Dear all,
what is the difference between retired U-270 for Europe and E-270? Can I use e270 for the same things and programs as I did for U270?
Kind Regards,
Eva
Hi Eva-
The Electron has been deprecated and we recommend moving off of it. However, to answer your question you can use the e270 the way you would use the u270. Check out the electron datasheet for more info!
Colleen
