Device OS 1.5.1-rc.1 Release Candidate is out on the Web IDE for (Photon/P1/Electron/Argon/Boron/Xenon/B SoM/B5 SoM)
released on April 29th, 2020
:white_check_mark: This 1.5.1-rc.1 Release Candidate will be defaulted to 1.5.1 on May 6th, 2020 unless there are regressions found that require further patches. :pencil2: Testing on your applications is encouraged and appreciated, thank you! :bowing_man:
Note: This is a Release Candidate (RC) and is not intended for production yet. We've tested this RC to the best of our ability and we want to know what you think now! Please understand that some care and attention is necessary when testing this RC, and be sure to upgrade to the final release when it's available. This RC will not be available by default. To use you must select the version dropdown from the devices drawer. Downgrading back to the current release info is at the bottom of this post.
  4. Then update to 1.2.1 (if the current version is less than that)
  5. Then update to 1.5.1-rc.1
  • You may update to 1.5.1-rc.1 directly first, flash the system firmware (attached above) in order 1,2(,3) to the device using particle flash --usb <system-part.bin>. See the next note about the bootloader if you are offline!
Note: P1/Photon Bootloader
The Cloud will automatically update the bootloader on P1/Photon devices if your device is online. If your device does not connect to the cloud and it is offline, you should flash the bootloader to the device using particle flash --serial <bootloader.bin>. This should be done after upgrading system firmware. The Electron bootloader is applied automatically from it's own system parts.
Note: Argon/Boron/Xenon/B SoM/B5 SoM
If your device is offline, the bootloader must be manually updated using particle flash --serial <bootloader.bin>. This can be done before or after upgrading system firmware.
Note: Argon/Boron/Xenon/B SoM/B5 SoM SoftDevice
1.5.1-rc.1
Note: If your Gen 2 Photon/P1 or Gen 3 device does not have a Cloud connection, it is recommended to update system firmware, and then the bootloader via CLI with particle flash --serial bootloader.bin (bootloaders found in Github release). Electron bootloaders are still contained in system firmware and will update automatically as needed.
This release contains v501 bootloaders.
SoftDevice update
Prerequisites
particle-cli version 2.0.1.
Upgrading OTA
  1. Upgrade to 1.5.1-rc.1
  2. Manually flash 1.5.1-rc.1 bootloader: particle flash <deviceId> boron-bootloader@1.5.1-rc.1.bin
  3. Flash SoftDevice: particle flash <deviceId> boron-softdevice@1.5.1-rc.1.bin
Upgrading using YModem
  3. Manually flash 1.5.1-rc.1 bootloader: particle flash --serial boron-bootloader@1.5.1-rc.1.bin
  4. Flash SoftDevice: particle flash --serial boron-softdevice@1.5.1-rc.1.bin
  1. Upgrade Device OS to 1.5.1-rc.1
  2. Update the bootloader to 1.5.1-rc.1 with the OTA or YModem process above
  4. Flash the SoftDevice: particle flash --usb boron-softdevice@1.5.1-rc.1.bin
ENHANCEMENTS
  • [Argon] Increase the size of the ARP queue #2075
  • [Cellular] Increase registration timeout to 10 minutes #2072
  • [Electron / Boron] Make sure that SARA R4-based LTE devices report LTE Cat M1 access technology #2083
  • [B5 SoM] Enable hardware flow control on Quectel modems earlier in the initialization process #2069 #2071
  • [Vitals] Add CoAP transmitted, retransmitted counter diagnostics #2043
  • [Vitals] Add CoAP latency diagnostic #2050
  • Remove locking in some of the SPI and I2C APIs. SPI perofrmance tests #2088
  • Particle.process() no-op when called from custom threads #2085
  • [Electron] Minor log message changes when the modem is not responsive #2087
BUGFIXES
  • [Cellular] Fixes an issue with CGI (Cellular Global Identity) not available on some devices #2067
  • [Electron] Compatibility CellularSignal rssi and qual values generation for LTE devices using AT+UCGED #2070
  • [B5 SoM / Asset Tracker] Zero RSRP/RSRQ values from AT+QCSQ treated as errors #2078
  • [wiring] BLE: use delete for objects allocated with new #2081
  • [Gen 3] I2C HAL recovers the I2C bus on transmission errors #2084
  • [Gen 3] Devices should be able to enter STANDBY / Hibernate sleep mode without specifying any wake-up sources #2086
  • [Gen 3] Fix an issue with platform_user_ram.ld generation when the application path contains 'data' #2090
  • [wiring] Fix SPI macros polluting global namespace #2089
  • [system] firmware_update_failed and firmware_update_complete are mixed up 71a8eb56f8d34efbda46f5d547c92e32a42a2148
  • [system] Do not propagate non-critical network errors to communication layer ba6c9d863ed79cd036848329c3b89b3c0e84dbd0
  • [Gen 3] Fix a crash in netif_ext_callback_handler() when parsing unset event fields dd01b12ea6166b6b175c46348a2b4c180d779ead
System Binaries (all devices)
https://github.com/particle-iot/device-os/releases/download/v1.5.1-rc.1/particle_device-os@1.5.1-rc.1.zip
Programming and Debugging
