Device OS 1.4.0-rc.1 Release Candidate is out on the Web IDE for (Core/Photon/P1/Electron/Argon/Boron/Xenon/A SoM/B SoM/X SoM)
released on August 30th, 2019
:white_check_mark: This 1.4.0-rc.1 Release Candidate will be defaulted to 1.4.0 on September 10th, 2019 unless there are regressions found that require further patches. :pencil2: Testing on your applications is encouraged and appreciated, thank you! :bowing_man:
  4. Then update to 1.2.1 (if the current version is less than that)
  5. Then update to 1.4.0-rc.1
  • You may update to 1.4.0-rc.1 directly first, flash the system firmware (attached above) in order 1,2(,3) to the device using particle flash --usb <system-part.bin>. See the next note about the bootloader if you are offline!
Note: P1/Photon Bootloader
Note: Argon/Boron/Xenon/Argon-SoM/Boron-SoM/Xenon-SoM Bootloader
If your device is offline, the bootloader must be manually updated using particle flash --serial <bootloader.bin>. This can be done before or after upgrading system firmware.
1.4.0-rc.1
Note: If your Gen 2 device does not have a Cloud connection, it is recommended to update system firmware, and then the bootloader via CLI with particle flash --serial bootloader.bin (bootloaders found in Github release). Gen 3 devices should not need an updated bootloader this release.
This release contains v500 bootloaders.
SoftDevice update
Customers affected by https://github.com/particle-iot/device-os/issues/1855 may manually update the Nordic SoftDevice S140 to version 7.0.0 using the binaries provided in this release.
Starting with 1.4.0 (final) Device OS update will automatically trigger SoftDevice update.
Prerequisites
particle-cli version 1.43.3.
Upgrading OTA
  1. Upgrade to 1.4.0-rc.1
  2. Manually flash 1.4.0-rc.1 bootloader: particle flash <deviceId> boron-bootloader@1.4.0-rc.1.bin
  3. Flash SoftDevice: particle flash <deviceId> boron-softdevice@1.4.0-rc.1.bin
Upgrading using YModem
  3. Manually flash 1.4.0-rc.1 bootloader: particle flash --serial boron-bootloader@1.4.0-rc.1.bin
  4. Flash SoftDevice: particle flash --serial boron-softdevice@1.4.0-rc.1.bin
Upgrading using DFU (–usb only works for SoftDevice, not bootloader yet)
  1. Upgrade Device OS to 1.4.0-rc.1
  2. (optional, not required) Update the bootloader to 1.4.0-rc.1 with the OTA or YModem process above
  4. Flash the SoftDevice: particle flash --usb boron-softdevice@1.4.0-rc.1.bin
FEATURES
  • [Gen 3] Introduces BLE.begin() and BLE.end() wiring APIs #1890
  • [Gen 3] Exposes POSIX select() and poll() from socket HAL dynalib #1895
ENHANCEMENTS
BUGFIXES
  • [Gen 3] Fixes heap and application static RAM overlap introduced in 1.3.0-rc.1 #1898
  • Fixes tinker build errors when building with LOG_SERIAL=y #1898
  • [Gen 3] Restored default BLE device address is incorrect. #1891
  • [Gen 3] Read BLE device name might be contracted. #1891
  • [Gen 3] operator& of the BleCharacteristicProperty enum class doesn’t work as expected. #1891
  • [Gen 3] The length of got advertising and scan response data is not updated. #1891
  • Fixes dynalib alignment issue when compiling relatively large applications potentially due to an unconfirmed bug in GCC by moving the dynalib into a separate section (.dynalib) #1894
  • [Gen 3] Fixes incorrect handling of MODULE_INFO_FLAG_DROP_MODULE_INFO in the bootloader #1897
  • [Gen 3] Adds a dummy suffix to the NCP and SoftDevice modules’ module info with unique SHA to cause the communication layer to detect the change in SYSTEM DESCRIBE after NCP or SoftDevice update #1897
INTERNAL
  • [Photon / P1] Changes to support building combined images for the recent releases #1887
  • wiring/no_fixture test adjustments for Gen 2 and Gen 3 platforms #1898
  • Coveralls test coverage reports generated by Travis #1896
System Binaries (all devices)
https://github.com/particle-iot/device-os/releases/download/v1.4.0-rc.1/particle_device-os@1.4.0-rc.1.zip
Programming and Debugging
Device OS 1.3.1 Default Release is out on the Web IDE for (Core/Photon/P1/Electron/Argon/Boron/Xenon/A SoM/B SoM/X SoM)
released on production servers September 6th, 2019
:pencil2: Please read all notes below
Note: This is a Release and may be used for production. Any known issues are likely slated for a future version, (check Github issues). It is available by default for all devices. To use, select the 1.3.1 version dropdown from the devices drawer.
Note: If you have previously last used one of the prerelease versions of 1.3.x-rc.x on a device, please re-flash it with 1.3.1.
  5. Then update to 1.3.1
  • You may update to 1.3.1 directly first, flash the system firmware (attached above) in order 1,2(,3) to the device using particle flash --usb <system-part.bin>. See the next note about the bootloader if you are offline!
1.3.1
Note: If your Gen 2 Photon/P1 or Gen 3 device does not have a Cloud connection, it is recommended to update system firmware via CLI with particle update. Electron bootloaders are still contained in system firmware and will update automatically as needed.
This release contains v401 bootloaders.
SoftDevice update
Prerequisites
particle-cli version 1.46.1.
Upgrading OTA
  1. Upgrade to 1.3.1
  2. Manually flash 1.3.1 bootloader: particle flash <deviceId> boron-bootloader@1.3.1.bin
  3. Flash SoftDevice: particle flash <deviceId> boron-softdevice@1.3.1.bin
  1. Upgrade to 1.3.1
  3. Manually flash 1.3.1 bootloader: particle flash --serial boron-bootloader@1.3.1.bin
  4. Flash SoftDevice: particle flash --serial boron-softdevice@1.3.1.bin
  1. Upgrade Device OS to 1.3.1
  2. (optional, not required) Update the bootloader to 1.3.1 with the OTA or YModem process above
  4. Flash the SoftDevice: particle flash --usb boron-softdevice@1.3.1.bin
FEATURES
  • [gen 3] Nordic SoftDevice update support #1816
  • [gen 3] API for selecting BLE antenna for BLE radio #1847
  • [gen 3] API for setting/getting BLE device name #1847
  • [gen 3] API for setting BLE device address #1847
  • [gen 3] API for manually discovering peer device’s BLE services and characteristics #1847
  • [gen 3] API for fetching discovered peer’s services and characteristics #1847
  • [gen 3] API in BlePeerDevice for establishing BLE connection without scanning required #1847
  • [gen 3] API for manually subscribing/unsubscribing peer characteristic’s notification #1847
  • [gen 3] API for disconnecting all on-going BLE connections #1847
  • [gen 3] BLE support #1740
  • [gen 3] NFC support #1606
ENHANCEMENTS
  • [Boron/BSoM] power: Increases charging current to 900mA when powered through VIN (VUSB) pin #1846
  • Cancel network connection when processing a USB request that resets the device #1830
  • Particle.connected() should return true only after handshake messages are acknowledged #1825
  • [gen 3] USB state tracking enhancements #1871
  • [gen 3] Adds timeouts to I2C HAL operations #1875
  • [gen 3] Refactors BLE event dispatching #1847
  • [gen 3] Decreases BLE runtime RAM consumption #1847
  • [gen 3] Supports up to 23 local characteristics, 20 of them are available for user application #1847
  • [gen 3] Supports up to 3 central links #1847
  • [gen 3] More convenient methods provided in BleUuid class #1847
  • ensures AT interface is responsive #1886
  • [enhancement] Cache cellular diagnostics #1810
  • [enhancement] allow the bootloader to be flashed over DFU #1788
BUG FIXES
  • Fixes a regression introduced in 1.1.0 where the system layer was always sending its handshake messages even if the session was resumed causing increased data usage #1905
  • Properly seeds rand() in multiple threads including system thread. Fixes ephemeral port allocation in LwIP on Gen 3 platforms #1905
  • Control requests that reset the device (e.g. particle usb dfu) no longer cause unnecessary reconnection to the cloud #1905
  • Initialize user module in monolithic builds #1905
  • fixes RSSI regression on G350 (2G) devices #1841
  • [electron, gen3] Temporarily increase IDLE task priority whenever a thread exits (calls vTaskDelete) to resolve a memory leak that resulted in device being stuck “blinking green” until reset in some cases. #1862
  • [gen 3] Fixes mesh pub/sub socket consuming all packet buffers #1839
  • [Photon/P1] Bootloader correctly re-imports the DCT functions from system firmware after its modification through DFU #1868
  • [gen 3] Mesh.off() disconnects the cloud. Resolves an issue with loop() not being executed in SEMI_AUTOMATIC mode after Mesh.off() #1857
  • [Argon] Fixes the issue being unable to reset the device through RST pin by changing the ESPEN mode to OUTPUT_OPEN_DRAIN #1870
  • [Electron/LTE] devices drop Cloud connection every time user firmware opens and closes a TCP socket ch34976 #1854
  • [gen 2] Fixes an issue with clock stretching in I2C slave mode with underrun reads with certain I2C masters (e.g. Gen 3 devices) #1829
  • Fix to ensure device resets after bootloader update #1873
  • Fixes boot issue for Core introduced in 1.2.1-rc.3 #1873
  • [gen 3] Resolved a HardFault after USB cable is unplugged under certain conditions #1871
  • [gen 3] BLE advertising parameters didn’t apply, issue #1874 #1847
  • [gen 3] BLE scanning parameters didn’t apply, issue #1859 and #1855 #1847
  • [gen 3] Local characteristic notification causes SOS: #1847
  • [gen 3] BLE address order reversed #1847
  • [gcc] fixes virtual platform exception on startup #1878
  • Add two-digit mnc diagnostic flag #1804
  • BLE fixes from 1.3.0-alpha.1 #1817
  • NFC Context parameter is missing and NFC.update() will remove callback, fixes from 1.3.0-alpha.1 #1818
  • [lte] cellular fixes #1824
  • fixes #1811 - increases the number of event handlers to 6 #1822
  • [gen 3] fixes memory usage diagnostics (reported negative values in safe mode) #1819
  • System.disableUpdates() operates asynchronously #1801
  • [gen 3] [bsom] Building platform BSOM results flash overflow. #1802
  • [gen 3] [hal] fixes early wakeup by RTC from STOP sleep mode #1803
INTERNAL
  • Adjusts on-device tests #1898
  • Add coverage to CMake unit-tests #1860
  • Pull test implementation out of source file #1867
  • [gen 3] Changes WKP pin to A7 for SoM platforms to avoid an overlap with Ethernet chip on EVB ESPEN mode to OUTPUT_OPEN_DRAIN #1837
  • [hal] Fixes WIFIEN pin mode for ASoM #1889
  • Refactor/move catch test #1869
  • fixes to communications public interface #1863
  • Refactors platform pinmap to be in platform-specific headers #1838
  • Improve compatibility with recent versions of GCC #1806
  • Set path to Boost libraries #1872
  • [docs] Updates spark_publish_vitals and build scripts documentation. #1800
  • [docs] update the test documentation #1683
https://github.com/particle-iot/device-os/releases/download/v1.3.1/particle_device-os@1.3.1.zip
Hi friends!
We just updated release/stable and master branches of the device-os repo to be current with release/v1.3.1.
:warning: Before doing this, make sure you save any changes you have been making in your local copy of release/stable or master (hopefully you are not doing that though and using a feature/branch based on these :wink: )
Hard Reset release/stable
Hard Reset master
You should now be sync’d up again with the most recent release/stable and master
Device OS 1.4.0 Default Release is out on the Web IDE for (Core/Photon/P1/Electron/Argon/Boron/Xenon/A SoM/B SoM/X SoM)
released on production servers September 10th, 2019
Note: This is a Release and may be used for production. Any known issues are likely slated for a future version, (check Github issues). It is available by default for all devices. To use, select the 1.4.0 version dropdown from the devices drawer.
Note: If you have previously last used one of the prerelease versions of 1.4.0-rc.x on a device, please re-flash it with 1.4.0.
  • You may update to 1.4.0 directly first, flash the system firmware (attached above) in order 1,2(,3) to the device using particle flash --usb <system-part.bin>. See the next note about the bootloader if you are offline!
Note: Argon/Boron/Xenon/Argon-SoM/Boron-SoM/Xenon-SoM SoftDevice
1.4.0.
SoftDevice update
Prerequisites
particle-cli version 1.47.0.
Upgrading using particle update
  1. Put the device into DFU mode
  2. Run particle update
DeviceOS, bootloader and SoftDevice should get correctly updated.
Upgrading OTA
  1. Upgrade to 1.4.0
  2. Manually flash 1.4.0 bootloader: particle flash <deviceId> boron-bootloader@1.4.0.bin
  3. Flash SoftDevice: particle flash <deviceId> boron-softdevice@1.4.0.bin
  1. Upgrade to 1.4.0
  3. Manually flash 1.4.0 bootloader: particle flash --serial boron-bootloader@1.4.0.bin
  4. Flash SoftDevice: particle flash --serial boron-softdevice@1.4.0.bin
  2. Update the bootloader to 1.4.0 with the OTA or YModem process above
  4. Flash the SoftDevice: particle flash --usb boron-softdevice@1.4.0.bin
FEATURES
ENHANCEMENTS
BUGFIXES
  • Fixes an issue in IPAddress::operator bool() causing the operator to return false for valid IPv6 addresses #1912
  • Fixes #1865, TCPClient::connect() return values #1909
  • [Gen 2] [LTE] fixes slow to close TCP sockets on SARA-R410M-02B [ch35609] #1909
  • [Gen 3] Subscribes both notification and indication if both properties are present in peer BLE characteristic #1901
  • [Gen 3] Restricts BleCharacteristic templated getValue() and setValue() arguments to be standard layout #1901
  • [Gen 3] BleUuid comparison operators are no longer case-sensitive #1902
  • [Gen 3] Fixes BleCharacteristic constructor template to accept characteristic and service UUID arguments with different types #1902
  • Fixes SerialLogHandler interfering with the Serial setup console in listening mode #1909
INTERNAL
  • Minor enhancements in wiring/no_fixture and wiring/no_fixture_long_running tests #1912
  • [Git] Fixes whitespace issues in .gitmodules #1910
  • [Gen 3] Adds wiring/no_fixture_ble, wiring/ble_central_peripheral and wiring/ble_scanner_broadcaster on-device tests #1901
  • Update release script to include Electron without DEBUG_BUILD=y and tinker-serial-debugging apps for Gen 3 #1903
https://github.com/particle-iot/device-os/releases/download/v1.4.0/particle_device-os@1.4.0.zip
Hi friends!
We just updated release/stable and master branches of the device-os repo to be current with release/v1.4.0.
Hard Reset master
Device OS 1.4.1-rc.1 Release Candidate is out on the Web IDE for (Core/Photon/P1/Electron/Argon/Boron/Xenon/A SoM/B SoM/X SoM)
released on October 1st, 2019
:white_check_mark: This 1.4.1-rc.1 Release Candidate will be defaulted to 1.4.1 on October 14th, 2019 unless there are regressions found that require further patches. :pencil2: Testing on your applications is encouraged and appreciated, thank you! :bowing_man:
  5. Then update to 1.4.1-rc.1
  • You may update to 1.4.1-rc.1 directly first, flash the system firmware (attached above) in order 1,2(,3) to the device using particle flash --usb <system-part.bin>. See the next note about the bootloader if you are offline!
1.4.1-rc.1
Note: If your Gen 2 Photon/P1 or Gen 3 device does not have a Cloud connection, it is recommended to update system firmware, and then the bootloader via CLI with particle flash --serial bootloader.bin (bootloaders found in Github release). Electron bootloaders are still contained in system firmware and will update automatically as needed.
SoftDevice update
Prerequisites
Upgrading OTA
  1. Upgrade to 1.4.1-rc.1
  2. Manually flash 1.4.1-rc.1 bootloader: particle flash <deviceId> boron-bootloader@1.4.1-rc.1.bin
  3. Flash SoftDevice: particle flash <deviceId> boron-softdevice@1.4.1-rc.1.bin
  3. Manually flash 1.4.1-rc.1 bootloader: particle flash --serial boron-bootloader@1.4.1-rc.1.bin
  4. Flash SoftDevice: particle flash --serial boron-softdevice@1.4.1-rc.1.bin
  1. Upgrade Device OS to 1.4.1-rc.1
  2. Update the bootloader to 1.4.1-rc.1 with the OTA or YModem process above
  4. Flash the SoftDevice: particle flash --usb boron-softdevice@1.4.1-rc.1.bin
FEATURES
  • [Gen 2] Adds support for serial number, NCP type and mobile secret in STM32F2 OTP area #1927 #1931
ENHANCEMENTS
  • [Electron, Boron] Increase the PMIC input current limit from 900mA to 1500mA and limit charging current to 896mA to allow 2G/3G devices to function when powered by sufficient power supply through VIN without the battery #1921
  • DTLS handshake timeout increased to 24 seconds to allow 3 retransmission attempts #1914
BUGFIXES
  • [Electron] Fixes RSSI failing due to Power Saving mode active #1917 #1892
  • [Gen 3] Fixes memory leak when scanning for BLE devices #1929 #1926
  • [Gen 3] Fixes reporting of discovered BLE peer characteristic descriptors #1916
  • [Gen 3] Fixes BleCharacteristic::setValue() with default BLeTxRxType argument (BleTxRxType::AUTO) for characteristics with WRITE property #1915 #1913 #1924
INTERNAL
  • [ci] Buildpack builder updated to unreleased branch feature/buildpack-runnable-without-travis to move buildpack builds off of Travis
  • [docs] Adds Artifact Versioning and Tagging (1.0.0) artifacts.md #1703
https://github.com/particle-iot/device-os/releases/download/v1.4.1-rc.1/particle_device-os@1.4.1-rc.1.zip
Device OS 1.4.1 Default Release is out on the Web IDE for (Core/Photon/P1/Electron/Argon/Boron/Xenon/A SoM/B SoM/X SoM)
released on production servers October 16th, 2019
Note: This is a Release and may be used for production. Any known issues are likely slated for a future version, (check Github issues). It is available by default for all devices. To use, select the 1.4.1 version dropdown from the devices drawer.
Note: If you have previously last used one of the prerelease versions of 1.4.1-rc.x on a device, please re-flash it with 1.4.1.
  • You may update to 1.4.1 directly first, flash the system firmware (attached above) in order 1,2(,3) to the device using particle flash --usb <system-part.bin>. See the next note about the bootloader if you are offline!
1.4.1
SoftDevice update
Prerequisites
particle-cli version 1.48.0.
Upgrading OTA
  1. Upgrade to 1.4.1
  2. Manually flash 1.4.1 bootloader: particle flash <deviceId> boron-bootloader@1.4.1.bin
  3. Flash SoftDevice: particle flash <deviceId> boron-softdevice@1.4.1.bin
  1. Upgrade to 1.4.1
  3. Manually flash 1.4.1 bootloader: particle flash --serial boron-bootloader@1.4.1.bin
  4. Flash SoftDevice: particle flash --serial boron-softdevice@1.4.1.bin
  2. Update the bootloader to 1.4.1 with the OTA or YModem process above
  4. Flash the SoftDevice: particle flash --usb boron-softdevice@1.4.1.bin
FEATURES
ENHANCEMENTS
  • Implements a command to reset all network interfaces of a device remotely #1943
  • [Electron] Disables usage of AT+UDNSRN on 2G/3G Electrons in favor of a standalone socket-based DNS client #1940
BUGFIXES
  • [Photon / P1] Limits maximum TLS version to TLS1.1 for WPA Enterprise authentication as TLS1.2 seems to be broken in WICED 3.7.0-7 #1945
  • [Boron] Fixes attachInterrupt(D7, ...) not working due to a constraint introduced previously for cellular devices (Electron) #1939 #1944
  • Send safe mode event when the session is resumed #1935
  • [LTE, u-blox] adds a mitigation to keep DNS Client responsive ch38990 #1938
INTERNAL
  • [test] i2c_mcp23017: implements HighPriorityInterruptInterferer for nRF52840-based platforms #1947
  • [LTE] Removes log noise by closing only untracked socket handles that are open ch37610 #1938
  • [ci] Buildpack builder updated to 0.0.8 to move buildpack builds off of Travis
https://github.com/particle-iot/device-os/releases/download/v1.4.1/particle_device-os@1.4.1.zip
Hello Friends!
Just a quick update that firmware repo branches release/stable and master have been updated to point to release/v1.4.1
If you have any trouble with this, please reference this previous post Particle Device OS Updates Thread
:warning: October 17th, 2019
We have identified a critical issue affecting Gen 3 bootloaders in DeviceOS releases 1.2.1 - 1.4.1.
It has been confirmed to mostly affect some number of Borons, but other Gen 3 platforms may present it as well.
We have confirmed a fix and will be releasing a new DeviceOS version this week. As a temporary measure we are suggesting manually updating bootloaders on Borons using the binary from the GitHub PR.
Device OS 1.4.2 Default Release is out on the Web IDE for (Core/Photon/P1/Electron/Argon/Boron/Xenon/A SoM/B SoM/X SoM)
released on production servers October 18th, 2019
:pencil2: Please read all notes below :necktie:
Note: This is a Release and may be used for production. Any known issues are likely slated for a future version, (check Github issues). It is available by default for all devices. To use, select the 1.4.2 version dropdown from the devices drawer.
Note: If you have previously last used one of the prerelease or release versions of 1.4.x on a device, please re-flash it with 1.4.2.
  5. Then update to 1.4.2
  • You may update to 1.4.2 directly first, flash the system firmware (attached above) in order 1,2(,3) to the device using particle flash --usb <system-part.bin>. See the next note about the bootloader if you are offline!
1.4.2
This release contains v501 bootloaders.
SoftDevice update
Prerequisites
particle-cli version 1.49.0.
Upgrading OTA
  1. Upgrade to 1.4.2
  2. Manually flash 1.4.2 bootloader: particle flash <deviceId> boron-bootloader@1.4.2.bin
  3. Flash SoftDevice: particle flash <deviceId> boron-softdevice@1.4.2.bin
  1. Upgrade to 1.4.2
  3. Manually flash 1.4.2 bootloader: particle flash --serial boron-bootloader@1.4.2.bin
  4. Flash SoftDevice: particle flash --serial boron-softdevice@1.4.2.bin
  1. Upgrade Device OS to 1.4.2
  2. Update the bootloader to 1.4.2 with the OTA or YModem process above
  4. Flash the SoftDevice: particle flash --usb boron-softdevice@1.4.2.bin
BUGFIXES
  • [Gen 3] Fixes a boot/crash-loop due to a POWER_CLOCK_IRQn firing in between the jump into the system firmware from the bootloader #1948
https://github.com/particle-iot/device-os/releases/download/v1.4.2/particle_device-os@1.4.2.zip
Hello Friends!
Just a quick update that firmware repo branches release/stable and master have been updated to point to release/v1.4.2
Device OS 1.4.3 Default Release is out on the Web IDE for (Core/Photon/P1/Electron/Argon/Boron/Xenon/A SoM/B SoM/X SoM)
released on production servers November 25th, 2019
Note: This is a Release and may be used for production. Any known issues are likely slated for a future version, (check Github issues). It is available by default for all devices. To use, select the 1.4.3 version dropdown from the devices drawer.
Note: If you have previously last used one of the prerelease or release versions of 1.4.x on a device, please re-flash it with 1.4.3.
  5. Then update to 1.4.3
  • You may update to 1.4.3 directly first, flash the system firmware (attached above) in order 1,2(,3) to the device using particle flash --usb <system-part.bin>. See the next note about the bootloader if you are offline!
1.4.3
This release resolves a thread-safety issue on Gen 2 devices (Photon, P1, Electron), affecting non-reentrant C standard library functions requiring temporary non-stack storage. It is recommended to update any Gen 2 devices to this release.
SoftDevice update
Prerequisites
particle-cli version 1.52.0.
Upgrading OTA
  1. Upgrade to 1.4.3
  2. Manually flash 1.4.3 bootloader: particle flash <deviceId> boron-bootloader@1.4.3.bin
  3. Flash SoftDevice: particle flash <deviceId> boron-softdevice@1.4.3.bin
  1. Upgrade to 1.4.3
  3. Manually flash 1.4.3 bootloader: particle flash --serial boron-bootloader@1.4.3.bin
  4. Flash SoftDevice: particle flash --serial boron-softdevice@1.4.3.bin
  1. Upgrade Device OS to 1.4.3
  2. Update the bootloader to 1.4.3 with the OTA or YModem process above
  4. Flash the SoftDevice: particle flash --usb boron-softdevice@1.4.3.bin
BUGFIXES
  • [Photon/P1/Electron] Fixes thread-safety issues with non-reentrant C standard library functions requiring temporary thread-local storage #1970
https://github.com/particle-iot/device-os/releases/download/v1.4.3/particle_device-os@1.4.3.zip
Hello Friends!
Just a quick update that firmware repo branches release/stable and master have been updated to point to release/v1.4.3
Device OS 1.4.4 Default Release is out on the Web IDE for (Core/Photon/P1/Electron/Argon/Boron/Xenon/A SoM/B SoM/X SoM)
released on production servers December 4th, 2019
:pencil2: Please read all notes below :tophat:
Note: This is a Release and may be used for production. Any known issues are likely slated for a future version, (check Github issues). It is available by default for all devices. To use, select the 1.4.4 version dropdown from the devices drawer.
Note: If you have previously last used one of the prerelease or release versions of 1.4.x on a device, please re-flash it with 1.4.4.
  5. Then update to 1.4.4
  • You may update to 1.4.4 directly first, flash the system firmware (attached above) in order 1,2(,3) to the device using particle flash --usb <system-part.bin>. See the next note about the bootloader if you are offline!
1.4.4
This release resolves a bug in handling of incorrectly initialized WiFi credentials list, resulting in crashes on a number of Photons and P1s manufactured with DeviceOS 1.2.1 - 1.4.2. It is recommended to update Photons and P1s with factory 1.2.1 - 1.4.2 DeviceOS to this release.
SoftDevice update
Prerequisites
particle-cli version 1.53.0.
Upgrading OTA
  1. Upgrade to 1.4.4
  2. Manually flash 1.4.4 bootloader: particle flash <deviceId> boron-bootloader@1.4.4.bin
  3. Flash SoftDevice: particle flash <deviceId> boron-softdevice@1.4.4.bin
  1. Upgrade to 1.4.4
  3. Manually flash 1.4.4 bootloader: particle flash --serial boron-bootloader@1.4.4.bin
  4. Flash SoftDevice: particle flash --serial boron-softdevice@1.4.4.bin
  1. Upgrade Device OS to 1.4.4
  2. Update the bootloader to 1.4.4 with the OTA or YModem process above
  4. Flash the SoftDevice: particle flash --usb boron-softdevice@1.4.4.bin
BUGFIXES
  • [Photon/P1] Fixes handling of invalid WiFi access point config entries in DCT #1976
https://github.com/particle-iot/device-os/releases/download/v1.4.4/particle_device-os@1.4.4.zip
stable and master DeviceOS repository branches
DeviceOS repository branches release/stable and master have been updated to point to release/v1.4.4
Device OS 1.5.0-rc.1 Release Candidate is out on the Web IDE for (Photon/P1/Electron/Argon/Boron/Xenon/B SoM/B5 SoM)
released on February 6th, 2020
:white_check_mark: This 1.5.0-rc.1 Release Candidate will be defaulted to 1.5.0 on February 21st, 2020 unless there are regressions found that require further patches. :pencil2: Testing on your applications is encouraged and appreciated, thank you! :bowing_man:
  5. Then update to 1.5.0-rc.1
  • You may update to 1.5.0-rc.1 directly first, flash the system firmware (attached above) in order 1,2(,3) to the device using particle flash --usb <system-part.bin>. See the next note about the bootloader if you are offline!
Note: Argon/Boron/Xenon/B SoM/B5 SoM
Note: Argon/Boron/Xenon/B SoM/B5 SoM SoftDevice
1.5.0-rc.1
SoftDevice update
Prerequisites
particle-cli version 2.0.1.
Upgrading OTA
  1. Upgrade to 1.5.0-rc.1
  2. Manually flash 1.5.0-rc.1 bootloader: particle flash <deviceId> boron-bootloader@1.5.0-rc.1.bin
  3. Flash SoftDevice: particle flash <deviceId> boron-softdevice@1.5.0-rc.1.bin
  3. Manually flash 1.5.0-rc.1 bootloader: particle flash --serial boron-bootloader@1.5.0-rc.1.bin
  4. Flash SoftDevice: particle flash --serial boron-softdevice@1.5.0-rc.1.bin
  1. Upgrade Device OS to 1.5.0-rc.1
  2. Update the bootloader to 1.5.0-rc.1 with the OTA or YModem process above
  4. Flash the SoftDevice: particle flash --usb boron-softdevice@1.5.0-rc.1.bin
1.5.0-rc.1
DEPRECATION
  • Spark Core End-Of-Life. 1.5.x+ releases no longer support Spark Core #2003
FEATURES
  • Sleep 2.0 #1986
  • Enables C++14 chrono string literals for wiring APIs #1709
  • [Gen 3] Implements persistent antenna selection (Mesh.selectAntenna()) #1933
  • GCC 8 support #1971
  • [B5 SoM] B5 SoM platform support
  • [Boron/Electron/B5 SoM] Reverts default PMIC settings changes, adds higher level power configuration API #1992
ENHANCEMENTS
  • Enables Workbench DeviceOS local development (deviceOS@source) #1957
  • [Gen 3/Cellular] Enables logging of modem AT commands and data transmissions by default in modular builds #1994
  • [Gen 2] Removes write protection enforcement of system firmware on boot #2009
  • [Cellular] Adds SystemPowerFeature::DISABLE to disable system power management #2015
BUGFIXES
  • [Boron/BSoM] Enables advance SETUP/MODE button features (single click - RSSI, double click - soft poweroff) #1918
  • Fixes a call to objdump when the compiler is not in PATH #1961
  • [gcc] Ensure GPIO pinmap is initialized on first use #1963
  • [Gen 3] Fixes too many connection attempts with deactivated SIM #1969
  • [Gen 3] Fixes NCP issue with devices stuck in a seemingly connected state #1980
  • [Photon/P1] Fixes a hardfault when calling certain WiFI class methods with WICED networking stack uninitialized #1949
  • [Gen 3] Fixes .particle/toolchains/gcc-arm/5.3.1/bin/objdump: not found issues in Workbench #1996
  • [B5 SoM] Temporarily disables hardware flow control #1999
  • [Gen 3] Fixes retained variables first-time initialization #2001
  • [B5 SoM] Removes unsupported AT+CGDCONT call with CHAP:<APN> #2006
  • [Boron] Increases AT+COPS=0 timeout, lowers baudrate to 115200 #2008
  • Prevents expansion of EXTRA_CFLAGS variable #2012
  • [Gen 3] Workaround for QSPI/XIP nRF52840 hardware anomaly 215 #2010
  • Fixes a potential buffer overflow in Time.format() #1973
  • [Gen 2] Clear WLAN_WD when disconnect() is called #2016
  • [Gen 3] Fixes concurrency/thread-safety SPI issues with Ethernet Featherwing #1879
INTERNAL
  • Increase VitalsPublisher test coverage #1920
  • Adds missing platforms to manifest.json #1959
  • Add support for control requests sent by the test runner #1987
  • Add support for chunked transfer of USB request/reply data #1991
  • Implements EnumFlags class for bitwise operations on C++ enum classes #1978
  • Improves cellular test coverage #1930
  • [Gen 3] Frees up some flash space in system-part1 #2000
  • [Cellular] Internal function to modify cellular registration timeout #2007 #2014
  • Removes xsom and asom platforms #2011
DOCUMENTATION
  • Documents adding custom CFLAGS during DeviceOS application build #2004
https://github.com/particle-iot/device-os/releases/download/v1.5.0-rc.1/particle_device-os@1.5.0-rc.1.zip
Device OS 1.5.0-rc.2 Release Candidate is out on the Web IDE for (Photon/P1/Electron/Argon/Boron/Xenon/B SoM/B5 SoM)
released on March 6th, 2020
:white_check_mark: This 1.5.0-rc.2 Release Candidate will be defaulted to 1.5.0 on March 20th, 2020 unless there are regressions found that require further patches. :pencil2: Testing on your applications is encouraged and appreciated, thank you! :bowing_man:
  5. Then update to 1.5.0-rc.2
  • You may update to 1.5.0-rc.2 directly first, flash the system firmware (attached above) in order 1,2(,3) to the device using particle flash --usb <system-part.bin>. See the next note about the bootloader if you are offline!
1.5.0-rc.2
SoftDevice update
Prerequisites
Upgrading OTA
  1. Upgrade to 1.5.0-rc.2
  2. Manually flash 1.5.0-rc.2 bootloader: particle flash <deviceId> boron-bootloader@1.5.0-rc.2.bin
  3. Flash SoftDevice: particle flash <deviceId> boron-softdevice@1.5.0-rc.2.bin
  3. Manually flash 1.5.0-rc.2 bootloader: particle flash --serial boron-bootloader@1.5.0-rc.2.bin
  4. Flash SoftDevice: particle flash --serial boron-softdevice@1.5.0-rc.2.bin
  1. Upgrade Device OS to 1.5.0-rc.2
  2. Update the bootloader to 1.5.0-rc.2 with the OTA or YModem process above
  4. Flash the SoftDevice: particle flash --usb boron-softdevice@1.5.0-rc.2.bin
FEATURES
  • Introduce configurable I2C buffer #2022
  • Support for > 255 I2C buffers and transfers, configurable timeouts #2035
  • Thread-safe cloud variables #1998
ENHANCEMENTS
  • [B5 SoM] Enable hardware flow control for Quectel modem during runtime and add support for EG91-EX #2042
BUGFIXES
  • [Workbench] Workaround for failing Device OS builds on Windows #2037
  • [Gen 2] platform: fix FLASH_Update() for unaligned writes #2036
  • Fixes the issue with SPI default SS pin being not configured #2039
  • [gcc] fixes builds on osx and enables usage of the latest gcc versions #2041
  • [Gen 3] Fixes renegotiation of options and adds IPCP packet parsing #2029
  • [Gen 3] Fix parsing of large AT command responses #2017
  • String::substring() unnecessarily modifies the source buffer #2026
  • [B5 SoM] Fix CGI for Quectel modems #2019
  • [Gen 2] Fixes socket leak in UDP.begin() #2031
  • [Gen 3] Fixes Serial.read() returning -1 instead of 0 when there’s no data to read #2034
  • [Gen 3] Fixes BLE UUID conversion issue #1997
  • [wiring] Fixes a regression in SPI due to thread-safety additions from #1879 #2023
INTERNAL
  • [test] unit: fixes Print tests failing #2027
  • [B5 SoM] Change the prefix of BLE broadcasting name for B5SoM #2030
  • update workbench manifest with latest buildscripts dependency #2020
https://github.com/particle-iot/device-os/releases/download/v1.5.0-rc.2/particle_device-os@1.5.0-rc.2.zip
Device OS 1.5.0 Default Release is out on the Web IDE for (Photon/P1/Electron/Argon/Boron/Xenon/B SoM/B5 SoM)
released on production servers March 30th, 2020
Note: This is a Release and may be used for production. Any known issues are likely slated for a future version, (check Github issues). It is available by default for all devices. To use, select the 1.5.0 version dropdown from the devices drawer.
Note: If you have previously last used one of the prerelease or release versions of 1.5.x on a device, please re-flash it with 1.5.0.
  • You may update to 1.5.0 directly first, flash the system firmware (attached above) in order 1,2(,3) to the device using particle flash --usb <system-part.bin>. See the next note about the bootloader if you are offline!
1.5.0
DEPRECATION
FEATURES
  • Sleep 2.0 #1986
ENHANCEMENTS
  • Replace AT+CSQ usage on Quectel-based devices with AT+QCSQ 147f654
  • Replace AT+CSQ/CESQ usage on ublox-based LTE devices with AT+UCGED #2033 #2038
  • [wiring] Specify floating precision in JSON library #2054
  • Expose full concurrent HAL APIs to the application #2052
  • Close cloud socket on communication errors on all platforms except for Electron #2056
BUGFIXES
  • [Boron/B SoM/B5 SoM] Fix Cellular Global Identity generation #2062
  • [B5 SoM] Strip padding F from ICCID 4aa1746
  • Fix 3G signal strength calculation on ublox-based cellular devices 553af7b
  • Only increment unacknowledged counter for requests, not acknowledgements #2046
  • Fix YModem transfer regression introduced in 1.5.0-rc.2 #2051
  • [wiring] Fixes a memory leakage in Mutex and RecursiveMutex classes #2053
  • [B5 SoM] Fixes a hardfault when Ethernet is enabled #2057
  • [P1] Enable power save clock (32KHz) only if not disabled by feature flag #2058
  • [wiring] Fixes multiple conflicting candidates when calling Wire.requestFrom() #2059
  • [Gen 2] Fix SPI.beginTransaction() deadlocking #2060
  • [Gen 3] Fix a race condition in NCP client when the GSM0710 muxer connection to the NCP is abruptly broken #2049
INTERNAL
  • [test] Removes A6 pin from PWM tests on B5 SoM d9c859c
  • Fix building of boost on macOS #2044
  • [ci] Workaround GitHub rate limiting by using github.com/xxx/yyy/tarball instead of api.github.com
  • Removes xsom platform #2011
https://github.com/particle-iot/device-os/releases/download/v1.5.0/particle_device-os@1.5.0.zip
SoftDevice update
Prerequisites
particle-cli version 2.3.0.
Upgrading OTA
  1. Upgrade to 1.5.0
  2. Manually flash 1.5.0 bootloader: particle flash <deviceId> boron-bootloader@1.5.0.bin
  3. Flash SoftDevice: particle flash <deviceId> boron-softdevice@1.5.0.bin
  1. Upgrade to 1.5.0
  3. Manually flash 1.5.0 bootloader: particle flash --serial boron-bootloader@1.5.0.bin
  4. Flash SoftDevice: particle flash --serial boron-softdevice@1.5.0.bin
  2. Update the bootloader to 1.5.0 with the OTA or YModem process above
  4. Flash the SoftDevice: particle flash --usb boron-softdevice@1.5.0.bin
Device OS 1.5.1-rc.1 Release Candidate is out on the Web IDE for (Photon/P1/Electron/Argon/Boron/Xenon/B SoM/B5 SoM)
released on April 29th, 2020
:white_check_mark: This 1.5.1-rc.1 Release Candidate will be defaulted to 1.5.1 on May 6th, 2020 unless there are regressions found that require further patches. :pencil2: Testing on your applications is encouraged and appreciated, thank you! :bowing_man:
  5. Then update to 1.5.1-rc.1
  • You may update to 1.5.1-rc.1 directly first, flash the system firmware (attached above) in order 1,2(,3) to the device using particle flash --usb <system-part.bin>. See the next note about the bootloader if you are offline!
1.5.1-rc.1
SoftDevice update
Prerequisites
Upgrading OTA
  1. Upgrade to 1.5.1-rc.1
  2. Manually flash 1.5.1-rc.1 bootloader: particle flash <deviceId> boron-bootloader@1.5.1-rc.1.bin
  3. Flash SoftDevice: particle flash <deviceId> boron-softdevice@1.5.1-rc.1.bin
  3. Manually flash 1.5.1-rc.1 bootloader: particle flash --serial boron-bootloader@1.5.1-rc.1.bin
  4. Flash SoftDevice: particle flash --serial boron-softdevice@1.5.1-rc.1.bin
  1. Upgrade Device OS to 1.5.1-rc.1
  2. Update the bootloader to 1.5.1-rc.1 with the OTA or YModem process above
  4. Flash the SoftDevice: particle flash --usb boron-softdevice@1.5.1-rc.1.bin
ENHANCEMENTS
  • [Argon] Increase the size of the ARP queue #2075
  • [Cellular] Increase registration timeout to 10 minutes #2072
  • [Electron / Boron] Make sure that SARA R4-based LTE devices report LTE Cat M1 access technology #2083
  • [B5 SoM] Enable hardware flow control on Quectel modems earlier in the initialization process #2069 #2071
  • [Vitals] Add CoAP transmitted, retransmitted counter diagnostics #2043
  • [Vitals] Add CoAP latency diagnostic #2050
  • Remove locking in some of the SPI and I2C APIs. SPI perofrmance tests #2088
  • Particle.process() no-op when called from custom threads #2085
  • [Electron] Minor log message changes when the modem is not responsive #2087
BUGFIXES
  • [Cellular] Fixes an issue with CGI (Cellular Global Identity) not available on some devices #2067
  • [Electron] Compatibility CellularSignal rssi and qual values generation for LTE devices using AT+UCGED #2070
  • [B5 SoM / Asset Tracker] Zero RSRP/RSRQ values from AT+QCSQ treated as errors #2078
  • [wiring] BLE: use delete for objects allocated with new #2081
  • [Gen 3] I2C HAL recovers the I2C bus on transmission errors #2084
  • [Gen 3] Devices should be able to enter STANDBY / Hibernate sleep mode without specifying any wake-up sources #2086
  • [Gen 3] Fix an issue with platform_user_ram.ld generation when the application path contains ‘data’ #2090
  • [wiring] Fix SPI macros polluting global namespace #2089
  • [system] firmware_update_failed and firmware_update_complete are mixed up 71a8eb56f8d34efbda46f5d547c92e32a42a2148
  • [system] Do not propagate non-critical network errors to communication layer ba6c9d863ed79cd036848329c3b89b3c0e84dbd0
  • [Gen 3] Fix a crash in netif_ext_callback_handler() when parsing unset event fields dd01b12ea6166b6b175c46348a2b4c180d779ead
https://github.com/particle-iot/device-os/releases/download/v1.5.1-rc.1/particle_device-os@1.5.1-rc.1.zip
Device OS 1.5.1 Default Release is out on the Web IDE for (Photon/P1/Electron/Argon/Boron/Xenon/B SoM/B5 SoM)
released on production servers May 6th, 2020
Note: This is a Release and may be used for production. Any known issues are likely slated for a future version, (check Github issues). It is available by default for all devices. To use, select the 1.5.1 version dropdown from the devices drawer.
Note: If you have previously last used one of the prerelease or release versions of 1.5.x on a device, please re-flash it with 1.5.1.
  • You may update to 1.5.1 directly first, flash the system firmware (attached above) in order 1,2(,3) to the device using particle flash --usb <system-part.bin>. See the next note about the bootloader if you are offline!
1.5.1
ENHANCEMENTS
BUGFIXES
  • [wiring] Resolves an incompatibility around usage of SPIClass #2095
https://github.com/particle-iot/device-os/releases/download/v1.5.1/particle_device-os@1.5.1.zip
SoftDevice update
Prerequisites
particle-cli version 2.5.0.
Upgrading OTA
  1. Upgrade to 1.5.1
  2. Manually flash 1.5.1 bootloader: particle flash <deviceId> boron-bootloader@1.5.1.bin
  3. Flash SoftDevice: particle flash <deviceId> boron-softdevice@1.5.1.bin
  1. Upgrade to 1.5.1
  3. Manually flash 1.5.1 bootloader: particle flash --serial boron-bootloader@1.5.1.bin
  4. Flash SoftDevice: particle flash --serial boron-softdevice@1.5.1.bin
  2. Update the bootloader to 1.5.1 with the OTA or YModem process above
  4. Flash the SoftDevice: particle flash --usb boron-softdevice@1.5.1.bin
Branches
release/stable and master branches have been updated to point to v1.5.1 tag.
