to v0.6.0-rc.1 directly, but make sure you have installed v1.16.0 of the CLI first.
060rc1
(minor known issue with 060rc1 being located lower and out of order in the dropdown)
BREAKING CHANGES
  • UDP.flush() and TCP.flush() now conform to the Stream.flush() behavior from Arduino 1.0 Wiring. The current (correct) behavior is to wait
    until all data has been transmitted. Previous behavior discarded data in the buffer. #469
FEATURES
  • Logging library for flexible system and application logging. Docs
  • [Electron] Reduced data consumption connecting to the cloud with deep sleep. (See the Docs for how to gain the full data reduction.) #953
  • Can set Claim Code via the Serial interface (for use by the CLI.) #602
  • Device ID available via dfu-util. #949
  • [Electron] Firmware Reset now available. #975 and Docs
  • System Reset Reason #403 Docs
  • [Photon/Electron/P1] Composite USB device driver with HID Mouse & Keyboard implementation for STM32F2 #902 and #528
  • Exposes Device ID and Bootloader Version through USB descriptors while in DFU mode, Microsoft WCID support #1001
  • USB vendor-specific setup request handling #1010
  • [Electron] now allows OTA bootloader updates #1002
  • Added Daylight Saving Time support #1058 per proposed #211 Docs
ENHANCEMENTS
  • Local build warns if crc32 is not present. #941
  • [Photon/Core] MAC address is available immediately after WiFi.on() #879
  • [virtual device] support for TCP Server #1000
  • [virtual device] support for EEPROM emulation #1004
  • Low-level RTOS queues exposed in HAL #1018
  • USART LIN bus support. #930 Docs
  • USART added support for 7E1, 7E2, 7O1, 7O2 modes. #997 Docs
  • Configurable resolution for analogWrite (PWM and DAC) #991 analogWrite() Docs | analogWriteResolution() Docs | analogWriteMaxFrequency() Docs
  • System flag SYSTEM_FLAG_RESET_NETWORK_ON_CLOUD_ERRORS to control if the device resets the network when it cannot connect to the cloud. #946
  • [Photon] 1KB system backup memory added (same size as Electron) reducing user backup memory to 3KB (3068 bytes) #1046
  • Automatically adds vendored libraries from the lib directory for extended application projects #1053
  • Extended spi_master_slave tests with SPI_MODE0/1/2/3 and MSBFIRST/LSBFIRST testing #1056
  • [Electron] System parts reordered from 3,1,2 to 1,2,3 to preserve logical flashing order for OTA/YModem when upgrading. #1065
BUGFIXES
  • digitalRead() interferes with analogRead() #993
  • USART 9-bit receiving. #968
  • Fix soft AP suffix broken by the addition of device id in DCT #1030
  • WKP pin should not be enabled as a wakeup source unconditionally for STOP mode #948 and #938
  • System.sleep SLEEP_MODE_DEEP timing accuracy and sleep STOP mode retains user interrupt handler after resuming #1051 fixes #1043 and #1029
INTERNAL
  • [Electron] Use floating point arithmetic in PWM to save about 1KB of flash space #1027
  • Feature/vendorlibraries #1009
  • [Electron] Added a 3rd system module to provide room for additional system firmware #1035
  • Remove accidental SYSTEM_MODE(MANUAL) from pwm.cpp in wiring/no_fixture #1052
To update your device, compile and flash your application in the Build IDE, selecting version 0.6.0-rc.1 (prerelease) in the devices drawer. Update instructions for Core, Photon, P1 and Electron below.
Core:
particle flash YOUR_DEVICE_NAME tinker-0.6.0-rc.1-core.bin
Photon:
particle flash YOUR_DEVICE_NAME system-part1-0.6.0-rc.1-photon.bin
particle flash YOUR_DEVICE_NAME system-part2-0.6.0-rc.1-photon.bin
P1:
particle flash YOUR_DEVICE_NAME system-part1-0.6.0-rc.1-p1.bin
particle flash YOUR_DEVICE_NAME system-part2-0.6.0-rc.1-p1.bin
Electron:
particle flash YOUR_DEVICE_NAME system-part1-0.6.0-rc.1-electron.bin
particle flash YOUR_DEVICE_NAME system-part2-0.6.0-rc.1-electron.bin
particle flash YOUR_DEVICE_NAME system-part3-0.6.0-rc.1-electron.bin
This requires CLI version 1.16.0 or newer. You can check with particle --version.
Core:
particle flash --usb tinker-0.6.0-rc.1-core.bin
Photon:
particle flash --usb system-part1-0.6.0-rc.1-photon.bin
particle flash --usb system-part2-0.6.0-rc.1-photon.bin
P1:
particle flash --usb system-part1-0.6.0-rc.1-p1.bin
particle flash --usb system-part2-0.6.0-rc.1-p1.bin
Electron:
particle flash --usb system-part1-0.6.0-rc.1-electron.bin
particle flash --usb system-part2-0.6.0-rc.1-electron.bin
particle flash --usb system-part3-0.6.0-rc.1-electron.bin
Core:
dfu-util -d 1d50:607f -a 0 -s 0x8005000:leave -D tinker-0.6.0-rc.1-core.bin
Photon:
dfu-util -d 2b04:d006 -a 0 -s 0x8020000 -D system-part1-0.6.0-rc.1-photon.bin
dfu-util -d 2b04:d006 -a 0 -s 0x8060000:leave -D system-part2-0.6.0-rc.1-photon.bin
P1:
dfu-util -d 2b04:d008 -a 0 -s 0x8020000 -D system-part1-0.6.0-rc.1-p1.bin
dfu-util -d 2b04:d008 -a 0 -s 0x8060000:leave -D system-part2-0.6.0-rc.1-p1.bin
Electron:
dfu-util -d 2b04:d00a -a 0 -s 0x8060000 -D system-part1-0.6.0-rc.1-electron.bin
dfu-util -d 2b04:d00a -a 0 -s 0x8020000 -D system-part2-0.6.0-rc.1-electron.bin
dfu-util -d 2b04:d00a -a 0 -s 0x8040000 -D system-part3-0.6.0-rc.1-electron.bin
Downgrading from 0.6.0-rc.1 to current default firmware
Current defaults
Core: v0.5.2
Photon: v0.5.2
P1: v0.5.2
Electron: v0.5.2
The easiest way to downgrade from a 0.6.0-rc.1 prerelease system firmware, is to use the CLI and run these commands in order. First put the Tinker back on the device, then downgrade the System firmware. This requires CLI version 1.15.0. You can check with particle --version.
  1. Make sure Tinker is installed, instead of a 0.6.0-rc.1 app that you may currently have running on your device. Have the device in DFU mode and run:
particle update
This works for downgrading without specifying --target X.Y.Z because the 0.6.0-rc.1 pre-release firmware is not the default, and therefor particle update effectively downgrades your firmware.
System.sleep and WKP Pin
Firmware Pre-Release Docs for v0.6.0-rc.2
How to use the lib directory in 0.6.0-rc1+
#33
Firmware 0.6.0-rc.2 Pre-release is out on the Build IDE for Core/Photon/P1/Electron
More Updates!
  • Please make sure to update your CLI to >= v1.16.0 for proper handling of 3 system parts for Electron.
  • You must update your Electron to >= v0.5.3-rc.2 first before attempting to use OTA or YModem transfer to update to v0.6.0-rc.2. If you use DFU over USB, you can update to v0.6.0-rc.2 directly, but make sure you have installed >= v1.16.0 of the CLI first.
0 6 0-rc 2
v0.6.0-rc.2
ENHANCEMENTS
  • USB HID enhancements, please see PR: #1110 for a list. Closes #1096
BUGFIX
  • Consecutive HID reports were overwriting previous the report before it was delivered to the host. Fixes #1090.
  • Disabling multiple USB configurations (normal/high power) as this breaks composite driver on Windows. Fixes #1089 Serial and USBSerial1 not working at same time on Windows 8.1 Pro.
  • Do not run the event loop from delay() when threading is enabled. Fixes #1055
  • Cancel current connection attempt before entering the listening mode with WiFi.listen(true) and also WiFi.off(). Fixes #1013
INTERNAL
  • Removed hardcoded server IP that was used when DNS resolution fails. Instead, the cloud connection is failed and the system will have to retry. This means DNS lookup failure is now consistent with other modes of connection failure. Addresses #139 Related to #1024
To update your device, compile and flash your application in the Build IDE, selecting version 0.6.0-rc.2 (prerelease) in the devices drawer. Update instructions for Core, Photon, P1 and Electron below.
Core:
particle flash YOUR_DEVICE_NAME tinker-0.6.0-rc.2-core.bin
Photon:
particle flash YOUR_DEVICE_NAME system-part1-0.6.0-rc.2-photon.bin
particle flash YOUR_DEVICE_NAME system-part2-0.6.0-rc.2-photon.bin
P1:
particle flash YOUR_DEVICE_NAME system-part1-0.6.0-rc.2-p1.bin
particle flash YOUR_DEVICE_NAME system-part2-0.6.0-rc.2-p1.bin
Electron:
particle flash YOUR_DEVICE_NAME system-part1-0.6.0-rc.2-electron.bin
particle flash YOUR_DEVICE_NAME system-part2-0.6.0-rc.2-electron.bin
particle flash YOUR_DEVICE_NAME system-part3-0.6.0-rc.2-electron.bin
Core:
particle flash --usb tinker-0.6.0-rc.2-core.bin
Photon:
particle flash --usb system-part1-0.6.0-rc.2-photon.bin
particle flash --usb system-part2-0.6.0-rc.2-photon.bin
P1:
particle flash --usb system-part1-0.6.0-rc.2-p1.bin
particle flash --usb system-part2-0.6.0-rc.2-p1.bin
Electron:
particle flash --usb system-part1-0.6.0-rc.2-electron.bin
particle flash --usb system-part2-0.6.0-rc.2-electron.bin
particle flash --usb system-part3-0.6.0-rc.2-electron.bin
Core:
dfu-util -d 1d50:607f -a 0 -s 0x8005000:leave -D tinker-0.6.0-rc.2-core.bin
Photon:
dfu-util -d 2b04:d006 -a 0 -s 0x8020000 -D system-part1-0.6.0-rc.2-photon.bin
dfu-util -d 2b04:d006 -a 0 -s 0x8060000:leave -D system-part2-0.6.0-rc.2-photon.bin
P1:
dfu-util -d 2b04:d008 -a 0 -s 0x8020000 -D system-part1-0.6.0-rc.2-p1.bin
dfu-util -d 2b04:d008 -a 0 -s 0x8060000:leave -D system-part2-0.6.0-rc.2-p1.bin
Electron:
dfu-util -d 2b04:d00a -a 0 -s 0x8060000 -D system-part1-0.6.0-rc.2-electron.bin
dfu-util -d 2b04:d00a -a 0 -s 0x8020000 -D system-part2-0.6.0-rc.2-electron.bin
dfu-util -d 2b04:d00a -a 0 -s 0x8040000 -D system-part3-0.6.0-rc.2-electron.bin
Downgrading from 0.6.0-rc.2 to current default firmware
Current defaults
Core: v0.5.2
Photon: v0.5.2
P1: v0.5.2
Electron: v0.5.2
The easiest way to downgrade from a 0.6.0-rc.2 prerelease system firmware, is to use the CLI and run these commands in order. First put the Tinker back on the device, then downgrade the System firmware. This requires CLI version 1.15.0. You can check with particle --version.
  1. Make sure Tinker is installed, instead of a 0.6.0-rc.2 app that you may currently have running on your device. Have the device in DFU mode and run:
particle update
This works for downgrading without specifying --target X.Y.Z because the 0.6.0-rc.2 pre-release firmware is not the default, and therefor particle update effectively downgrades your firmware.
Cannot open DFU device! Electron
Electron stuck in safe mode after flashing
Safe mode explained
#34
Firmware 0.5.3 is out on the Web IDE for Core/Photon/P1/Electron - and the Particle CLI has been updated from 1.16.0 to 1.17.0
Note: This is a Release and may be used for production. Any known issues are likely slated for 0.7.0-rc.1 (check Github issues). It is available by default for all devices. To use, select the 0.5.3 version dropdown from the devices drawer.
Note: If you have previously last used one of the prerelease versions of 0.5.3 on a Core/Photon/P1 device, please re-flash it with 0.5.3. You must upgrade (locally preferred) the Electron system firmware to 0.5.3 first before you can OTA new user apps.
0 5 3
v0.5.3 Changelog
FEATURE
ENHANCEMENTS
INTERNAL
BUGFIXES
System Binaries (all devices) & Firmware Manager (Photon & Electron)
Programming and Debugging
You can view specific programming and debugging notes for this version of firmware here.
Electron Firmware and Dev
Particle update command
PHOTON HARD FAULT - not recover
#35
Hey all!
We just updated latest and master branches of the firmware repo to be current with release/v0.5.3.
Because we had to force push these changes, you’ll likely have merge conflicts if you git pull the latest changes for those branches. Because of this you will need to hard reset your local copy of each branch to match the remote.
:warning: Before doing this, make sure you save any changes you have been making in your local copy of latest or master (hopefully you are not doing that though and using a feature/branch based on these ;-))
Hard Reset Lastest
git checkout latest && git fetch origin && git reset --hard origin/latest
Hard Reset Master
git checkout master && git fetch origin && git reset --hard origin/master
You should now be sync’d up again with the most recent latest and master
Also, some changes to note:
The latest branch is being depreciated, and release/stable is taking it’s place. We will reiterate this during the 0.6.0 release which is coming.
We also have release/stable-0.5.x which is the latest 0.5.x default release (as of this post it’s 0.5.3)
Issue controlling 5 servos with a single Photon
#36
Firmware 0.6.0 is out on the Web IDE for Core/Photon/P1/Electron - and the Particle CLI has been updated to 1.18.0
Note: This is a Release and may be used for production. Any known issues are likely slated for 0.7.0-rc.1 (check Github issues). It is available by default for all devices. To use, select the 0.6.0 version dropdown from the devices drawer.
Note: If you have previously last used one of the prerelease versions of 0.6.0 on a Core/Photon/P1 device, please re-flash it with 0.6.0. You must upgrade (locally preferred) the Electron system firmware to 0.6.0 first before you can OTA new user apps.
Note: You must update your Electron to (v0.5.3, v0.5.3-rc.2, or v0.5.3-rc.3) first before attempting to use OTA or YModem transfer to update to v0.6.0. If you use DFU over USB, you can update to v0.6.0 directly, but make sure you have installed v1.18.0 of the CLI first.
0 6 0
v0.6.0 (same as v0.6.0-rc.2)
BREAKING CHANGES
FEATURES
ENHANCEMENTS
BUGFIXES
INTERNAL
You can view specific programming and debugging notes for this version of firmware here programming and debugging notes for this version of firmware here.
Particle Tools Changelog
Particle Dev Tips
#37
Hey all!
We updated release/stable and master branches of the firmware repo to be current with release/v0.6.0.
:exclamation: release/stable is taking the place of latest which will be deleted :no_entry_sign:
:warning: Before doing this, make sure you save any changes you have been making in your local copy of release/stable or master (hopefully you are not doing that though and using a feature/branch based on these ;-))
Hard Reset release/stable
git checkout release/stable && git fetch origin && git reset --hard origin/release/stable
Hard Reset master
You should now be sync’d up again with the most recent release/stable and master, you will see:
HEAD is now at d17554a automate the Core build and binary collection
Just to reiterate from last time:
#38
Firmware 0.6.1-rc.1 Pre-release is out on the Web IDE for Core/Photon/P1/Electron
061rc1
0.6.1-rc.1 Changelog
FEATURES
  • [PR #1190] [Implements #1114] Added ability to mirror MODE/SETUP button to any GPIO, available from time of boot, active high or low.
  • [PR #1182] [Fixes #687] [Docs] Added WiFi.set|getListenTimeout() | Cellular.set|getListenTimeout() to override the automatic new Listening Mode timeout (Wi-Fi = no timeout by default, Cellular = 5 minute timeout by default).
  • [PR #1154] Added low_battery system event, which is generated when low battery condition is detected. This is when the battery falls below the SoC threshold (default 10%, max settable 32%). The event can only be generated again if the system goes from a non-charging to charing state after the event is generated. The event doesn’t carry any data.
  • [PR #1144] Added tracking of ACKs for published events (see WITH_ACK flag for Particle.publish())
  • [PR #1135] [Fixes #1116] [Fixes #965] New Time API’s! Time.isValid() | Particle.syncTimePending() | Particle.syncTimeDone() | Particle.timeSyncedLast()
  • [PR #1127] [PR #1213] Added support for runtime logging configuration, which allows to enable logging on already running system via USB control requests. Disabled by default to save flash memory space. (note: this feature is not fully baked with tool support)
  • [PR #1120] [Implements #1059] [P1] Added extra spare pin to P1 (P1S6) with GPIO and PWM support.
  • [PR #1204] [Implements #1113] RGB LED pins can be mirrored to other PWM capable pins via RGB.mirrorTo(). Common Anode/Cathode LED and Bootloader compatible. See PR for usage.
  • [PR #1205] [Closes #569] [Closes #976] [Closes #1111] By implementing a centralized LED service and theme “engine” for system LED signaling, giving users the ability to apply custom LED colors and patterns for system events.
ENHANCEMENTS
  • [PR #1191] Added more Arduino Library compatibility
  • [PR #1188] [Implements #1152] Added SPI API’s: SPISettings | SPI.beginTransaction() | SPI.endTransaction()
  • [PR #1169] Updated system communication logging with new logging API
  • [PR #1160] [Electron] Modem USART paused via HW_FLOW_CONTROL (RTS) before going into sleep with SLEEP_NETWORK_STANDBY. Receives and buffers small messages while system sleeping.
  • [PR #1159] [Closes #1085] [Closes #1054] Added support for GCC 5.4.x
  • [PR #1151] [Closes #977] Added System events for cloud/network connection state changes
  • [PR #1122] Attach to host even if Serial, USBSerial1 and Keyboard/Mouse are disabled, so that “Control Interface” that receives vendor requests is still accessible.
  • [PR #1097] [Implements #1032] When flashing (OTA/YModem) an invalid firmware binary (that the device ignores) it will post an event describing why the binary was not applied.
  • [PR #1203] [PR #1212] Automatic bootloader updates have returned to the Electron. v9 bootloader has been added to firmware release >=0.6.1-rc.1 for Photon/P1/Electron. After updating your system firmware, a new v9 bootloader will be applied to your device if required. v9 includes support for SETUP/MODE button and RGB LED mirroring at the bootloader level of operation. Also included are updates to USB DFU mode so that Windows users do not need to install separate drivers via Zadig. Bootloader GREEN and WHITE LED flashing speeds (Firmware Reset modes) are faster now as well (you won’t see these unless you have loaded user firmware to the Backup location).
  • [PR #1125] Breaks on-going network connection when Sleep stop mode is called, thereby speeding up the time to entering sleep when using SYSTEM_THREAD(ENABLED).
BUGFIX
  • [PR #1186] Fixed issue where USB Serial might deadlock when interrupts are disabled while using DEBUG_BUILD=y
  • [PR #1179] [Fixes #1178] [Fixes #1060] [Electron] Bootloader build was failing, fixed and added to CI.
  • [PR #1158] [Fixes #1133] [Electron] Before sleeping, now waits for server sent confirmable messages to be acknowledged, in addition to previous behavior of device generated confirmable messages being acknowledged. Reduces data usage.
  • [PR #1156] [Fixes #1155] System.sleep(30) wasn’t reapplying power to the network device after set time.
  • [PR #1147] [Electron] Fixed approx. -0.1V offset on FuelGauge().getVCell() readings
  • [PR #1145] [Fixes #973] Particle.connect() now blocks loop() from running until Particle.connected() is true in single threaded SEMI_AUTOMATIC mode.
  • [PR #1140] [Fixes #1138] [Fixes #1104] [Electron] Fixed modem USART and buffer handling
  • [PR #1130] Particle.subscribe() used with same events but changing scope between PUBLIC and PRIVATE or vice versa would potentially result in non-registered subscriptions. This was also crashing the GCC virtual device with a segfault when subscription checksums were calculated.
INTERNAL
  • [PR #1196] Re-enable GNU extensions for libc globally. Fixes build with ARM GCC 4.9.3 Q1.
  • [PR #1189] Typo caused a warning during compilation in wiring/no_fixture Cellular tests.
  • [PR #1184] [Electron] moved cellular HAL and its direct dependencies from module 2 to module 3 to free up space (this is system-part3 was reduced in size, while system-part1 was increased)
  • [PR #1167] [Fixes #1036] [GCC Virtual Device] workaround for 100% CPU usage problem.
  • [PR #1146] [Closes #1040] Added asserts for checking that network calls are run on system thread.
  • [PR #1134] [GCC Virtual Device] Error in socket_hal’s socket_receive() logic caused random cloud connection errors.
LED Signaling Themes?
Electron Lipo current in deep sleep mode
#39
#40
Hey all!
I’m working on releasing 0.6.1-rc.1 firmware docs to the prerelease-docs site, and I had some troubles with git subtrees. Maybe some of you feel my pain if you’ve used subtrees :smile:
If you use the develop branch of the firmware repo, read on… otherwise please disregard below the fold.
I just had to force push develop back to the way it was earlier today. Because of this you’ll likely have merge conflicts if you git pull the latest changes from develop. You will need to hard reset your local copy of develop to match the remote.
:warning: Before doing this, make sure you save any changes you have been making in your local copy of develop (hopefully you are not doing that though and using a feature/branch based on these ;-))
Hard Reset develop
git checkout develop && git fetch origin && git reset --hard origin/develop
You should now be sync’d up again with the most recent develop, you will see:
HEAD is now at b82c352 added LED Themes to 0.6.1-rc.1 Changelog [ci skip]
#41
Firmware 0.6.1-rc.2 Pre-release is out on the Web IDE for Core/Photon/P1/Electron
released on production servers January 23, 2017
:warning: Please Note: The bootloader on Electron/Photon/P1 will update to v11 automatically with this update. Make sure your device is connected to a stable power source and do not remove power until after the device reboots and is running. It happens so quickly right after the device resets and boots that you won’t notice any special RGB LED signaling for this.
Note: You must update your Electron to v0.5.3 first before attempting to use OTA or YModem transfer to update to >= v0.6.0. If you use DFU over USB, you can update to >= v0.6.0 directly, but make sure you have installed v1.18.0 of the CLI first.
061rc2
0.6.1-rc.2 Changelog
FEATURES
  • [PR #1225] [Photon/P1/Electron] Added support for custom LED colors in bootloader v11 (Safe Mode, DFU Mode, Firmware Reset).
  • [PR #1227] [Implements #961] [Electron] Added new API for hostname IP address lookup IPAddress ip = Cellular.resolve(hostname)
ENHANCEMENTS
  • [PR #1216] Improved Arduino Compatibility (now supported by default, added PARTICLE_NO_ARDUINO_COMPATIBILITY=y command line option for disabling)
  • [PR #1217] Added Windows, Mac command, & Unix/Linux meta USB keyboard scancode definitions.
  • [PR #1224] Allow the compiler to garbage collect USBKeyboard and USBMouse implementations if they are not used in user code, saving flash space.
  • [PR #1225] [Photon/P1/Electron] Combined LEDStatus and LEDCustomStatus into a single class -> LEDStatus
BUG FIXES
  • [PR #1221] [Fixes #1220] [Electron] TIM8 PWM pins (B0, B1) did not work correctly in bootloader with RGB.mirrorTo()
  • [PR #1222] Fixed bug in String(const char* str, int len) constructor when the string is longer than the specified length.
  • [PR #1225] [Photon/P1/Electron] Fixed LED indication shown during device key generation (blinking white) introduced in 0.6.1-rc.1
  • [PR #1226] [Fixes #1181] [Photon/P1/Core] Process TCP DESCRIBE properly and return only one response, SYSTEM, APPLICATION, or COMBINED (ALL) describe message. Was sending separate SYSTEM and APPLICATION previously.
  • [PR #1230] Safe Mode event was being published unconditionally introduced in 0.6.1-rc.1
  • [PR #1231] [Electron] fixes double newline parser issue on G350 introduced in 428835a 0.6.1-rc.1
#42
Firmware 0.6.1 release is out on the Web IDE for Core/Photon/P1/Electron
released on production servers March 1, 2017
Note: This is a Release and may be used for production. Any known issues are likely slated for 0.7.0-rc.1 (check Github issues). It is available by default for all devices. To use, select the 0.6.1 version dropdown from the devices drawer.
Note: If you have previously last used one of the prerelease versions of 0.6.1 on a Core/Photon/P1 device, please re-flash it with 0.6.1. You must upgrade (locally preferred) the Electron system firmware to 0.6.1 first before you can OTA new user apps.
Note: You must update your Electron to (v0.5.3, v0.5.3-rc.2, or v0.5.3-rc.3) first before attempting to use OTA or YModem transfer to update to v0.6.0. If you use DFU over USB, you can update to v0.6.1 directly, but make sure you have installed v1.20.1 of the CLI first.
Note: As a Product in the Console, when flashing a >= 0.6.0 user app, Electrons can now Safe Mode Heal from < 0.5.3 to >= 0.6.0 firmware. This will consume about 500KB of data as it has to transfer two 0.5.3 system parts and three >= 0.6.0 system parts. Devices will not automatically update system firmware if not added as a Product in Console.
061
0.6.1 Changelog (same as v0.6.1-rc.2)
FEATURES
  • [PR #1190] [[Implements #1114]] (https://github.com/spark/firmware/issues/1114) [Docs] Added ability to mirror MODE/SETUP button to any GPIO, available from time of boot, active high or low.
  • [PR #1154] [Docs] Added low_battery system event, which is generated when low battery condition is detected. This is when the battery falls below the SoC threshold (default 10%, max settable 32%). The event can only be generated again if the system goes from a non-charging to charing state after the event is generated. The event doesn’t carry any data.
  • [PR #1144] [Docs] Added tracking of ACKs for published events (see WITH_ACK flag for Particle.publish())
  • [PR #1135] [Fixes #1116] [Fixes #965] [Docs] New Time API’s! Time.isValid() | Particle.syncTimePending() | Particle.syncTimeDone() | Particle.timeSyncedLast()
  • [PR #1120] [Implements #1059] [P1] [Docs] [Pinout] Added extra spare pin to P1 (P1S6) with GPIO and PWM support.
  • [PR #1204] [Implements #1113] [Docs] RGB LED pins can be mirrored to other PWM capable pins via RGB.mirrorTo(). Common Anode/Cathode LED and Bootloader compatible. See PR for usage.
  • [PR #1205] [Closes #569] [Closes #976] [Closes #1111] [Docs] By implementing a centralized LED service and theme “engine” for system LED signaling, giving users the ability to apply custom LED colors and patterns for system events.
  • [PR #1225] [Photon/P1/Electron] [Docs] Added support for custom LED colors in bootloader v11 (Safe Mode, DFU Mode, Firmware Reset).
  • [PR #1227] [Implements #961] [Electron] [Docs] Added new API for hostname IP address lookup IPAddress ip = Cellular.resolve(hostname)
ENHANCEMENTS
  • [PR #1188] [Implements #1152] [Docs] Added SPI API’s: SPISettings | SPI.beginTransaction() | SPI.endTransaction()
  • [PR #1151] [Closes #977] [Docs] Added System events for cloud/network connection state changes
  • [PR #1203] [PR #1212] Automatic bootloader updates have returned to the Electron. v9 bootloader has been added to firmware release >=0.6.1-rc.1 for Photon/P1/Electron. After updating your system firmware, a new v9 bootloader will be applied to your device if required. v9 includes support for SETUP/MODE button and RGB LED mirroring at the bootloader level of operation. Also included are updates to USB DFU mode so that Windows users do not need to install separate drivers via Zadig. Bootloader GREEN and WHITE LED flashing speeds (Firmware Reset modes) are faster now as well (you won’t see these unless you have loaded user firmware to the Backup location). Note: this release 0.6.1 includes all of these changes as v11 which fixed some bugs in v9.
  • [PR #1217] [Docs] Added Windows, Mac command, & Unix/Linux meta USB keyboard scancode definitions.
BUG FIXES
  • [PR #1147] [Electron] [Docs] Fixed approx. -0.1V offset on FuelGauge().getVCell() readings
INTERNAL
Problem compiling RGBMATRIX lib on Desktop IDE
Keepalives between sleep (stop mode) periods
