Device OS 1.4.3 Default Release is out on the Web IDE for (Core/Photon/P1/Electron/Argon/Boron/Xenon/A SoM/B SoM/X SoM)
released on production servers November 25th, 2019
Please read all notes below :bowtie:
Note: This is a Release and may be used for production. Any known issues are likely slated for a future version, (check Github issues). It is available by default for all devices. To use, select the 1.4.3 version dropdown from the devices drawer.
Note: If you have previously last used one of the prerelease or release versions of 1.4.x on a device, please re-flash it with 1.4.3.
- Then update to 1.4.3
- You may update to 1.4.3 directly first, flash the system firmware (attached above) in order 1,2(,3) to the device using
. See the next note about the bootloader if you are offline!
Note: P1/Photon Bootloader
The Cloud will automatically update the bootloader on P1/Photon devices if your device is online. If your device does not connect to the cloud and it is offline, you should flash the bootloader to the device using particle flash --serial <bootloader.bin>
. This should be done after upgrading system firmware. The Electron bootloader is applied automatically from it’s own system parts.
Note: Argon/Boron/Xenon/Argon-SoM/Boron-SoM/Xenon-SoM Bootloader
If your device is offline, the bootloader must be manually updated using particle flash --serial <bootloader.bin>
. This can be done before or after upgrading system firmware.
Note: Argon/Boron/Xenon/Argon-SoM/Boron-SoM/Xenon-SoM SoftDevice
1.4.3
This release resolves a thread-safety issue on Gen 2 devices (Photon, P1, Electron), affecting non-reentrant C standard library functions requiring temporary non-stack storage. It is recommended to update any Gen 2 devices to this release.
Note: If your Gen 2 Photon/P1 or Gen 3 device does not have a Cloud connection, it is recommended to update system firmware via CLI with particle update
. Electron bootloaders are still contained in system firmware and will update automatically as needed.
This release contains v501 bootloaders.
SoftDevice update
Prerequisites
particle-cli version 1.52.0.
Upgrading using particle update
- Put the device into DFU mode
- Run
particle update
DeviceOS, bootloader and SoftDevice should get correctly updated.
Upgrading OTA
- Upgrade to 1.4.3
- Manually flash 1.4.3 bootloader:
particle flash <deviceId> boron-bootloader@1.4.3.bin
- Flash SoftDevice:
particle flash <deviceId> boron-softdevice@1.4.3.bin
Upgrading using YModem
- Upgrade to 1.4.3
particle flash --serial boron-bootloader@1.4.3.bin
- Flash SoftDevice:
particle flash --serial boron-softdevice@1.4.3.bin
Upgrading using DFU (–usb only works for SoftDevice, not bootloader yet)
- Upgrade Device OS to 1.4.3
- Update the bootloader to 1.4.3 with the OTA or YModem process above
- Flash the SoftDevice:
particle flash --usb boron-softdevice@1.4.3.bin
BUGFIXES
- [Photon/P1/Electron] Fixes thread-safety issues with non-reentrant C standard library functions requiring temporary thread-local storage #1970
System Binaries (all devices)
https://github.com/particle-iot/device-os/releases/download/v1.4.3/particle_device-os@1.4.3.zip
Programming and Debugging
