Device OS 1.3.1 Default Release is out on the Web IDE for (Core/Photon/P1/Electron/Argon/Boron/Xenon/A SoM/B SoM/X SoM)
released on production servers September 6th, 2019
Please read all notes below
Note: This is a Release and may be used for production. Any known issues are likely slated for a future version, (check Github issues). It is available by default for all devices. To use, select the 1.3.1 version dropdown from the devices drawer.
Downgrading back to a previous release info is at the bottom of this post.Note: If you have previously last used one of the prerelease versions of 1.3.x-rc.x on a device, please re-flash it with 1.3.1.
- Then update to 1.3.1
- You may update to 1.3.1 directly first, flash the system firmware (attached above) in order 1,2(,3) to the device using
. See the next note about the bootloader if you are offline!Note: P1/Photon Bootloader
The Cloud will automatically update the bootloader on P1/Photon devices if your device is online. If your device does not connect to the cloud and it is offline, you should flash the bootloader to the device usingparticle flash --serial <bootloader.bin>
. This should be done after upgrading system firmware. The Electron bootloader is applied automatically from it's own system parts.Note: Argon/Boron/Xenon/Argon-SoM/Boron-SoM/Xenon-SoM Bootloader
If your device is offline, the bootloader must be manually updated usingparticle flash --serial <bootloader.bin>
. This can be done before or after upgrading system firmware.Note: Downgrading [Electron/Photon/P1] OTA or YModem transfer:
1.3.1
Note: If your Gen 2 Photon/P1 or Gen 3 device does not have a Cloud connection, it is recommended to update system firmware via CLI with
particle update
. Electron bootloaders are still contained in system firmware and will update automatically as needed.
This release contains v401 bootloaders.
SoftDevice update
Customers affected by https://github.com/particle-iot/device-os/issues/1855 may manually update the Nordic SoftDevice S140 to version 7.0.0 using the binaries provided in this release.
Starting with 1.4.0 (final) Device OS update will automatically trigger SoftDevice update.
Prerequisites
particle-cli version 1.46.1.
Upgrading OTA
- Upgrade to 1.3.1
- Manually flash 1.3.1 bootloader:
particle flash <deviceId> boron-bootloader@1.3.1.bin
- Flash SoftDevice:
particle flash <deviceId> boron-softdevice@1.3.1.bin
Upgrading using YModem
- Upgrade to 1.3.1
particle flash --serial boron-bootloader@1.3.1.bin
- Flash SoftDevice:
particle flash --serial boron-softdevice@1.3.1.bin
- Upgrade Device OS to 1.3.1
- (optional, not required) Update the bootloader to 1.3.1 with the OTA or YModem process above
- Flash the SoftDevice:
particle flash --usb boron-softdevice@1.3.1.bin
FEATURES
- [gen 3] Nordic SoftDevice update support #1816
- [gen 3] API for selecting BLE antenna for BLE radio #1847
- [gen 3] API for setting/getting BLE device name #1847
- [gen 3] API for setting BLE device address #1847
- [gen 3] API for manually discovering peer device's BLE services and characteristics #1847
- [gen 3] API for fetching discovered peer's services and characteristics #1847
- [gen 3] API in BlePeerDevice for establishing BLE connection without scanning required #1847
- [gen 3] API for manually subscribing/unsubscribing peer characteristic's notification #1847
- [gen 3] API for disconnecting all on-going BLE connections #1847
- [gen 3] BLE support #1740
- [gen 3] NFC support #1606
ENHANCEMENTS
- [Boron/BSoM] power: Increases charging current to 900mA when powered through VIN (VUSB) pin #1846
- Cancel network connection when processing a USB request that resets the device #1830
- Particle.connected() should return true only after handshake messages are acknowledged #1825
- [gen 3] USB state tracking enhancements #1871
- [gen 3] Adds timeouts to I2C HAL operations #1875
- [gen 3] Refactors BLE event dispatching #1847
- [gen 3] Decreases BLE runtime RAM consumption #1847
- [gen 3] Supports up to 23 local characteristics, 20 of them are available for user application #1847
- [gen 3] Supports up to 3 central links #1847
- [gen 3] More convenient methods provided in BleUuid class #1847
- ensures AT interface is responsive #1886
- [enhancement] Cache cellular diagnostics #1810
- [enhancement] allow the bootloader to be flashed over DFU #1788
BUG FIXES
- [Gen 3] Fixes heap and application static RAM overlap introduced in 1.3.0-rc.1 #1898
- Fixes tinker build errors when building with
LOG_SERIAL=y
#1898 - Fixes dynalib alignment issue when compiling relatively large applications potentially due to an unconfirmed bug in GCC by moving the dynalib into a separate section (
.dynalib
) #1894 - [Gen 3] Fixes incorrect handling of
MODULE_INFO_FLAG_DROP_MODULE_INFO
in the bootloader #1897 - [Gen 3] Adds a dummy suffix to the NCP and SoftDevice modules' module info with unique SHA to cause the communication layer to detect the change in SYSTEM DESCRIBE after NCP or SoftDevice update #1897
- Fixes a regression introduced in 1.1.0 where the system layer was always sending its handshake messages even if the session was resumed causing increased data usage #1905
- Properly seeds
rand()
in multiple threads including system thread. Fixes ephemeral port allocation in LwIP on Gen 3 platforms #1905 - Control requests that reset the device (e.g.
particle usb dfu
) no longer cause unnecessary reconnection to the cloud #1905 - Initialize user module in monolithic builds #1905
- fixes RSSI regression on G350 (2G) devices #1841
- [electron, gen3] Temporarily increase IDLE task priority whenever a thread exits (calls vTaskDelete) to resolve a memory leak that resulted in device being stuck "blinking green" until reset in some cases. #1862
- [gen 3] Fixes mesh pub/sub socket consuming all packet buffers #1839
- [Photon/P1] Bootloader correctly re-imports the DCT functions from system firmware after its modification through DFU #1868
- [gen 3]
Mesh.off()
disconnects the cloud. Resolves an issue withloop()
not being executed inSEMI_AUTOMATIC
mode afterMesh.off()
#1857 - [Argon] Fixes the issue being unable to reset the device through RST pin by changing the ESPEN mode to
OUTPUT_OPEN_DRAIN
#1870 - [Electron/LTE] devices drop Cloud connection every time user firmware opens and closes a TCP socket ch34976 #1854
- [gen 2] Fixes an issue with clock stretching in I2C slave mode with underrun reads with certain I2C masters (e.g. Gen 3 devices) #1829
- Fix to ensure device resets after bootloader update #1873
- Fixes boot issue for Core introduced in 1.2.1-rc.3 #1873
- [gen 3] Resolved a HardFault after USB cable is unplugged under certain conditions #1871
- [gen 3] BLE advertising parameters didn't apply, issue #1874 #1847
- [gen 3] BLE scanning parameters didn't apply, issue #1859 and #1855 #1847
- [gen 3] Local characteristic notification causes SOS: #1847
- [gen 3] BLE address order reversed #1847
- [gcc] fixes virtual platform exception on startup #1878
- Add two-digit mnc diagnostic flag #1804
- BLE fixes from 1.3.0-alpha.1 #1817
- NFC Context parameter is missing and NFC.update() will remove callback, fixes from 1.3.0-alpha.1 #1818
- [lte] cellular fixes #1824
- fixes #1811 - increases the number of event handlers to 6 #1822
- [gen 3] fixes memory usage diagnostics (reported negative values in safe mode) #1819
- System.disableUpdates() operates asynchronously #1801
- [gen 3] [bsom] Building platform BSOM results flash overflow. #1802
- [gen 3] [hal] fixes early wakeup by RTC from STOP sleep mode #1803
INTERNAL
- Adjusts on-device tests #1898
- Add coverage to CMake unit-tests #1860
- Pull test implementation out of source file #1867
- [gen 3] Changes WKP pin to A7 for SoM platforms to avoid an overlap with Ethernet chip on EVB ESPEN mode to
OUTPUT_OPEN_DRAIN
#1837 - [hal] Fixes WIFIEN pin mode for ASoM #1889
- Refactor/move catch test #1869
- fixes to communications public interface #1863
- Refactors platform pinmap to be in platform-specific headers #1838
- Improve compatibility with recent versions of GCC #1806
- Set path to Boost libraries #1872
- [docs] Updates
spark_publish_vitals
and build scripts documentation. #1800 - [docs] update the test documentation #1683
System Binaries (all devices)
https://github.com/particle-iot/device-os/releases/download/v1.3.1/particle_device-os@1.3.1.zip
Programming and Debugging
