Device OS 1.5.4-rc.2 Release Candidate is out on the Web IDE for (Photon/P1/Electron/Argon/Boron/Xenon/B SoM/B5 SoM/Tracker)
released on October 15th, 2020
Note: This is a Release Candidate (RC) and is not intended for production yet. We've tested this RC to the best of our ability and we want to know what you think now! Please understand that some care and attention is necessary when testing this RC, and be sure to upgrade to the final release when it's available. This RC will not be available by default. To use you must select the version dropdown from the devices drawer. Downgrading back to the current release info is at the bottom of this post.
- Then update to 1.5.4-rc.2
- You may update to 1.5.4-rc.2 directly first, flash the system firmware (attached above) in order 1,2(,3) to the device using
. See the next note about the bootloader if you are offline!Note: P1/Photon Bootloader
The Cloud will automatically update the bootloader on P1/Photon devices if your device is online. If your device does not connect to the cloud and it is offline, you should flash the bootloader to the device usingparticle flash --serial <bootloader.bin>
. This should be done after upgrading system firmware. The Electron bootloader is applied automatically from it's own system parts.Note: Argon/Boron/Xenon/B SoM/B5 SoM
If your device is offline, the bootloader must be manually updated usingparticle flash --serial <bootloader.bin>
. This can be done before or after upgrading system firmware.Note: Argon/Boron/Xenon/B SoM/B5 SoM SoftDevice
If your device is offline, the SoftDevice must be manually updated using the CLI. See the instructions below.Note: Downgrading [Electron/Photon/P1] OTA or YModem transfer:
1.5.4-rc.2
Note: If your Gen 2 Photon/P1 or Gen 3 device does not have a Cloud connection, it is recommended to update system firmware, and then the bootloader via CLI with
particle flash --serial bootloader.bin
(bootloaders found in Github release). Electron bootloaders are still contained in system firmware and will update automatically as needed.
This release contains v502 bootloaders.
BUGFIXES
- Configure PMIC and FuelGauge interrupt pins as
INPUT_PULLUP
#2207 - [Gen 3 / Cellular] Do not use packet buffers from pool in TX path #2150
- [Gen 3 / Cellular] Call into LwIP PPP code to indicate
PPP_IP
protocol is finished #2150 - [Gen 3] Workaround when unable to obtain DNS servers from remote PPP peer #2165
- [Cellular] When resuming cellular connection, do not run
COPS=0
again to avoid triggering PLMN reselection #2139
System Binaries (all devices)
Programming and Debugging
SoftDevice update
Prerequisites
particle-cli version 2.8.1.
Upgrading OTA
- Upgrade to 1.5.4-rc.2
- Manually flash 1.5.4-rc.2 bootloader:
particle flash <deviceId> boron-bootloader@1.5.4-rc.2.bin
- Flash SoftDevice:
particle flash <deviceId> boron-softdevice@1.5.4-rc.2.bin
Upgrading using YModem
particle flash --serial boron-bootloader@1.5.4-rc.2.bin
- Flash SoftDevice:
particle flash --serial boron-softdevice@1.5.4-rc.2.bin
- Upgrade Device OS to 1.5.4-rc.2
- Update the bootloader to 1.5.4-rc.2 with the OTA or YModem process above
- Flash the SoftDevice:
particle flash --usb boron-softdevice@1.5.4-rc.2.bin
