Here’s a recap on how to get system firmware to your devices:
Update from Build (Web IDE) or CLI by flashing a new application. (Note that with the CLI you must use
particle flash
rather thanparticle compile
. This will flash 3 binaries - the application, system-part1 and system-part2. Do not interrupt the process. If the process is interrupted, then re-flash the application to reapply system firmware. -
At present, flashing from Particle Dev DOES NOT update system firmware. In that case, you need to update via the CLI. See below.
Updating via the CLI either using DFU mode or an OTA update. Both approaches are described here.
Thanks
