Device OS 1.5.2 Default Release is out on the Web IDE for (Photon/P1/Electron/Argon/Boron/Xenon/B SoM/B5 SoM)
released on production servers May 20th, 2020
Please read all notes below :bowtie:
Note: This is a Release and may be used for production. Any known issues are likely slated for a future version, (check Github issues). It is available by default for all devices. To use, select the 1.5.2 version dropdown from the devices drawer.
Downgrading back to a previous release info is at the bottom of this post.Note: If you have previously last used one of the prerelease or release versions of 1.5.x on a device, please re-flash it with 1.5.2.
- Then update to 1.5.2
- You may update to 1.5.2 directly first, flash the system firmware (attached above) in order 1,2(,3) to the device using
. See the next note about the bootloader if you are offline!Note: P1/Photon Bootloader
The Cloud will automatically update the bootloader on P1/Photon devices if your device is online. If your device does not connect to the cloud and it is offline, you should flash the bootloader to the device usingparticle flash --serial <bootloader.bin>
. This should be done after upgrading system firmware. The Electron bootloader is applied automatically from it's own system parts.Note: Argon/Boron/Xenon/Argon-SoM/Boron-SoM/Xenon-SoM Bootloader
If your device is offline, the bootloader must be manually updated usingparticle flash --serial <bootloader.bin>
. This can be done before or after upgrading system firmware.Note: Argon/Boron/Xenon/Argon-SoM/Boron-SoM/Xenon-SoM SoftDevice
If your device is offline, the SoftDevice must be manually updated using the CLI. See the instructions below.Note: Downgrading [Electron/Photon/P1] OTA or YModem transfer:
1.5.2
Note: If your Gen 2 Photon/P1 or Gen 3 device does not have a Cloud connection, it is recommended to update system firmware via CLI with
particle update
. Electron bootloaders are still contained in system firmware and will update automatically as needed.
This release contains v502 bootloaders.
BUGFIXES
- [Boron / B SoM] LTE-M1 (SARA R4) radio unresponsive when sending certain amount of data within a period of time #2100 #2105
- [B5 SoM] Suspend program/erase opertion when QSPI flash init gives timeout error
ENHANCEMENTS
- [Boron/B SoM] Forward compatibility with 460800 baudrate on SARA R4-based devices to support >= 2.x downgrades #2104
- [Boron/B SoM] Enables hardware flow control on SARA R4-based devices with appropriate modem firmware version #2079 cc7adb7c46ea82383a5f948ea1dc898270a27a3c
System Binaries (all devices)
https://github.com/particle-iot/device-os/releases/download/v1.5.2/particle_device-os@1.5.2.zip
SoftDevice update
Prerequisites
particle-cli version 2.6.0.
Upgrading using particle update
- Put the device into DFU mode
- Run
particle update
DeviceOS, bootloader and SoftDevice should get correctly updated.
Upgrading OTA
- Upgrade to 1.5.2
- Manually flash 1.5.2 bootloader:
particle flash <deviceId> boron-bootloader@1.5.2.bin
- Flash SoftDevice:
particle flash <deviceId> boron-softdevice@1.5.2.bin
Upgrading using YModem
- Upgrade to 1.5.2
particle flash --serial boron-bootloader@1.5.2.bin
- Flash SoftDevice:
particle flash --serial boron-softdevice@1.5.2.bin
- Upgrade Device OS to 1.5.2
- Update the bootloader to 1.5.2 with the OTA or YModem process above
- Flash the SoftDevice:
particle flash --usb boron-softdevice@1.5.2.bin
Programming and Debugging
Branches
release/stable
and master
branches have been updated to point to v1.5.2
tag.
